Chromecast status
Chromecast status
The Chromecast status can be retrieved in JSON (see http://fiquett.com/2013/07/chromecast-traffic-sniffing/). Would it be possible to add the Chromecast to Domoticz so we can use the status in events ?
- Domoticz version: 2022.2
Re: Chromecast status
Hm I have a chromecast. Why would you want to see the chromecast status?
To use it in Events. Example: Domoticz turns the lights off when it's past 23:00 AND no one is watching TV (Mediacenter virual switch). And: because we can
- Siewert308SW
- Domoticz version: Stable
Already done this by using the Network presence detection.piotr wrote:To use it in Events. Example: Domoticz turns the lights off when it's past 23:00 AND no one is watching TV (Mediacenter virual switch). And: because we can
Dim lights when Chromcast/TV is on and brighten them when Chromcast/TV is off.
Or when nobody is home for more then 1hr and Chromecast/TV is off then switch OFF TV standby killer (KaKu unit)
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
- rootfs @ USB HDD
ok, your tv has not network connection? That would make sense.
- Siewert308SW
Indeed, my TV doesn't have network connection and there for the Chromecast solves that issuejan_nl wrote:ok, your tv has not network connection? That would make sense.
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
Does someone know if it's possible to start a stream through Chromecast (audio) via Domoticz?
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
- Domoticz version: 3.5033
I don't know it but this repository was posted in the tweakers domoticz topic last week by user zeu: https://github.com/balloob/pychromecastHeisenberg wrote:Does someone know if it's possible to start a stream through Chromecast (audio) via Domoticz?
He has created a simple web interface himself to use with it and put it here: https://github.com/roberthorlings/chromecast-web maybe you can use these repositories to create your wanted situation.
- Domoticz version: 2.4608
I'll give it a try Sunday, or maybe tonight.wmn79 wrote:I don't know it but this repository was posted in the tweakers domoticz topic last week by user zeu: https://github.com/balloob/pychromecastHeisenberg wrote:Does someone know if it's possible to start a stream through Chromecast (audio) via Domoticz?
RPi Model 2: Domoticz Server (Beta)
RPi Model B+: Smart Meter Slave (Stable)
Particle Photon (2x): Prototyping, Controlling LEDS and gathering Sensor data for Domoticz
Arduino Uno R3: with CC2500 Shield for Philips LivingColor Lights 1st Gen.
- Domoticz version: 2.2480
Another possible scenario is, that when you start playback on chromecast it could dim down the lights automatically, and if the playback is paused, it could turn up the lights to normal levels..
Right now I have almost accomplished this, with pychromecast reporting into domoticz, and setting a dummy light switch according to play state. Works for most casts. Except netflix, it doesn't report back pause events (only play events, even when returning from pause state).
Right now I don't have any lights connected to domoticz (have it planned though). So I'm not pursuing netflix support actively at the moment. But I'm in the planning state of installing controllable led strips.
Mysensors HW developer / hacker.
Creator of Sensebender Micro temperature / humidity sensor
Do you have an example script?tbowmo wrote:Another possible scenario is, that when you start playback on chromecast it could dim down the lights automatically, and if the playback is paused, it could turn up the lights to normal levels..
downloaded pychromecast from github https://github.com/balloob/pychromecast
and then using the following python script
It's a draft and seems to work.. Setting a virtual switch on / off, according to the playing state. And also populates a uservariable with the current state.
I don't have any lights connected, so haven't checked how well this works.. (The lights are in development..)
