What OWL device can report power for all 3 phases separately
eagapov
Domoticz version: Stable
Post by eagapov »
can anybody explain me - what OWL device (that i still can find and buy :) will report power consumption on each phase separately?
Now i have OWL CM180i with 3 clamps, but it reports cumulative value, and i need to know separate values per phase...
Thank you in advance,
Eugene
simonrg
Domoticz version: 3.8807
Re: What OWL device can report power for all 3 phases separa
Post by simonrg »
I am using an Owl CM113, connected to 3 separate single phase supplies for household, heat pump and solar electricity, it reports current of each separately. So should be able to same for 3 phase. http://www.homeautomation-direct.com/sh ... M113_.html
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
eagapov
Post by eagapov »
thank you for quick responce. But it's hard to find CM113 now.. :( Wil CM119 works as CM113 in terms of separete phase reporting?
pashek
Post by pashek »
I know this is an old thread but I have the 119 and am also seeing a cumulative total I think. Is it confirmed that only the 113 reports separate readings?
btw8
Post by btw8 »
i have a WBZ from NZR (http://www.nzr.de/en/products/electrici ... r-wbz.html) with LAN Module
See the attached screenshot for the output of this device.
Greetings, Oliver
Synology DS-918+, RFXtrx433E, Philips Hue
eagapov
Post by eagapov »
as i can see on OWL site, there is OWL intuition-lc, http://theowl.com/index.php/energy-moni ... uition-lc/,
that can do exact what i want.
May be anybody knows - will RFXCOM understands this device?
b_weijenberg
Post by b_weijenberg »
yes, the OWl intuition is supported by the RFXtrx433 and RFXtrx433E.
The OWL reports for each channel the instant current usage and about every 4 minutes the total power usage.
RFX-433, RFX-433EMC, RFX-868
eagapov
Post by eagapov »
Exellent, thank you. Now i'll check all my three phases.
