IR-Schreib-Lesekopf
jossie67
IR-Schreib-Lesekopf
Post by jossie67 »
I have Landis+Gyr ZME120ACd and a IR-Schreib-Lesekopf from Udo
The IR-Schreib-Lesekopf is connected to the raspberry on /dev/ttyUSB0
I added the IR-Schreib-Lesekopf as an "SO Meter USB" on serial port /dev/ttyUSB0.
In the setup, I can change to Baudrate only to 9600 or 115200, my Landis+Gyr uses 300 Baud.
Where can I change this setting in to 300 Baud.
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
Dlanor
Re: IR-Schreib-Lesekopf
Post by Dlanor »
I have the same kind of problem with my Landis+Gyr ZCF120ABd. I won't get any reading from IR-Schreib-Lesekopf on my RPI.
pi@RaspberryPi ls -l /dev/serial/{by-path,by-id}/*
lrwxrwxrwx 1 root root 13 Jan  1  1970 /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1YI4T4I-if00-port0 -> ../../ttyUSB1
lrwxrwxrwx 1 root root 13 Jan  1  1970 /dev/serial/by-id/usb-Silicon_Labs_USB-IR-Kopf_0092D858-if00-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 Jan  1  1970 /dev/serial/by-path/platform-bcm2708_usb-usb-0:1.2:1.0-port0 -> ../../ttyUSB1
lrwxrwxrwx 1 root root 13 Jan  1  1970 /dev/serial/by-path/platform-bcm2708_usb-usb-0:1.3:1.0-port0 -> ../../ttyUSB0
[b]pi@RaspberryPi ~ $ cu -l /dev/ttyUSB0 -s=9600 --parity=none[/b]
Connected.
Nothing pops up on my RPI. I have tested the IR-Schreib-Lesekopf with my windows laptop. It shows up and reads the data.
Last edited by Dlanor on Wednesday 26 September 2018 20:25, edited 2 times in total.
Domoticz| Zigbee | SONOFF
ThinkPad
Post by ThinkPad »
The output looks quite similar to that of a smartmeter, but similar != same.
I think Domoticz can't parse it, because it doesn't know this kind of telegram.
Maybe it can be implemented :)
pj-r
Domoticz version: V3.8650
Post by pj-r »
Bit offtopic but can anyone say if I can buy ready assembled IR-Schreib-Lesekopf from somewhere?
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
Dlanor
Post by Dlanor »
pj-r wrote:Bit offtopic but can anyone say if I can buy ready assembled IR-Schreib-Lesekopf from somewhere?
Via volkszaehler.org
Dlanor
Post by Dlanor »
ThinkPad wrote:The output looks quite similar to that of a smartmeter, but similar != same.
How can i send the request to be implemented?
ThinkPad
Post by ThinkPad »
You can place a feature request here: http://www.domoticz.com/forum/tracker.php?p=2 and discuss about it here: http://www.domoticz.com/forum/viewforum.php?f=5 (be sure to read the rules of that subforum).
gizmocuz
Post by gizmocuz »
I think for one reason is that the P1 serial port is opened with 9600 baud, Even parity, 7 bits
Maybe your serial protocol is different ?
what you can try:
install 'ser2net' and configure this that port 2000 is opening the right serial device, with the right parameters (in raw mode)
now when you connect from another machine to this port 2000, you should see the serial output
in domoticz, you can also setup a P1 meter with LAN interface
Maybe this will work
Probably later this year you will get a P1 Smart meter (i think everyone in holland will get one)
jossie67
Post by jossie67 »
Gizmocuz,
I don't think I will get a new smart-meter this year, my house was build in 2008.
I have it working now also with stadverwarming, see also
http://www.domoticz.com/forum/viewtopic.php?f=14&t=5270
Raspberry Pi (3x)
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
Dlanor
Post by Dlanor »
gizmocuz wrote:Probably later this year you will get a P1 Smart meter (i think everyone in holland will get one)
I have called Stedin en our area isn't scheduled yet. They have planned it somewhere from 2017 until 2020. Just because it is working fine for them now.
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
In our area ENEXIS is the provider.
When I called them to tell that my meter didn't switch from high to low tariff,
it was immediate replaced by a smart meter.
In my case it was the truth (but who cares?).
Hope this helps
Domosapiens
Dlanor
Post by Dlanor »
I have tried to get my Lesekopf working. I am getting one step closer but am stil far far away. I am sending
pi@raspberrypi ~ $ echo -e "\x2f\x3f\x21\x0d\x0a" > /dev/ttyUSB0
pi@raspberrypi ~ $ cat /dev/ttyUSB0
(ER23)
Does anybody knows more?
jossie67
Post by jossie67 »
Dlanor wrote:I have tried to get my Lesekopf working. I am getting one step closer but am stil far far away. I am sending
Check viewtopic.php?f=31&t=5390 and viewtopic.php?f=14&t=5270
Raspberry Pi (3x)
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
Dlanor
IR-Schreib-Lesekopf
Post by Dlanor »
Thanks! I will give it a try. I give up and wait for support within Domoticz :oops: . Too much noob for this.
Jendemen
Post by Jendemen »
How do I see on what USB port the IR-Lesekopf is connected?
When I use 'dmesg | grep ttyUSB' I see nothing, so it is a bit difficult to amend the python script which reads the Kamstrup.
Dlanor
Post by Dlanor »
Dlanor wrote: Tuesday 07 July 2015 17:33
Finally allmost got it working. Babysteps! @Jossie67 thanks!
