Zwave and groups -> how does it work?
leby
Re: Zwave and groups -> how does it work?
Post by leby »
tonygair wrote: My devices have no groups! I need to associate them.
I'm not familiar with your hardware, do you have any dimmer, switch or sensor? Sirens etc does not report only receive so its only some hardware that have groups.
You have used the Aeon stick to include your nodes? Please post a screenshot of your network and groups similar to this one:
/lennart
tonygair
Post by tonygair »
So what do you think could be the reason for the drop outs. I have tried extra relays, no relays (its surprising actually how far a Aeon USBSTICK will throw a signal and receive it) . I have tried short 20-120 and long 720 poll intervals on my controller. Its not batterys.
Using Raspberry Pi,
Aeon S2
Stella Z's
TKB68's
tonygair
Post by tonygair »
Heres the screen shot of my groups and network screen
screenshot of groups and networks
Using Raspberry Pi,
Aeon S2
Stella Z's
TKB68's
leby
Post by leby »
Strange, non of your nodes connects to anyone else then the controller. What kind of hardware is it?
Are they so thermostats?
/lennart
sidepipe
Post by sidepipe »
My guess, from the screenshot, is that they're TRVs :)
In which case it's perfectly normal that they don't have associations. They will just report to the controller at every "wake up interval."
leby
Post by leby »
And for someone ignorant, what's a trv?
/lennart
sidepipe
Post by sidepipe »
Thermostatic Radiator Valve - saves a lot of typing :D
leby
Post by leby »
Ok, well then it's more understandable, tony needs to by some switches!
/lennart
G3rard
Domoticz version: No
Post by G3rard »
I am just starting with Z-Wave, but I think my Group is not working allright because none of the nodes is connected to the controller in the picture.
See screenshot below for the nodes I'm using and the network information.
The nodes are working, but any suggestions if I need to make any changes to the groups?
Not using Domoticz anymore
tlpeter
Post by tlpeter »
I had this issue and i gave the controller a hard reset and included all nodes again (you will need to do that as a hard reset clears it all)
But you could also have a range issue.
G3rard
Post by G3rard »
tlpeter wrote:I had this issue and i gave the controller a hard reset and included all nodes again (you will need to do that as a hard reset clears it all)
I will give that a try. I don't think it is a range issue, because the frontdoor sensor is within 2 meters of the controller.
tonygair
Post by tonygair »
My hardware attached are STELLA Z trvs , raspberry pi and aeon 2 stick, and a couple of danfoss LC13 TRV's. The stella z's have 3 thermostats, a level which appears as a light dimmer switch, and a temperature sensor device. I have set the controller Poll interval to 40 seconds, stella z and danfoss poll interval is 720 seconds. polling is enabled on all stella z's and danfoss valves.
Frequently the valves seem to get quite excited and keep actuating much more than the wakeup interval as if they are trying to push the valve but not succeeding, which I don't think is a good use of battery. And my batteries don't seem to last six months never mind 2 years
Using Raspberry Pi,
Aeon S2
Stella Z's
TKB68's
G3rard
Post by G3rard »
I gave the controller a hard reset and included the nodes again and now all is working allright.
cr1cr1
Domoticz version: 2024.4
Post by cr1cr1 »
Do you know the meaning of the line width in the zwave network graph? I remarked that most of the newer devices have thin lines at their ends while older devices have all bold lines. I mean by "newer" that they are a few days old and have already communicated successfully in the network of course.
Thanks,
Domoticz on RPi2 - RFXCOM RFXtrx433E - Weather Station WMR200 - Z-WAVE.ME UZB - Fibaro FGR[M]222, FGFS101 - GR105n - Opus XT300 - téléinfo Elec.- Everspring SM103 & Vision ZD2102 - NAS Thecus N4800 - Logitech Harmony Ultimate - MXIII-G + Kodi :D
stuiow
Domoticz version: 3.6857
Post by stuiow »
I always though the thinner lines were battery operated devices so they don't repeat signals. Whether that is correct or not i don't know.
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
cr1cr1
Post by cr1cr1 »
Hi Stuviow,
No, it is not the case in my network :
As you can see, the door sensors (9,10,11) have bold lines and operates on battery, and are sleeping devices.
The two last devices I added are roller shutters (16 & 17) and display thin lines (the "Bureau" one has been installed more than two weeks ago and still display thin lines at their ends) :
I would like to understand the meaning of those thin lines !
cr1cr1
Post by cr1cr1 »
No answer on my previous question? Well, I have another one: why does it show two devices without interconnexions though they work perfectly fine in my network ? :roll: :) Devices 21, 22 & 23 have been included in one hour time-frame. 21 showed interconnexions immediately, nothing for 22 & 23 that are exacly the same.
cr1cr1
Post by cr1cr1 »
Well, healing the network seemed to reorganize its view:
