dbfan
anybody knows what description to use to get wind-direction f.i. SSW iso degrees ? from wheather underground as example ?
or does somebody already found a nice way to show a wind-direction icon dependent on the actual direction ?
dbfan
I figured it out with help of the wiki:dbfan wrote:anybody knows what description to use to get wind-direction f.i. SSW iso degrees ? from wheather underground as example ?
- created an additional virtual sensor ( text version )
- made a LUA-script to read the windsensor data, filter out the winddirection data and sent that to the new virtual sensor
hoppa
Anybody knows if we just can use the system icons, like the winddirection icon that is already displayed in the virtual sensor ?
PeterFleur
- Domoticz version: 2.4739
With the API of the Dutch Railroad website (http://webservices.ns.nl/ns-api-avt?station=alphen) you can get an XML file. I've attached the file.
Is there a way to convert that into this page tile? Would be nice to see if there is a delay of the trains before you leave the house.
Peter
Peter
RaspberryPI
ZWave
RFXtrx433E
ZWave
RFXtrx433E
ThinkPad
It can probably be done by making a Lua script that parses the XML and sends the data to a virtual text sensor, just like the person above you did with weather data.
dbfan
Buienradar again down in my frontpage.....
Am I the only one ?
How to resolve ?
Am I the only one ?
How to resolve ?
ThinkPad
https://twitter.com/BuienRadarNL/status ... 1102391296dbfan wrote:Buienradar again down in my frontpage.....![]()
Am I the only one ?
How to resolve ?
jannl
- Domoticz version: 2026.1.x
I think for Python and/or Perl there should be tools to parse XML.PeterFleur wrote:With the API of the Dutch Railroad website (http://webservices.ns.nl/ns-api-avt?station=alphen) you can get an XML file. I've attached the file.
Peter
Might dive into to that in the near future.....(for Perl)
btw, there is no attachment and the links needs a username/password
dbfan
ah, okay...ThinkPad wrote:https://twitter.com/BuienRadarNL/status ... 1102391296dbfan wrote:Buienradar again down in my frontpage.....![]()
Am I the only one ?
How to resolve ?
strange that this one still running http://www2.buienradar.nl/display.php?w ... opacity=75
Skorpion
Thanks for sharing your code. It looks very nice!G3rard wrote:Here is the link were youy can download my frontpage.
http://www.filedropper.com/frontpagegz
The frontpage has a.o. the following changes compared to earlier versions posted in this topic.
- text with cell description changes according to the state (eg alarm on/off, sunrise/set)
- removed bounce effect (no vertical scrolling) on iPad
- use extra div's in the cells above (see also the post from zicht) to show 2 values in one cell
- various layout changes
Let me know if you have any questions regarding the configuration.
Unfortunately, I can't get the dimmer function to work when using your code. It does show the "- On +" text/signs, but after pressing, there is no effect. (I want to use it in combination with my Philips Hue & Living Colors lamps in my Z-wave setup.)
Does it work in your setup? Does it need some altering?
- G3rard
- Target OS: -
- Domoticz version: No
Thanks!Skorpion wrote: Thanks for sharing your code. It looks very nice!
In my setup I can use the dimmer function for Philips Hue and COCO dimmers. I use Hue Lux (only white), maybe you are using the color version?
Not using Domoticz anymore
Skorpion
I use Hue color, LivingColors and LivingWhites. I double checked the code, and as far as I can see, it doesn't differ from yours. There probably must be a faulty piece of code in my files though, because my RPi cpu usage goes sky high when I enable the dimmer function for one or multiple lamps.G3rard wrote:Thanks!Skorpion wrote: Thanks for sharing your code. It looks very nice!
