Low cost window/door sensor
Re: Low cost window/door sensor
When you open the door (contact), which of the LED's turn on?
If both turn on, your battery is low and LP also lights up. Turns out that my battery only lasted for around 6 months. After changing for a new one all worked well again.
- Domoticz version: stable
yes led works but no signal is received by domoticz
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
Have you checked with RFXmngr?jackslayter wrote:yes led works but no signal is received by domoticz
no but I can add to domoticz at the beginning and after it doesn't work (1 day for example)
I plug with 12vdc power supply and signal isn't received by domoticz, I will try with RFXmngr.
same problem on RFXmngr , no signal
Last edited by jackslayter on Thursday 12 February 2015 8:43, edited 1 time in total.
Tahnk You for this !!Thice wrote:I created a small and simple Arduino based device and some code to be able to link any of these cheap 433Mhz devices to the RFXCOM & Domoticz.
All information can be found here: http://www.thice.nl/convert-cheap-433mh ... convertor/
Works really well here.
http://domo-attitude.fr
So, i got a cheap 433Mhz remote with 2 buttons ('A' and 'B') from eBay.
I was able to get a cheap Intertek / Eurodomest paired to it (turned off when i pressed the 'A' button), but Domoticz doesn't seem to pick it up.
When i opened the remote, i saw a SCT2260 chip, which seems to be a clone of the PT2262 if i have to believe this page: http://kinavara.blogspot.nl/2015/02/rem ... -chip.html
I tried to solder the blobs like in this PIR of Raspberry Piet: http://i.imgur.com/tHGAykd.jpg
But doesn't work.
Anyone got a clue about how to solder the blobs? The remote is 433Mhz for sure, because it has a crystal 'BX R433A' in it, and the Intertek / Eurodomest socket responded to it (probably ARC protocol?).
I already have the PIR from this thread, so my Domoticz can receive PT2262 (Lighting4) protocol.
Edit: Hmm weird, RFXmngr doesn't pick up anything, even with 'undec on'
Not with the solder blobs in default configuration, but also not in modified situation.
But the Intertek / Eurodomest plugsocket still responds to it when i solder the blobs back to default... wtf
But doesn't work.
After mailing b_weijenberg from RFXCOM a photo of the PCB in the switch and a link to the datasheet, he told me i had to replace one (tiny SMD) resistor, marked 'R4' on the PCB.
It was marked '475' which stands for 4.7MΩ. b_weijenberg told me i had to replace it with a 3.9MΩ resistor. I first tried tying 3x 1MΩ resistors together and Domoticz picked it straight up! (Lightning4, PT2262).
But these (in comparison with the old one) huge resistors wouldn't fit the casing. I remembered that i still had a broken doorcontact lying around. I used the SMD calculator to find what 3.3MΩ must have for description. '335' it said.
So i opened the doorcontact and found a tiny 335 resistor. Desoldered and soldered it into the remote, and tadaaaaah it was working
Indeed value of that specific resistor needs to be 3.3MΩThinkPad wrote:After mailing b_weijenberg from RFXCOM a photo of the PCB in the switch and a link to the datasheet, he told me i had to replace one (tiny SMD) resistor, marked 'R4' on the PCB.
Changing the value of this resistor changes the oscillation frequency
ThinkPad, you have proven to be very handy now
Haha thanks
It was not that hard, could have figured it out myself with some more time. But went for the easy way and asked b_weijenberg because he probably has seen many of these devices.
And i was lucky that i had a 3.3 resistor from the doorcontact, otherwise i would have had a problem. I don't have any SMD resistors in stock, only the plain old big ones :p
I bought this two (15,31€ Free Shipping) 433mhz standalone smoke alarm, little more expensive !
Work right out of the box with PT2262.
http://www.aliexpress.com/item/433mhz-o ... 82671.html
Is it possible that this cheap sensor does work with the RFXtrx433 and doesn't work with the RFXtrx433E?
I changed from the old RFXcom to the "E" version but it looks like the sensors aren't working anymore.
No
I have the doorcontact working with RFXtrx433e.
Have you enabled the Lighting4 protocol?
- Domoticz version: 3.x
@roblom: I have RFXtrx433 with newest FW86. If I enable Fineoffset/Viking protocol the Lightning4 devices are not received anymore. Do you use those two protocols together?
In RFXtrx user guide, there is no indication that those two protocols are conflicting. I have contacted Bert regarding this issue.
Thanks. Strange but I didn't remember that I had it enabled.ThinkPad wrote:Have you enabled the Lighting4 protocol?
Now second thing is, can I change the "sub" channel of this sensors? I have 3 of them but domoticz sees them as one.
Change the jumpers. See this post from Raspberry Piet: http://www.domoticz.com/forum/viewtopic ... =40#p17076
He has 4 jumpers in the upper left corner, if you change these a bit random (one position between, some of them little bit more to the right etc) the unit will transmit a different device ID.
Hello, i've received those last week as well, but somehow i don't see them in domoticz, i have undec on, and lighting 4 enabled. Did you make some special changes to the jumpers?cosmo61 wrote:I bought this two (15,31€ Free Shipping) 433mhz standalone smoke alarm, little more expensive !
Nevermind, somehow this morning they showed up.
- LouiS22
Same problem, doesn't show up. Time to play with the jumpers i guess.allasia wrote:Hello, i've received those last week as well, but somehow i don't see them in domoticz, i have undec on, and lighting 4 enabled. Did you make some special changes to the jumpers?cosmo61 wrote:I bought this two (15,31€ Free Shipping) 433mhz standalone smoke alarm, little more expensive !
Update: Tricky one: you have to press and hold the test button to trigger it. After that, device is visible
