One may use the Buienradar's free service for non-commercial purposes.
Put your local lat/lon in the configuration part of the script. Calling the function IsItGonnaRain( 10) will return the average rain fall for the next 10 minutes. 0 is no rain, 255 is very heavy rain. When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
Please mail of PM your changes or suggestions, I'll update the script here.
Regards, Hans
-- IsItGonnaRain( int minutesinfuture)
-- returns: int avarage rainfall for the next minutesinfuture
-- Function to get rain prediction from Buienradar.nl (dutch)
-- http://gratisweerdata.buienradar.nl/#Buienradar You may use their free service for non-commercial purposes.
-- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
-- Spring 2015
-- 28-03-2015 v0.3 bug: quotes around url added.
-- 27-03-2015 v0.2 return value is now average for next time
-- 26-03-2015 v0.1 Initial release
-- todo: some error checking on http and file handling (tmp file)
function IsItGonnaRain( minutesinfuture )
-- config ---------------------------------------------------------
lat='52.09' -- example lat/lon for Utrecht
lon='5.12' -- use MAX 2 decimals behind comma. (Requirement Buienrader)
debug=false
tempfilename = '/var/tmp/rain.tmp' -- can be anywhere writeable
url='http://gps.buienradar.nl/getrr.php?lat='..lat..'&lon='..lon
if debug then print(url) end
read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
file = io.open(tempfilename, "r")
totalrain=0
rainlines=0
-- now analyse the received lines, format is like 000|15:30 per line.
while true do
line = file:read("*line")
if not line then break end
if debug then print('Line:'..line) end
linetime=string.sub(tostring(line), 5, 9)
if debug then print('Linetime: '..linetime) end
-- Linetime2 holds the full date calculated from the time on a line
linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
difference = os.difftime (linetime2,os.time())
-- When a line entry has a time in the future AND is in the given range, then totalize the rainfall
if ((difference > 0) and (difference<=minutesinfuture*60)) then
if debug then print('Line in time range found') end
rain=tonumber(string.sub(tostring(line), 0, 3))
totalrain = totalrain+rain
rainlines=rainlines+1
if debug then print('Rain in timerange: '..rain) end
if debug then print('Total rain now: '..totalrain) end
file:close()
-- Returned value is average rain fall for next time
-- 0 is no rain, 255 is very heavy rain
-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
averagerain=totalrain/rainlines
return(averagerain)
endExample implementation in Domoticz:
----- REGEN ------
minuten=10
regen = IsItGonnaRain(minuten)
print('Regen verwacht: '..regen..' binnen '..minuten..' minuten.')
if regen > 70 then
commandArray['SendNotification']='Sunscreens#Regen verwacht'
. I also don't have a weather station, that's why i use the forecast io. I've seen that rain is not very accurate. That's why this buienradar script comes in very handy!