- G3rard
- Target OS: -
Does it work if you use the frontpage.js file from the version I have shared in this topic?Skorpion wrote: I use Hue color, LivingColors and LivingWhites. I double checked the code, and as far as I can see, it doesn't differ from yours. There probably must be a faulty piece of code in my files though, because my RPi cpu usage goes sky high when I enable the dimmer function for one or multiple lamps.
jossie67
Probably a stupid question, but can I swip to the 'next' page , to see cell 20 ect, on a desktop with chrome.
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Landis+Gyr ZME120ACd
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
rijo78
- Domoticz version: V4.10717
Thanks for the great frontpage template. It is working really well for me. I'm getting very addicted to this domotica stuff.
All my switches work great.
I only have two issues left. When in daymode (IsDonker is switched off) I don't see the sun behind the cloud. When IsDonker is on, I can see the moon behind the rainy cloud.
In the frontpage.js I have changed the idx of IsDonker to the one I have in my Domoticz.
Any clue how to solve this issue?
The second issue I have is the pop-up to arm the home in field 1-19. I don't have anything to arm, so I would like to turn this one off. I suppose I have tho exclude a part in the frontpage.js, but it seems I have not excluded the correct part.
where can I find the part where the Domoticz security panel can be turned off? Or is there somebody that can convince me that this really is a needed function, and that I'm just too stupid to see otherwise...
- G3rard
- Target OS: -
The pictures shown related to the weather can be changed in frontpage.js. The pictures that are being used can be found in the icons folder.rijo78 wrote:Hi,
Maybe there is no picture with a sun behind the cloud in the frontpage version that you are using?
You can remove the link to the security panel in frontpage.html.
rijo78
Thanks! Found it. Regarding the images; I was a bit silly. The images are showing as should be. I was expecting something else. Then I checked how the images should look like, and found out that all is working great.The pictures shown related to the weather can be changed in frontpage.js. The pictures that are being used can be found in the icons folder.
Now I only have to wait for my tablet to arrive
rijo78
I don't think this is possible on a desktop computer. Better to work with this template on a tablet.jossie67 wrote:Probably a stupid question, but can I swip to the 'next' page , to see cell 20 ect, on a desktop with chrome.
dbfan
Hi Jan,jan_nl wrote:Added some sort of traffic info, max 4 traffic-jams, the text is clickable and brings you to http://www.anwb.nl/verkeer (which is not configurable (not yet anyway)).
Changes in frontpage.css (cell2_3), frontpages_settings.js and frontpage.js
I also added a script (wget_verkeer.sh) to get an rss feed from verkeerplaza, so this propably only works in the Netherlands. This scripts must run via crontab (changes about every minute)
how can I add more highways ? what is the exact syntax to add f.i. the A73 to this:
var file_string = '';
var CheckHighway = 'A50:' ; // The ; is needed for searching!!
- G3rard
- Target OS: -
You can add some lines of code in frontpage.html to give you some small arrows which you can use to swipe on a desktop.jossie67 wrote:Probably a stupid question, but can I swip to the 'next' page , to see cell 20 ect, on a desktop with chrome.
After
<div id="cnt" class="v-wrap">
<div class="v-box">
of page 1 in frontpage.html add the following:
<!-- show arrow to scroll on desktop -->
<div id="right-arrow"
style="font-size: 20px; position: absolute; right: 23%; top: 50%; z-index: 1000;"
onclick="javascript:window.mySwipe.next();">
<a href="#">></a>
</div><div id="cnt" class="v-wrap">
<div class="v-box">
of page 2 add the following code
<div id="left-arrow"
style="font-size: 20px; position: absolute; left: 23%; top: 50%; z-index: 1000;"
onclick="javascript:window.mySwipe.prev();">
<a href="#"><</a>
</div>Not using Domoticz anymore
ThinkPad
If anyone needs some inspiration, have a look at the 'Toon' interface (smart thermostat from Eneco).
Screenshots can be found in this news article and in this comment.
There is also a basic Android app demo of this: https://toonopafstand.eneco.nl/index_pc.html It seems to be build in 'PhoneGap (Cordova)'.
