LIFX Support
superczar
LIFX Support
Is it possible to add LIFX support ?
I am working on integrating the different interfaces I need to use for my house through Domoticz but missing out on LIFX and Wemo at the moment
superczar
Re: LIFX Support
Solved - In case anyone is interested, i can provide a detailed answer
There are multiple LIFX control libraries available on the net
I fiddled with a Perl library but finally got a reliable solution with lifx-python
Its far from perfect but I could add the LIFX as a dummy switch and now have easy on/off toggles as well as color scenes under scenes
pvm
- Domoticz version: 4.10538
Re: LIFX Support
Lease state in the wiki
Pi314
Re: LIFX Support
I like to use Domoticz, It's very usefull for me. But one thing is missing, the LIFX intégration.superczar wrote:Solved - In case anyone is interested, i can provide a detailed answer
I'm very interested to receive the procedure to implement LIFX.
Thanks,
Pi314
Re: LIFX Support
Great, It's work fine.
One thing is missing it's the possibility to access the bulbs individually
Derik
- Domoticz version: BETA
Re: LIFX Support
Nice..
Only are these better then a HUE?
Very expensive bulbs....?
The reason for that?
superczar
Re: LIFX Support
You can change the name of the bulbs on your network to LIFX1, LIFX2 and so on after which you should be able to call individual bulbsPi314 wrote:Great, It's work fine.
The bulb hardware is better than HUE - 17 W vs 9 W so significantly brighterNice..
Also, the ability to manage saturation independently allows for a far better control on the light spectrum
The official software for the HUE is however far better , the LIFX team has really botched up the apps
Derik
Re: LIFX Support
Do i need other hardware?
Or only a bulb?
The best place to buy?
Or only a bulb?
Pi314
Re: LIFX Support
I don't see where I can insert in the scripts the name or mac adr. of the bulbs.superczar wrote:You can change the name of the bulbs on your network to LIFX1, LIFX2 and so on after which you should be able to call individual bulbsPi314 wrote:Great, It's work fine.
When I execute example_intro.py :
at lights = lifx.Lifx() : it's give the adr. of one bulb
at print(lights.get_colours()) : it's give the parameter of same bulb
at print(lights.get_labels()) : it's give me the name of all bulbs
So I will continue to investigate.
You can check new features will come: http://support.lifx.co/hc/en-us/article ... X-2-0-appsDerik wrote:Do i need other hardware?
Or only a bulb?
The LIFX bulbs are WIFI devices and there is no need of bridge or something like that. They join an exiting WIFI network. It's very easy to install.
You can buy directly at http://store.lifx.co/ but you risk to pay customs fee. You have also in NL http://www.coolblue.nl/
mattc
LIFX Support
New user of Domoticz with a lifx bulb... I've been playing with the new cloud api and have managed to successfully setup a dummy dimmer that works flawlessly.
I've created a dummy switch based on lightwaverf called Lifx and the following lua script (named script_device_Lifx.lua) will allow the control of on/off & dimming:
It's pretty crude, but works a treat.
You'll need to get your own api key from chendo @lifx in order to use this functionality. See here: https://github.com/chendo/lifx-http/iss ... t-72760322
I'd like to take this further & implement a colour wheel... is there any way of creating a dummy switch with a colour wheel in domoticz? Failing this is there any decent documentation to allow me to write my own hardware device?
DomDevice = 'Lifx'
lifxlabel = '<INSERT THE LABEL OF THE BULB YOU WANT TO CONTROL HERE>'
apikey = '<INSERT YOUR OWN API KEY HERE>'
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
print ("Turning off " .. DomDevice);
runcommand = "curl -H \"Authorization: Bearer " .. (apikey) .. "\" -XPUT https://api.lifx.com:443/v1beta1/lights/label: .. (lifxlabel) .. "/power.json?state=off";
os.execute(runcommand);
elseif(devicechanged[DomDevice]=='On') then
print ("Turning on " .. DomDevice);
runcommand = "curl -H \"Authorization: Bearer " .. (apikey) .. "\" -XPUT https://api.lifx.com:443/v1beta1/lights/label: .. (lifxlabel) .. "/power.json?state=on";
DomValue = (otherdevices_svalues[DomDevice]);
CalcValue = DomValue / 31.25;
print ("Dimming " .. (DomDevice) .. " to " .. (CalcValue) .. " ");
(apikey) .. "\" -XPUT https://api.lifx.com:443/v1beta1/lights/label: .. (lifxlabel) .. "/color.json?color=brightness:" .. (CalcValue) .. " ";
return commandArrayIt's pretty crude, but works a treat.
mattc
Re: LIFX Support
Added the above to the wiki
Pi314
Re: LIFX Support
Now is possible to generate your own api key (token) yourself by logging into https://cloud.lifx.com/ and going to <your email> -> Settings.