from __future__ import print_function
import time
import sys
import logging
import json
import codecs
from urllib.request import urlopen
from urllib.parse import urlencode
import pychromecast
import pychromecast.controllers.youtube as youtube
domoticz = "http://localhost:8080"
if '--show-debug' in sys.argv:
logging.basicConfig(level=logging.DEBUG)
cast = pychromecast.get_chromecast()
class mediaListener:
domurl="http://localhost:8080"
device=20
def __init__(self, domoticzurl, deviceno):
self.domurl = domoticzurl
self.device=deviceno
self.oldPlayerStatus = 'NONE'
def new_media_status(self, status):
print("mediaListener")
print(status)
if (self.oldPlayerStatus != status.player_state):
self.oldPlayerStatus = status.player_state
if status.player_state == "PLAYING" or status.player_state == "BUFFERING":
data = urlopen(self.domurl+"/json.htm?type=command¶m=switchlight&idx="+self.device+"&switchcmd=on")
else :
data = urlopen(self.domurl+"/json.htm?type=command¶m=switchlight&idx="+self.device+"&switchcmd=off")
self.storeVariable('ChromeState', new_state)
def storeVariable(self,name, value):
value = urlencode({'vvalue':value, 'vname':name, 'vtype':2})
d = urlopen(self.domurl+'/json.htm?type=command¶m=updateuservariable&'+value)
reader = codecs.getreader("utf-8")
obj = json.load(reader(d))
if (obj['status'] == 'ERR'):
d = urlopen(self.domurl+'/json.htm?type=command¶m=saveuservariable&'+value)
listener = mediaListener(domoticz, 106)
cast.media_controller.register_status_listener(listener)
while (1):
pass
- Varazir
Are you running on a raspberry pi? Looks like I have python 2.7 on my Pi and the script is made for 3 right ?tbowmo wrote:downloaded pychromecast from github https://github.com/balloob/pychromecast
It's a draft and seems to work.. Setting a virtual switch on / off, according to the playing state. And also populates a uservariable with the current state.Code: Select all
from __future__ import print_function import time import sys import logging import json import codecs from urllib.request import urlopen from urllib.parse import urlencode import pychromecast import pychromecast.controllers.youtube as youtube domoticz = "http://localhost:8080" if '--show-debug' in sys.argv: logging.basicConfig(level=logging.DEBUG) cast = pychromecast.get_chromecast() class mediaListener: domurl="http://localhost:8080" device=20 def __init__(self, domoticzurl, deviceno): self.domurl = domoticzurl self.device=deviceno self.oldPlayerStatus = 'NONE' def new_media_status(self, status): print("mediaListener") print(status) if (self.oldPlayerStatus != status.player_state): self.oldPlayerStatus = status.player_state if status.player_state == "PLAYING" or status.player_state == "BUFFERING": data = urlopen(self.domurl+"/json.htm?type=command¶m=switchlight&idx="+self.device+"&switchcmd=on") else : data = urlopen(self.domurl+"/json.htm?type=command¶m=switchlight&idx="+self.device+"&switchcmd=off") self.storeVariable('ChromeState', new_state) def storeVariable(self,name, value): value = urlencode({'vvalue':value, 'vname':name, 'vtype':2}) d = urlopen(self.domurl+'/json.htm?type=command¶m=updateuservariable&'+value) reader = codecs.getreader("utf-8") obj = json.load(reader(d)) if (obj['status'] == 'ERR'): d = urlopen(self.domurl+'/json.htm?type=command¶m=saveuservariable&'+value) listener = mediaListener(domoticz, 106) cast.media_controller.register_status_listener(listener) while (1): pass
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
I ChangedVarazir wrote:Are you running on a raspberry pi? Looks like I have python 2.7 on my Pi and the script is made for 3 right ?tbowmo wrote:downloaded pychromecast from github https://github.com/balloob/pychromecast
import urllib
- Varazir
Got one more step forward.daandamhuis wrote:
I Changedto and now it works with Python 2.7Code: Select all
import urllib
I guess I have to do something more as it's not finding the
File "chromecast.py", line 10, in <module>
import pychromecast
ImportError: No module named pychromecast
Did you place the Python script inside the Pychromecast folder? That did the trick for me.
- Varazir
I got it to work sort of:daandamhuis wrote:Did you place the Python script inside the Pychromecast folder? That did the trick for me.
~/pychromecast $ python chromecast.py
mediaListener
<MediaStatus {'player_state': u'PLAYING', 'volume_level': 1, 'images': [], 'media_custom_data': {}, 'duration': 2546, 'current_time': 841.182, 'playback_rate': 1, 'title': None, 'media_session_id': 1, 'volume_muted': False, 'supports_skip_forward': False, 'track': None, 'season': None, 'idle_reason': None, 'stream_type': u'BUFFERED', 'supports_stream_mute': False, 'supports_stream_volume': False, 'content_type': u'video/mp4', 'metadata_type': None, 'subtitle_tracks': {}, 'album_name': None, 'series_title': None, 'album_artist': None, 'media_metadata': {}, 'episode': None, 'artist': None, 'supported_media_commands': 1, 'supports_seek': False, 'content_id': u'http://dummy', 'supports_skip_backward': False, 'supports_pause': True}>
I changed this in the script
domoticz = "http://localhost:80"
domurl="http://localhost:80"
device=33
Edit: I saw that the script is maxing out the CPU
I'm not here on this forum that often..
Anyway, it's a work in progress. Running on a pi2, so don't notice that one core is maxed out by the script. But yes dome kind of wait loop should be made instead of the current while loop, so it doesn't use max cpu.
And yes I'm using it with python3. I have both python 2.7 and 3.4 installed.
I installed pychromecast but cannot seem to find the folder. Do I really need to put the python script inside this folder to run?
Raspberry Pi Type B
RFXCOMtrx433e
RFXCOMtrx433e
Im trying to get this working.
But i am keeping getting this error
Im not a python programmer. I can read code but im not good at wrtiting.
So if you could give me a hint that would be very helpfull
(using raspberry pi2 and python 2).
File "D:\Domoticz\Scripts\PyChromecast\ChromeStatus.py", line 49, in <module>
AttributeError: 'NoneType' object has no attribute 'media_controller'
