Alarm clock
Alarm clock
Hi!
I thought it would be nice to be able to let domoticz do something when your alarm clock goes off..
so maybe play some music to wake you up, lights goes on slowly,...
But alarmclocks must be easy to use and edit times
I really like the standard alarmclock in android phones..
but it would be nice if there is an easy to use app that can launch a json link to activate a 'wake up' scenario?
is there anyone who has good experiences with something like this?
its just more out curiosity that i ask it, and maybe for future projects. But i think that there are people who would like something like this. Someone who already use a good alarmclock app/solutions for this that they can share their experiences with other people on here.
(I know you could just use the 'timers' in domoticz.. but i think that is to complex.. if you want to edit a time, or disable an alarm (on a holyday) or if you wake up 10 min before the alarm goes off.. then it should be easy to cancel the alarm (like in android lolipop) )
regards,
Thomas
regards,
Thomas
Re: Alarm clock
Don't have an Android device, but maybe Tasker is something that you can use? If only we had Tasker on Ios as well
- StanHD
Re: Alarm clock
I am using Tasker with Voice control for many of my Domoticz switches as well as with my Moto 360 watch. It works very well indeed. So I just checked and created a task that puts on the bedroom light when an alarm triggers from the standard Android Clock application. It's a standard function of Tasker and was straight forward to set up. I will test it later when I get home and report back
- StanHD
Re: Alarm clock
Yep, works a treat.
Python:- Broadlink RM2, Sonos
Re: Alarm clock
StanHD wrote:I am using Tasker with Voice control for many of my Domoticz switches as well as with my Moto 360 watch. It works very well indeed. So I just checked and created a task that puts on the bedroom light when an alarm triggers from the standard Android Clock application. It's a standard function of Tasker and was straight forward to set up. I will test it later when I get home and report back
StanHD wrote:Yep, works a treat.
Thanks for all the replies!
I had no idea that Tasker can do so much! seems it's really a must have app for home automation!
Re: Alarm clock
Can you show what you did in tasker? I tried but can't find out what to do.StanHD wrote:Yep, works a treat.
Greets gijs
Verstuurd vanaf mijn A0001 met Tapatalk
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
- StanHD
Re: Alarm clock
In Tasker add an HTTP Get Task like this:
<User
assword@IP
ort>/json.htm?type=command¶m=switchlight&idx=<idx>&switchcmd=On
Add this all to the top line labeled Server
ort
Then add a Profile based upon the Day or Time item to trigger the switch.
<User
Re: Alarm clock
Thanks!StanHD wrote:In Tasker add an HTTP Get Task like this:
<Userassword@IP
Add this all to the top line labeled Serverort
Re: Alarm clock
but that command set lights on, no ramping/wakeuplight
any options to fix that?
- Egregius
- Domoticz version: v2024.7
Re: Alarm clock
I created a function in my php script that sets a dimmer every minute +1%
The function it self is activated by a 'wake' appointment in my GCal.
This is the stuff that handles wake/sleep dimmers:
I basically set a variable. If variable = 0 = do nothing (normal operation). If variable = 1 slowly dim the lights (5% every minute). If variable = 2 slowly add +1% until 30% is reached.
//Wake/Sleep dimmers
$items = array('eettafel','zithoek','tobi','kamer');
foreach($items as $item) {
if(${'D'.$item}!='Off') {
$action = $mc->get('dimmer'.$item);
if($action == 1) {
$level = floor(${'Dlevel'.$item}*0.95);
Dim(${'DI'.$item},$level,$item);
if($level==0) $mc->set('dimmer'.$item,0);
} else if($action == 2&&date('i')%2==1) {
$level = ${'Dlevel'.$item}+1;
if($level>30) $level = 30;
if($level==30) $mc->set('dimmer'.$item,0);
Re: Alarm clock
Ah thats wonderfull!
But how do i use php scripts in domoticz? Put it in the dir /domoticz/scripts ?
- Egregius
Re: Alarm clock
Check the link in my signature
Re: Alarm clock
Can i run the php floorplan on another machine? Or is running on the rpi the best way?
- Egregius
Re: Alarm clock
To keep the info together: http://www.domoticz.com/forum/viewtopic ... 476#p66476
Re: Alarm clock
I made a wiki how to setup a Wakeuplight with a random Zwave dimmer.
It may work with 433mhz.
See https://www.domoticz.com/wiki/Wakeuplight
- Domoticz version: 3.5033
Re: Alarm clock
I use Morning Routine for this. You can choose to run a tasker task or open a url when you switch off the alarm. Any suggestions for IOS alternatives for this?