@mattc
They are some typo error
, corrected lines:
runcommand = "curl -H \"Authorization: Bearer " .. (apikey) .. "\" -XPUT https://api.lifx.com:443/v1beta1/lights/label: .. (lifxlabe) .. "/power.json?state=off";
runcommand = "curl -H \"Authorization: Bearer " .. (apikey) .. "\" -XPUT https://api.lifx.com:443/v1beta1/lights/label: .. (lifxlabel) .. "/color.json?color=brightness:" .. (CalcValue) .. " ";
in the wiki:
domoticz/scripts/lua/script_device_Lifx.lua
@mattc
in the wiki:
mattc
Re: LIFX Support
that's weird, I just copy pasted my working code. Thanks for correcting it.
I'd love to see a native hardware device for lifx in domoticz using the api, I'm sure it could be a quick adaptation of the Hue stuff. I had a quick look but looks too involved for me
phitar
- Domoticz version: 2.2436
Re: LIFX Support
Wonderful being able to include the LIFX lights ! Thank you so much.
2 minor points:
I had an issue with Lamp Names including spaces. Removing them or replacing them with %20 enabled the scripts.
The typos are still present, missing ¨ after the XPUT parameter in the wiki.
2 minor points:
l00pz
Re: LIFX Support
I would also like to control the LIFX lights with Domoticz, but I`m unable to get them working.. I think it has something to do with me using the wrong script, but where do I need to put the " that is not present in the Wiki according to the last post?
Is the correct line: runcommand = "curl -H \"Authorization: Bearer " .. (apikey) .. "\" -XPUT https://api.lifx.com:443/v1beta1/lights/label: .. (lifxlabe) .. "/power.json?state=off";
Or is it: runcommand = "curl -H \"Authorization: Bearer " .. (apikey) .. "\" -XPUT "https://api.lifx.com:443/v1beta1/lights/label:" .. (lifxlabe) .. "/power.json?state=off";
phitar
Re: LIFX Support
I thought I had corrected it in the wiki and can't seem to find a difference with what I have.
The log file may give you clues about what's wrong.
The problem I kept on having is the cut&paste function removed some " from the script, specifically those before " ..(lifxlabel) .. "
Here is the script I am using and that is working for me.
Do you LIFX devices have very simple names ?
DomDevice = 'DEVICE NAME'
lifxlabel = 'LIFX LABEL'
apikey = 'LIFX API KEY'
print ("Turning off " .. DomDevice .. " named " .. lifxlabel);
runcommand = "curl -H \"Authorization: Bearer " .. (apikey) .. "\" -XPUT https://api.lifx.com:443/v1beta1/lights/label: ..(lifxlabel) .. "/power.json?state=off";
print ("Turning on " .. DomDevice .. " named " .. lifxlabel);
runcommand = "curl -H \"Authorization: Bearer " .. (apikey) .. "\" -XPUT https://api.lifx.com:443/v1beta1/lights/label: ..(lifxlabel) .. "/power.json?state=on";
l00pz
Re: LIFX Support
I created a new script, but I keep getting errors in the Logviewer:
2015-04-02 20:39:30.113 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:39:30.128 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:39:30.163 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:39:30.178 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:39:30.213 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:00.220 Hardware Monitor: Fetching data (System sensors)
2015-04-02 20:40:00.230 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:00.253 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:00.290 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:00.317 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:00.352 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:00.460 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:00.453 (E Thermostaat) Thermostat (E Thermostaat)
2015-04-02 20:40:01.008 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:00.465 (E Thermostaat) Temp (E Thermostaat)
2015-04-02 20:40:01.032 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:01.281 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:01.291 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:01.286 (Weather Underground) UV (Unknown)
2015-04-02 20:40:01.305 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:01.319 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:01.312 (Weather Underground) General/Visibility (Unknown)
2015-04-02 20:40:02.687 Error: .../dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua:10: unexpected symbol near '?'
2015-04-02 20:40:02.679 (Dommoticzlifx) Lighting 5 (Domoticzlifx)
2015-04-02 20:40:03.340 Executing script: /home/pi/dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua
2015-04-02 20:40:03.350 Error: Error executing script command (/home/pi/dev-domoticz/scripts/lua/script_device_Domoticzlifx.lua). returned: 32256
My script contains the following rules:
My LiFX Bulb is named "Woonkamer", and the Switch in Domoticz is named Domoticzlifx
DomDevice = 'Domoticzlifx'
lifxlabel = 'Woonkamer'
apikey = '**'
mattc
Re: LIFX Support
Here's an upload of my working script... hopefully will avoid the cut/paste weirdness going on!
Oh, and take your key out of the post above.... your letting anyone control your lights by publishing it!
- script_device_Lifx.lua.zip
- (984 Bytes) Downloaded 214 times
l00pz
Re: LIFX Support
Sorry for the late reaction, but with you`re script it seems te be working
One sidenote though, I keep getting the 32256 error in the Log viewer. Any idea what that could be?
And another question, what type of Switch do I need to add to get the dimming function working?
