Domoticz and robot vacuum cleaners
Awst6000
Post by Awst6000 »
We're thinking about bying a Neato XV Signature Pro robot vacuumcleaner.
Can such a device be monitored within Domoticz?
If yes, what are the advantages of doing that?
Txs.
ThinkPad
Re: Domoticz and robot vacuum cleaners
Post by ThinkPad »
Chopper_Rob
Post by Chopper_Rob »
I created a script to control a roomba with a simple metered outlet.
The script monitors the usage of the power outlet and determines the state the Roomba is in. Based on this an action is triggered.
The only thing you need extra is a way to send a start signal to the roomba (or other device).
For this i use a DIY infrared blaster, but you could use something else.
https://www.chopperrob.nl/domoticz/7-us ... rol-roomba
Although i wrote this script for a Roomba, you could use it for whatever action you want to do based on the usage.
mongoose
Post by mongoose »
Awst6000
Post by Awst6000 »
Txs, but modifying/soldering such a device is a step too far for me :-)
But it looks promising.
Awst6000
Post by Awst6000 »
I just sent an email to Neato Robotics with the question if Json/Wifi is supported.
I'll update this thread when I get a reply.
Awst6000
Post by Awst6000 »
The answer from Neato support:
(First they asked if I wanted to upgrade the software)
Thank you for clarifying that. No, it cannot be controlled by domotica-software or any other remote software at this time but it would be a nice idea. That might be something I can suggest to my superiors for you. If we could control it by our smartphones or tablets I think that would make things easy to program when we wanted it to clean! I will make the suggestion.
Derik
Post by Derik »
And are there perhaps more robot vacuum cleaners that are supported?
jjnj
Post by jjnj »
LG hombot 3
Derik
Post by Derik »
jjnj wrote:LG hombot 3
Sucks this one good? ;) ;) ;)
And he can drive over a threshold?
Or should the floor be equal ?
Awst6000
Post by Awst6000 »
Because we have a cat and a dog we are thinking about this one:
LG Hombot VR64701LVMP Petcare
Any chance this device can be controlled by Domoticz too?
Txs.
jjnj
Post by jjnj »
Yes all the latest LG hombots are the same, the only difference is the accesoires . They can be controlled using domoticz, can run over small bumps and ledges, carpets and other small obstacles
Awst6000
Post by Awst6000 »
After reading a lot about robot vacuumcleaners we ordered the Neato XV Signature Pro although this device cannot be coupled with Domoticz.
I found that the source code and the cli can be found at:
http://www.neatorobotics.com/lab/linux
Who would like to rewrite the Linux source code? :-þ
SidneyInChains
Post by SidneyInChains »
I was also looking at the Neato ,which is supposed to be the best robot vacuum, but I don't know if its the right choice if it's not compatible with Domoticz. Is there something planned for the future? I mean I could wait another couple of months if I knew that there would be support eventually.
Justintime
Post by Justintime »
ThinkPad wrote:Seems a script is made for Roomba: http://domoticz.com/forum/viewtopic.php?f=31&t=103
as well as the LG Hombot http://domoticz.com/forum/viewtopic.php?f=23&t=5985
Also see this (Dutch) topic: http://gathering.tweakers.net/forum/lis ... es/1050080
For my Roomba,
I contacted the developer. And he is going to send me a pcb. Just have to solder some parts on it and the firmware.
Looking forward to get this working.
Got a nice script ready. No ping on the smartphones, start vacuuming... When ping... Go to base....
Thanks for the tip ThinkPad.
Raspberry Piet
Post by Raspberry Piet »
Justintime wrote: For my Roomba,
I think you mean the developer of this project? (Roomba + ESP8266 DIY)
http://www.mikrocontroller.net/topic/349219
This is also still on my to do list.
Unfortunately the code/firmware for this project is not online for download.
kamienZen
Post by kamienZen »
Here you can find a very good comparison: http://buildyoursmarthome.co/reviews/best-robot-vacuum/
Let me know what do you think. Do you agree with the winner?
fifise
Post by fifise »
I found the following api made to command the neato connect through it's wifi connection, anyone with some skill could help me to make it work with domoticz ?Image
https://github.com/tomrosenback/botvac
Musharna
Post by Musharna »
I bought a Neato 7 in1 robot vacuum cleaner crazysales years ago, it is great. Really save my time. It is cool to monitor it with Domoticz .And surely you can use Domoticz on it. I've seen videos that indicate the precess. It is compatible. One thing to keep your heads up is you should know that not all parameters are shown narmally on it. But would not be a barrier.
Brutus
Post by Brutus »
fifise wrote:I found the following api made to command the neato connect through it's wifi connection, anyone with some skill could help me to make it work with domoticz ?Image
They have a whole new developer section: https://developers.neatorobotics.com/
You can log in with your normal userid and password from neato and be a developer. They made SDK's for Java, Android and IOS language and have an API.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
