Blockly examples
HellStorm666
Domoticz version: 4.11786
Re: Blockly examples
Post by HellStorm666 »
Why doesnt my event work?
It is active, And manualy checked the states of the switches and they are correct.
for example, Yesterday I came home at 21:45. The lights were off, that is correct, because we wheren't at home. But at the moment I am home, it should've turned on the lights.
StanHD
Post by StanHD »
To start with, you do not have Logic Blocks on several of your devices. i.e. First Line:- "If aMobielR...."
What condition do you want to test, On - Off < > etc.?
Python:- Broadlink RM2, Sonos
HellStorm666
StanHD wrote:To start with, you do not have Logic Blocks on several of your devices. i.e. First Line:- "If aMobielR...."
Ohw, right.....
I guessed that on=true, off=false so no extra condition needed.
will change that.
Also simplified it with more events and less els-if in one event.
ea playing movies and controling the lights in a different event than turning the lights on.
lbouriez
Post by lbouriez »
I am looking to do an event who will notify me if the door is open more than 45sec (like I forget to close it).
With my HC2 I used GEA, an amazin scene who can do cofee, but in DomoticZ, I don't know how to do it with Blocky since I don't find any way to do a loop.
Any idea :) ?
pj-r
Domoticz version: V3.8650
Post by pj-r »
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
lbouriez
Post by lbouriez »
Ok, thanks for the link.
I thought I could do it with Blocks :(
Shaggie_NB
Post by Shaggie_NB »
http://www.domoticz.com/forum/viewtopic ... pir#p14415
I cannot understand why people always start with referring to LUA when people ask for a solution in blockly??? :?
Dlanor
Re: home ventilation system
Post by Dlanor »
macaidwin wrote:This is my working Blocky Event for my home ventilation system, level 1, 2, 3 and off.
Electrical scheme:
As i read your scheme right on L is 230v?
Domoticz| Zigbee | SONOFF
dressie
Domoticz version: V2020.2
Post by dressie »
I have a question. I have the following blockly event made for turning off my tv, mediabox and Horizon.
The problem is the following; when away is set on, it will take 5 minuten before it turns off. But when Home is set within the 5 minutes, the media will turn off anyway. It looks like the event is not canceled. Is it something in my blockly event of is it perhaps a "bug"?
pj-r
Post by pj-r »
How do you think domoticz knows to cancel the timer you have set at "set off after..."? ;)
You need to "build" your own timer. So add "AwayTimer" variable or virtual switch to use as a flag.
Then just add bit more cases there(Havent tested but it should work this way):
If Away = On and AwayTimer = Off and Media = On <-- case when you leave the house
 set AwayTimer = On After 5 minutes
Else if Away = On and AwayTimer = On and Media = On <-- case when timer time has passed and you are still away
 set AwayTimer = Off
 set Media = Off
Else if Away = Off and AwayTimer = On <-- case where you cancel the timer eg. return home within 5 minutes
 set AwayTimer = Off
 set Media = On <-- not sure if needed here
Else if Away = Off <-- case when you return to home
 set Media = On
Perhaps some "cancel timers of device xxx" block could help to make these more simple looking.
I think its the same with PIR. You could check the "smart pir script" from wiki.
dressie
Post by dressie »
Thanks @pj-r , I'll give it a try!!
Andrès
Adam
Post by Adam »
Hello there,
is there perhaps someone who could help me with the building blocks in German? :oops:
Adam
BarryT
Domoticz version: 2024.3
Post by BarryT »
dressie wrote:I have a question. I have the following blockly event made for turning off my tv, mediabox and Horizon.
I've done the same here..
Maybe you can learn from this blocky?
G'Luck.
Note, the time function to stay ON between 18.00 and 23.50 is for recording programs @ the horizon box :-)
Yury
Post by Yury »
Please Help.
I do not understand variables comparison. Whenever I use user variables like Time, Integer or String in IF statement it does not work.
This event supposed to occur every minute. but not.
Docc
Domoticz version: 2.3530
Post by Docc »
Can someone please help me understand why this is not working..? :-S
It is a simple fan control. Fan should go on if outside temp is lower than inside temp and goes off if not, but the fan stays off :-(
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
À short question.
Is it possible to use LUX as a comparing in Blocky?
Trying to determine if lights should be on or off based on lux.
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
StanHD
Post by StanHD »
@Minglarn, Yes you can use:-
If Lux < x
Do set Switch On
This works:-
ThinkPad
Post by ThinkPad »
But be sure to have some margin.
<150 lux = On
> 200 lux = Off
Otherwise (with the on/off comparison value close to eachother) your lights might go acting very nervous if a cloud flies by, switching your lights on, and off very soon after.
Minglarn
Post by Minglarn »
Cant get this to work. The actual value for "LUX Hallen" is 67.
But no reaction to this blocky..
Using: v2.311..
As the abowe did not work I tryed a dummy swich and now it works...
Using this blocky:
Minglarn
Post by Minglarn »
OKey need some help here...
I Want this blocky to be active ony between time from morgning 06:00 and after midnight 00:30 . How do I make the time comparison?
Would this work?
