[90] MQTT Support
gizmocuz
Re: [90] MQTT Support
Post by gizmocuz »
Not at the moment, but i will implement this.
Also the current mqtt client implementation is a bit buggy i found out, working on a new one as we speak.
gizmocuz
Post by gizmocuz »
new mqtt library implemented.... next i will do the username/password
(that will be another day :lol: )
SweetPants
Post by SweetPants »
gizmocuz wrote:new mqtt library implemented....
I get this when compiling?
/home/pi/domoticz/hardware/MQTT.cpp:216:1: error: expected unqualified-id before ‘<<’ token
<<<<<<< .mine
/home/pi/domoticz/hardware/MQTT.cpp:225:36: error: ‘MQTTAsync_successData’ has not been declared
void mqtt_onConnect(void* context, MQTTAsync_successData* response)
/home/pi/domoticz/hardware/MQTT.cpp: In function ‘void mqtt_onConnect(void*, int*)’:
/home/pi/domoticz/hardware/MQTT.cpp:227:36: error: ‘m_mqtt_mutex’ was not declared in this scope
boost::lock_guard<boost::mutex> l(m_mqtt_mutex);
/home/pi/domoticz/hardware/MQTT.cpp:229:11: error: ‘class MQTT’ has no member named ‘OnConnect’
pClient->OnConnect();
/home/pi/domoticz/hardware/MQTT.cpp: At global scope:
/home/pi/domoticz/hardware/MQTT.cpp:232:1: error: expected unqualified-id before ‘==’ token
make[2]: *** [CMakeFiles/domoticz.dir/hardware/MQTT.cpp.o] Error 1
make[1]: *** [CMakeFiles/domoticz.dir/all] Error 2
maxtrash
Post by maxtrash »
chrille wrote:Hi,
I am a new domoticz user and would really like to try the MQTT support, as my current setup is based on MQTT. [...]
can you share a little on how you have implemented your current setup?
gizmocuz
Post by gizmocuz »
looks like you have an update conflict
issue
svn revert -R MQTT/*
svn revert -R hardware/*
or
svn revert -R *
chrille
Post by chrille »
maxtrash wrote:can you share a little on how you have implemented your current setup?
What I have is more less bits and pieces. I have a number of ESP8266 wireless modules (with temperature, humidity, light and door sensors) that all sends to my MQTT broker. I also have a HA7net and USR-HTW devices that reports to MQTT and finally I'm building an ESP8266/MQTT based module to activate my garage door.
Currently it's tied together with mqttwarn and some scripts, that writes data to RRDtool - however I would like to add better automation than what can be done with mqttwarn and also have a better interface.
Other ideas/plans includes owntrack, more door sensors, power switches (for the espresso machines) and the doorbell. I like to have as much wireless as possible, since the WAF on most wireless stuff is better than wired, and MQTT is a great way to implement new devices without too much hazzle
- Jan
Beaglebone Black, Raspberry Pi (A and B)
Multiple ESP8266 (DIY - temperature, humidity, light, door sensors)
USR-HTW (MQTT), HA7net, 2x Kankun wifi plug (MQTT)
WH1090 weatherstation + weewx (MQTT)
Hikvision IP cameras
KD101 fire alarms
RFXTRX433e + RFlink
SweetPants
gizmocuz wrote: looks like you have an update conflict issue
or
svn revert -R *
You are right, something went wrong with MQTT/*
SweetPants
chrille wrote:What I have is more less bits and pieces. I have a number of ESP8266 wireless modules (with temperature, humidity, light and door sensors) that all sends to my MQTT broker.
- Jan
Jan, are you using NodeMcu or the native MQTT from TuanPMT?
chrille
Post by chrille »
SweetPants wrote:Jan, are you using NodeMcu or the native MQTT from TuanPMT?
I am mostly using this russian software: http://esp8266.homes-smart.ru/ - it support at least 90% of the stuff I want to do, and new features are added all the time. For the garagedoor project I'm currently using NodeMCU but will probably switch to the HomesSmart software as well. The author charges a small fee for licenses, but it's worth it, and I save a lot of time. Most of the documentation is in russian but Google translate does a decent job
- Jan
KD101 fire alarms
RFXTRX433e + RFlink
maxtrash
Post by maxtrash »
- Jan
Didn't know about Mqttwarn, as mentioned on Jan-Piet Mens' site it seems to do similar things as can be done with Node-red. Are you going to keep using it to translate messages from and to Domoticz?
I found something called Freeswitch mentioned in the documentation, that's an interesting thing to investigate as well!
maxtrash
Post by maxtrash »
In the mean time I decided to simplify the wiki-page to just "MQTT": http://www.domoticz.com/wiki/MQTT
I've also created a page with Node-red (example) flows: http://www.domoticz.com/wiki/Flows
One of the new examples is a mindergas.nl flow
gizmocuz
Post by gizmocuz »
thanks!, i added the export to InfluxDB
strangely i could not copy the mindergas flow from the wiki page, i had to edit the source, and then do a copy/past
maxtrash
Post by maxtrash »
you're right, I also couldn't just copy the influxdb flow you added. It's got to do with the tag being used. <blockquote> looked nice to me but is giving these problems. Also <code> does not work properly. <source lang=javascript> does work fine from the copying perspective, however the text is now put in one big line which makes it really inconvenient to copy. There's got to be a better tag/solution for handling this but what is it?!
(have a look at the flow page to see what I mean)
chrille
Post by chrille »
maxtrash wrote:Didn't know about Mqttwarn, as mentioned on Jan-Piet Mens' site it seems to do similar things as can be done with Node-red. Are you going to keep using it to translate messages from and to Domoticz?
