[541] Choose icon on push button
djoeney
Hi there,
It would be nice if you could select icons on push on push off buttons.
I have a harmony HUB it would be nice if i could add for example a radio icon when i want to start the listen radio activity.
Compute RPi 2 : Domoticz latest beta, Synology : Domoticz tested beta on failover system.
Peripherals RFXCOM - RFXtrx433, Z-Wave.Me ZME_UZB1 USB Stick,P1 cable on smartmeter, Logitech Harmony Hub, 3 IP camera's
spudgunman
Re: Choose icon on push button
I would really love ability to change icons on all devices
Pjedr
Me too, and on dimmers too.
Thomasdc
same here
- Domosapiens
- Domoticz version: V3.5981
spudgunman
yes but this is for only switches on/off
ArturK
Re: [541] Choose icon on push button
Any news? I made some push buttons for Harmony Hub, but volume up, down, channel up, down and mute icon looks identical. Help.
Raspberry Pi 2B, Logitech Harmony Hub, Z-Stick GEN 5.
robal_k
Same here.
I need the ability to se a custom icon on "Push On Button" and "Push Off Button".
- Dnpwwo
Custom icons can be specified for dimmers already. Just edit the device and the icon drop down is available.
+1!
I'd like that too!
I'd like that too!
Goudtik
Any news yet???
piokuc
Any chance to write code to user can change icon to all type devices ?Dnpwwo wrote:Custom icons can be specified for dimmers already. Just edit the device and the icon drop down is available.
dannybloe
That would be awesome indeed. Changing icons for only switches and dimmers is indeed rather limited.
keson
- Domoticz version: 2021.1
I am also looking for a solution of following goal:
I have a door sensor-contact (closed/open) and the only sensor type I can use is the CONTACT. But this one only has the default "arrows" icon.
I was trying to change the type to ON/OFF type, which allows custom icons (great BTW!), but the drawback is that such sensor allows manual change of the state from user interface and that is what I need to avid so that nobody at home can by mistake change it (and trigger alarm). I know I can lock it with a password, but that is still a kind of uncomfortable.
So either I would welcome an option to change icons on ON/OFF switch or an option to disable the option to manually change the status of the switch.
Any idea?
Any idea?
