Dashticz - Alternative Dashboard
Landry
Re: WIP - Dashticz - Alternative Dashboard
Post by Landry »
Ok thx a lot for your work!
jesper
Post by jesper »
I like the layout very much
Is it possible to get so more info on the sensor box like the image if yes how?.
BigDog
Domoticz version: V3.9269
Post by BigDog »
very nice indeed wil try it
it looks very interesting and easy to use
greetz Bob
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
Roncalli
Post by Roncalli »
Hi everyone,
This really looks great and I'd like to test it. Unfortunately I don't manage to get it up and running.
What I did:
- downloaded latest version from GitHub
- unzipped it
- copied everything into a new folder "dash" in Domoticz' "www" folder
- edited CONFIG.js in the "dash" folder with 'sudo nano' to:
//GENERAL HOSTS
var _HOST_DOMOTICZ = 'http://192.168.1.89:8080'; //IP-address of Domoticz-server, e.g.: http://192.168.1.3:8084
//HOSTS IF DASHTICZ IS INSTALLED ON A WEBSERVER WITH PHP-SUPPORT
var _HOST_XBMC = ''; //IP-address of XBMC/Kodi device, e.g.: http://192.168.1.109:8080
var _HOST_JOINTSPACE = ''; //IP-address for televisions supported by JointSpace, e.g.: http://192.168.1.51:1925
- saved and closed it
Where am I a now supposed to access the new dashboard? When I enter 192.168.1.89:8080 everything looks as usual...
Sorry for the noob question!
Domoticz Stable on RaspberryPi 3B+ running stretch-light
Aeon-Labs stick with 23 z-wave devices, RFXtrx with 14 devices, Netatmo with 6 modules, Satel Integra, Instar IP Camera
Luuc_a
Post by Luuc_a »
Try http://<IP domoticz>:<port>/dash
Roncalli
Post by Roncalli »
Hmm, tried typing http://192.168.1.89:8080/dash into my browser (Safari).
Still I only get a white page. Any other ideas?
Thanx
Roncalli
Post by Roncalli »
Got it working now. Don't know what the problem was. Before I used my Mac to download and unzip. Now used my wife's Windows notebook. However, is running now and I'm testing. Cheers
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Sorry for the late response, was a bit busy for a week.
Hope all works well for now, if you have any further questions, add a reply :)
JHummelman
Post by JHummelman »
Have the same issue as Roncalli. Followed exactly the same step by step plan, have changed the IP address to my Domoticz server but get a blank page. I have tried installing on the same webserver as my Domoticz install is running on as well as a separate webserver (with PHP) in my network. Same results unfortunately.
robgeerts
Post by robgeerts »
Wich version are you using?
What are the contents of your _CONFIG.JS?
If you open javascript console in your webbrowser, do you get any errors?
JHummelman
Opening the JS Console in Chrome says this:
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check http://xhr.spec.whatwg.org/. (jquery.min.js:4)
I am running the release from 07-03-2015 (downloaded yesterday from Git)
Content of CONFIG.JS:
//GENERAL HOSTS
var _HOST_DOMOTICZ = 'http://192.168.1.10:8084'; //IP-address of Domoticz-server, e.g.: http://192.168.1.3:8084
var _HOST_NZBGET = 'http://192.168.1.10:6789/jsonrpc';
I deleted the lines below these as I don't use XBMC/KODI, but when they were still in the file it did not function either. Hope this helps! Thanks!
robgeerts
Post by robgeerts »
Well, besides the fact you have to remove/jsonrpc from the url in the config I'm not seeing anything strange... What version of chrome do you use? Do you have Skype/Teamviewer? That way I will maybe be able to solve the problem faster...
remb0
Post by remb0 »
Very nice! I use it and it's great.
However I have some ideas:
an block with buienradar (as grafic)
my xbmc is more offline as online so a popup isn't necessary
the charts on a different page
and below some icons to the other pages?
robgeerts
Post by robgeerts »
Well, I tried a new block for Buienradar with a graphic-interface but the design didn't fit well the Dashticz-layout.
If you have want to propose a design, I would be glad to see one :)
But, if your XBMC-device is offline, there is no popup on the dashboard?
Or, if it is, could you send me a screenshot?
Last but not least, in the latest version, the charts are on a different page now :)
I also have tried a new fix for the white-page-error some users are getting, I hope it's fixed now.
I cannot really test this because on my pc I'm not getting this error.
robgeerts
Post by robgeerts »
Some goods news, one user has just confirmed the white screen was gone after the last update!
TheDude
Post by TheDude »
First of all: I really like Dashticz. It is so simple and clean :). So thank you!
I do have a question though: I switched the theme from default to Darkoticz and I cannot find how to change it back to default. The header won't show with the Darkoticz theme.
From the source, dashticz.js, I figured that the preferences are stored in a 'uservars' object (from Domoticz?), so I manually set it again via the URL, but that didn't work.
What am I doin wrong? :p
robgeerts
Post by robgeerts »
That's true, I added the menu last night and Darkoticz theme is not yet prepared for this...
You can always remove the dashticz_theme variable on the UserVariables page of Domoticz.
TheDude
Post by TheDude »
Thank you so much! It's all default again. I didn't know of that page in Domoticz. Learning everyday :).
JHummelman
robgeerts wrote:Some goods news, one user has just confirmed the white screen was gone after the last update!
Hi Rob, I can confirm this as well :) problem solved and many thanks!
robgeerts
Post by robgeerts »
Great:)