For now I need to keep mqttwarn - at least for the following reasons
- rewrite topics (since Domoticz needs everything published to domoticz/in)
- do JSON formatting - most of the data I receive today are in the form of "<device>/<sensor>: <value>"
- do some basic math (like converting pulses from my power meter into watt)
- Jan
KD101 fire alarms
RFXTRX433e + RFlink
kylegordon
Domoticz version: Trunk
Post by kylegordon »
Oh wow, this is fantastic :-D Thank you to all involved!
1 x HP DL380 & KVM
1 x RPI
1 x RFXtrx433 V78
11 x LWRF Switches
1 x LIFX
2 x Echo Dots
6 x Byron PIRs
2 x Nexa PIRs
2 x Kodi
2 x ESP8266 MQTT
1 x GPIO/MQTT PIR
1 x GPIO(PWM)/MQTT LEDs
1 x GPIO(SPI)/MQTT LPD6803 LEDs
Lots of Node-Red glue
kylegordon
This is the node-red flow I use to generate an average temperature from a bunch of sensors in Domoticz, and then feed it back into Domoticz. I find it useful for turning my antiquated heating system on and off, although it has absolutely no protection against hysteresis :-)
[{"id":"66a92c76.9956d4","type":"mqtt-broker","broker":"homeauto.vpn.glasgownet.com","port":"1883","clientid":""},{"id":"5b5ffbeb.a4a004","type":"mqtt out","name":"House Average Temperature Domoticz","topic":"domoticz/in","qos":"","retain":"","broker":"66a92c76.9956d4","x":1074,"y":243,"z":"1b6aed19.e49513","wires":[]},{"id":"6a89d0ab.95763","type":"function","name":"JSONify","func":"msg.payload = '{\"idx\":46, \"nvalue\": 0, \"svalue\":\"' + msg.payload + ';0;0\"}';\n\nreturn msg;","outputs":1,"x":832,"y":243,"z":"1b6aed19.e49513","wires":[["5b5ffbeb.a4a004"]]},{"id":"5601543e.a9feac","type":"function","name":"Average temp","func":"numdevices = 7;\n\ntotal = parseFloat(context.global.masterbedtemp) + \nparseFloat(context.global.guestbedtemp) + \nparseFloat(context.global.geeklofttemp) + \nparseFloat(context.global.kitchentemp) +\nparseFloat(context.global.studytemp) +\nparseFloat(context.global.livingroomtemp) +\nparseFloat(context.global.bottomhallwaytemp);\n\nmsg.payload = (total / numdevices).toFixed(2);\n//msg.payload = msg.payload + 0.5;\n\nreturn msg;","outputs":1,"x":680,"y":204,"z":"1b6aed19.e49513","wires":[["6a89d0ab.95763"]]},{"id":"57bde324.a8421c","type":"function","name":"Average humidity","func":"numdevices = 6;\n\ntotal = parseFloat(context.global.masterbedhum) + \nparseFloat(context.global.guestbedhum) + \nparseFloat(context.global.geeklofthum) + \nparseFloat(context.global.studyhum) +\nparseFloat(context.global.livingroomhum) +\nparseFloat(context.global.bottomhallwayhum);\n\nmsg.payload = (total / numdevices).toFixed(2);\n//msg.payload = msg.payload + 0.5;\n\nreturn msg;","outputs":1,"x":655,"y":292,"z":"1b6aed19.e49513","wires":[[]]},{"id":"78df9949.872068","type":"function","name":"Select payloads","func":"msg.parameters = JSON.parse(msg.payload);\n//console.log(msg.parameters);\nmsg.topic = \"debug output\";\nmsg.payload = msg.parameters.svalue1;\n\nif ( msg.parameters.idx == 35) {\n  context.global.kitchentemp = msg.parameters.svalue1;\n}\n\nif ( msg.parameters.idx == 116) {\n  context.global.masterbedtemp = msg.parameters.svalue1;\n}\n\nif ( msg.parameters.idx == 117) {\n  context.global.geeklofttemp = msg.parameters.svalue1;\n}\n\nif ( msg.parameters.idx == 122) {\n  context.global.guestbedtemp = msg.parameters.svalue1;\n}\n\nif ( msg.parameters.idx == 132) {\n  context.global.livingroomtemp = msg.parameters.svalue1;\n}\n\nif ( msg.parameters.idx == 133) {\n  context.global.livingroomtemp = msg.parameters.svalue1;\n}\n\nif ( msg.parameters.idx == 134) {\n  context.global.bottomhallwaytemp = msg.parameters.svalue1;\n}\n\nreturn msg;","outputs":"2","x":442,"y":206,"z":"1b6aed19.e49513","wires":[["5601543e.a9feac"],["57bde324.a8421c"]]},{"id":"1f56f12.fe0a90f","type":"mqtt in","name":"Domoticz out","topic":"domoticz/out","broker":"66a92c76.9956d4","x":235,"y":189,"z":"1b6aed19.e49513","wires":[["78df9949.872068"]]}]
1 x HP DL380 & KVM
1 x RPI
1 x RFXtrx433 V78
11 x LWRF Switches
1 x LIFX
2 x Echo Dots
6 x Byron PIRs
2 x Nexa PIRs
2 x Kodi
2 x ESP8266 MQTT
1 x GPIO/MQTT PIR
gizmocuz
Post by gizmocuz »
maxtrash wrote:In the mean time I decided to simplify the wiki-page to just "MQTT": http://www.domoticz.com/wiki/MQTT
question, the meter value uploaded to mindergas.nl, should this be divided by 1000 before uploading ?
because i have this value:
roblom
Post by roblom »
Mindergas wants his value in m3 so I don't think it should be devided.
gizmocuz
Post by gizmocuz »
its a pretty big value now ;) 2185074,22
roblom
Post by roblom »
Then the unit in the picture is already wrong, or there is a gas turbine in the backyard :-)
