I got a USB camera Logitech C270 connected and I have tried Motion and fswebcam and it works perfect and takes nice pictures.
But I want to use this raspberry and webcam as "webcamserver" so that I can get snapshots in Domoticz.
I have a couple of Axis cameras and Dlink with those cameras I can use wget and fetch a image.
Is there a software that I can use with the raspberry that function the same way ?
Raspberry, webcam och Domoticz
- Mince Inside
Re: Raspberry, webcam och Domoticz
This should be possible with Motion
http://www.raspberrypi.org/forums/viewt ... 61#p374790
Just set the port number not to be the same as any other web services running on the Pi and you should be good.
Have a look here 1st
http://www.domoticz.com/wiki/Camera_Setup#USB_Camera
Domoticz V2.2259
Raspberry Pi (B) with PiFace
RFXtrx433 USB
LighwaveRF relays, dimmer bulbs and light switches
Siemens On/Off 13A adaptors
Marmitek MS13E Motion (and Dusk) sensors
RFXtrx433 USB
- Domoticz version: 3.6369
Thanks for your answer.
I plan to put this rasberry pointing my parkinglot.
I have my other raspberry running Domoticz
So using uvccapture is no option.
Motion is working fine but I cant take "snapshots" from it on demand only on specified time like each 5 minutes or so.
- Mince Inside
There must be a URL for snap shot - ie what is being sent every 5 mins as a command?
Domoticz V2.2259
RFXtrx433 USB
RFXtrx433 USB
In Motion conf you can specify time when snapshot will be taken
Which imageurl needs to be used when you want to use FSwebcam (and not uvccapture)?Mince Inside wrote:There must be a URL for snap shot - ie what is being sent every 5 mins as a command?
Domoticz| Zigbee | SONOFF
Yeah same with my old webcam, works in fswebcam and do not want overhead of motion running, should be possible to use fswebcam as command to trigger image capture rather than uvccapture
