My mini-monitor! 3 LED's connected to a RaspberryPi where my Domoticz is running on.
The LED's are controlled via a script started from "domoticz_main" showing me the status from 3 important switches.
(burglar alarm active, camera active, minimum 1 door/windows is open)
Hey CopyCatz
do you know what's difference between Bramble Case with or without GPIO (Dropdown field on ETSY)?
I thought it should be an additional cut out... isn't it?
Have you ordered LCD using a PM to Te...?
1 x RPi3
4 x RPI
3 x RPi2
1 x RPI2 + Win 10 IoT (experimental device)
2 x RPI2 Raspbian "Jessie" + Domoticz (for tenants)
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam NOIR
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
RFXtrx 433 E FW 1020
tommit01 wrote:Hey CopyCatz
Yeah you can pm texy. The gpio is the header for attaching electronics, so you will get an opening there if you select the gpio option.
I use Domoticz to conrol various switches and my somfy blinds in two groups, so i have to use 2 remote´s from somfy over the scriptinterface and i/o board.
Andyyyy
To use it for additonally burglar protection I want to couple it with my doorbell via a script which checks if I've armed my alarm system. If yes it will play automatically all sound files on the SD or USB when connecting to power (12V). I placed those sounds on it:
- http://www.youtube.com/watch?v=KDnbvyrPR34 or this
- http://www.youtube.com/watch?v=NNeWxcLeu18
Additionally I need a spcecial transmitter which will be connected in parallel to my doorbell-switch. http://www.intertechno.at/produkte/send ... TS-23.html
Also a remote switch is needed which will activate the powersupply of the sound-modul.
Hardy
... so, finally my "barking-box" ready for operation. Will start barking when my burglar alarm system is activ and someone presses the doorbell.
Last edited by elythomaslumber on Saturday 30 November 2013 11:13, edited 1 time in total.
Ow yes!! Cool idea. Bookmarked the toy! And in case you are home have it play a chearfull ding-dong (or Christmas song as you like). Just put 2 MP3's on the thing and select next song for the barking dog! That'll keep them away
/paul
My 'test' setup using a charger as a UPS! Seems to work 100% although rhe solar is not functional but it gives possible an idea how to safeguard the unit for powerfailures!
Share with you my biggest projects a raspberryPi Photoframe.
Scrapped an old TFT screen and built a new wooden frame and mounted a raspberryPi behind, and put it on the wall.
A script runs every 5 minutes and check for new images to an email address it has and puts them up. And every minute, the photoframe retrieve the images from various cameras and weather forecast.
