Problem adding Weather Underground
Iron Man
Post by Iron Man »
I see all of you have done a pretty good job with the frontpage. I also have been busy with it but had some trouble with the weather forecast.
I noticed that my Domoticz won’t accept my virtual weather underground and I keep getting an error that the http can’t be reached or something.
I hoped someone could help me with that.
I also have tried to get the forecast information of the api page. The page url would be something like "http://api.wunderground.com/api/"+api+" ... ion+".json" this is what I used in javascript, but I can’t get the information of the page.
I really hope somebody can help me with one of these things.
Kind regards,
Rob van Hoof
Iron Man
Post by Iron Man »
@mvveelen thanks for your fast reply
I have tried your suggestion but still get the error:
"Fri Feb 20 17:30:00 2015 Error: Wunderground: Error getting http data!"
At the moment I have used this as setting:
(I would have post a image but I don't know how xD)
mvveelen
Post by mvveelen »
And 'Bladel' is the exact name of the weatherstation that is the nearest? Normally they have a slightly different name (and I think also in capitals), like 1BLADEL or something like that.
Oh, and posting images is very easy, just use the tab "Upload attachment" and then use the inline option.
Iron Man
Post by Iron Man »
Oke thanks,
This are my settings at the moment:
But the exact name of the weather station is: INOORDBR26 and it is located in “Hapert”.
Last edited by ThinkPad on Saturday 21 February 2015 11:02, edited 1 time in total.
Reason: Deleted attachment because API-key was visible, keep it for yourself, for your own security
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Iron Man wrote:Oke thanks,
I used for location helmond_netherlands
Iron Man
Post by Iron Man »
SwordFish wrote: I used for location helmond_netherlands
I have tried your suggestion. I tried “bladel_netherlands” and “hapert_netherlands” but I still get the same error. But still thanks for your replay.
mvveelen
Post by mvveelen »
Have you tried:
pws:INOORDBR26
or just
INOORDBR26
Walk through all the steps and read carefully. I made the mistake the first time to 'forget' the ' pws: '
edit: I'm using:
pws:IBLOKKER2
SwordFish
Post by SwordFish »
Is your Api key right?
When I use my api key with bladel_netherlands it works;
When I use youre Api (from the screenshot) it doesn't work, So chech if your Api key is correct.
Iron Man
Post by Iron Man »
mvveelen wrote:Have you tried:
pws:INOORDBR26
or just
INOORDBR26
I already tried that one if i remember right but to be sure I tried it again and still got the error.
I'm sorry I blured out some numbers the api is <API_KEY_removed_by_moderator>
But is you use this link:
http://api.wunderground.com/api/API_KEY ... lands.json
You can see the api is working.
But by some meaning I can't get it to work in my Domoticz sytem.
Last edited by ThinkPad on Saturday 21 February 2015 11:05, edited 2 times in total.
Reason: Deleted API-key, keep it for yourself, for your own security
SwordFish
Post by SwordFish »
If you install the virtual devices as told in the wiki and you still don't get data then its stops for me, sorry.
Maybe someone else can help you.
Iron Man
Post by Iron Man »
SwordFish wrote:If you install the virtual devices as told in the wiki and you still don't get data then its stops for me, sorry.
No problem but still really thanks for your help!
ThinkPad
Re: Problem adding Weather Underground
Post by ThinkPad »
I removed the above posts from this topic: http://domoticz.com/forum/viewtopic.php ... &start=420 because they were too much offtopic there.
Please create a new topic for problems you encounter that have nothing to do with the topic you were posting in
Oh and by the way, i have removed your API key from posts in this topic. This forum is also indexed by Google, so everyone can find your API-key, and use it if they want. It is advisable to ask WU for a new API-key, as this one is maybe already used by others now. API-key is a personal key, not meant to be shared with others.
HansLe
Domoticz version: V2.3530
Post by HansLe »
Hi, I've the same problem. Used the URL with my app key and location and get the weather information. Using the api key and location in domoticz is not working. I get the following message in the log file :Error: ForecastIO: Invalid data received!
Were you able to solve it?
Raspberry Pi B+ | Domoticz v3.4834 | RFXtrx433E | Action sockets and remote control (a cheap solution to start with)
Sonos device: control via Action remote control and EasySonos (via Domoticz scripts)
2 x Chresta TX320, Kaku sensoren, D-link camera
HansLe
Post by HansLe »
OMG what a .... I was. I selected the first "Forecast IO (Weather lookup)". Searching the program sources I saw Wunderground.cpp. Back to domotecz and selected "Weather underground". All the devices came by the wind ;-)
