I hope someone can help me with the following problem. I have a Raspberry Pi 2 Model B with an PiFace 2.
The Pi 2 works fine,fast and is stable. The PiFace....is the problem. I can't get it configured to work correctly.
In Domoticz device list I can't get any counter visible, only some switches.
I have tested with different settings like:
- Disable the device tree
- Enable SPI automatic loading
- Checked the blacklist
- Checked the devices : ls -l /dev/spidev*
crw-rw---T 1 root spi 153, 0 Jan 1 1970 /dev/spidev0.0
crw-rw---T 1 root spi 153, 1 Jan 1 1970 /dev/spidev0.1
- Reconfigured the piface.conf a few times:
piface.0.output.0.enabled=true
piface.0.output.0.pin_type=level
piface.0.output.0.count_enabled=true
piface.0.output.0.count_update_interval_sec=10
piface.0.input.0.enabled=false
piface.0.input.0.pin_type=level
piface.0.input.0.count_enabled=true
piface.0.input.0.count_update_interval_sec=10So i see some switches in my Domoticz device list, but no counter. Anyone a good suggestion ?
Thanks,
Leon
Raspberry Pi 2 Model B + PiFace Digital 2
Sudo apt-get update / Sudo apt-get upgrade (up-to-date on 2015-06-24 21:00)
Linux Domoticz 4.0.6-v7+ #798 SMP PREEMPT Tue Jun 23 18:06:01 BST 2015 armv7l GNU/Linux
Domoticz V2.2585 Beta release channel
