Now that RFX/Domoticz supports the selectplus doorbells (fw237) it works great and i can trigger events on doorbell now which is useful and it works if doorbell is physically pressed or pressed through domo - i was just wondering if it could go one step further and mute the doorbell, well chimes at certain times of the day - mainly because got a new born and its always sods law that someone rings the doorbell when he just goes down to sleep AND 9 times out of 10 i forget to physically mute the doorbell! lol
the chime has 3 physical options of sound and LED Light, sound only and LED Light only... i dunno if it could even be possible has anyone else done it or got something similar?
be nice to be able to toggle between mute/sound form phone/domo.
This is the kit i've got:
http://www.amazon.co.uk/gp/product/B00P ... ge_o00_s00
SelectPlus Mute the Doorbell
Re: SelectPlus Mute the Doorbell
You can unlearn the code from the physical doorbell button and learn a new code from Domoticz. Then you can make a script that sends the new code when Domoticz is receiving the original code from the physical button. Combine it with a time period and you're done.
Thanks! can't get the darn thing to "unlearn" even after being unplugged for from socket and doorbell battery removed for 30mins! lol but makes sense how to do it now thanks!
Hello! Is there any success with "unlearning" selectplus doorbell?
- Westcott
According to the instructions for mine, you have to hold the melody selector button for 5 secs (or until the LED flashes).
This will apparently "delete all the information within the receiver".
- Target OS: OS X
- Domoticz version: 2.2293
I found that for the black/white SelectPlus doorbell sets (Dutch Action stores) the chime unit learns the first received code when powered up.
So after a power outage I have to press the doorbell button to have the chime to learn the right code.
When powering-up 2 chime units they both learn the same code from 1 sender button.
DomoticZ can learn the same code and send it to the linked chime units.
So if you don't want the chime to ring during certain time periods, DomoticZ should use a different code from that of the front doorbell button.
DomoticZ can only learn a SelectPlus code, you can't set a code manually, so you have to buy a second doorbell set to have a different code learned to DomoticZ.
So then button1 (front door) and button2 are teached to DomoticZ and only button2 is teached to the chime(s).
After a power outage you have to press button2 (button2 itself or in DomoticZ).
Hope this helps.
Hope this helps.
- chimit
- Domoticz version: master
Maybe if you fiddle in the database a bit, you can change the learnt code without having to buy a second unit.
