P1 meter results are not showing
geoffrey
Post by geoffrey »
I have a P1 DIY cable... which after some tweaking in python I got working to read out..
also the commandline nicely shows my output...
cu -l /dev/ttyUSB0 -s 9600 --parity=none
Connected.
<COMMENTED OUT>
0-0:96.1.1(39373936353532302020202020202020)
1-0:1.8.1(06389.574*kWh)
1-0:1.8.2(08383.062*kWh)
1-0:2.8.1(00000.000*kWh)
1-0:2.8.2(00000.000*kWh)
0-0:96.14.0(0001)
1-0:1.7.0(0000.53*kW)
1-0:2.7.0(0000.00*kW)
0-0:17.0.0(999*A)
0-0:96.3.10(1)
0-0:96.13.1()
0-0:96.13.0()
0-1:96.1.0(3238303131303038323033333632313132)
0-1:24.1.0(03)
0-1:24.3.0(150210000000)(00)(60)(1)(0-1:24.2.0)(m3)
(04293.080)
0-1:24.4.0(1)
so I know the cable is working... however in domoticz I only get 0 values for both my gas and electricity.
I added hardware
P1 Smart Meter USB Setup
(on the right USB port)
and activated the devices...
however all the returned values are 0.
I checked the json interface:
5MinuteHistoryDays: 1,
ActTime: 1423523747,
AllowWidgetOrdering: true,
DashboardType: 0,
Latitude: <COMMEnteD OUt>,
Longitude: <COMMEnteD OUt>,
MobileType: 0,
TempScale: 1,
TempSign: "C",
WindScale: 1,
WindSign: "m/s",
dontcachehtml: true,
result: [
BatteryLevel: 255,
Counter: "0.000",
CounterDeliv: "0.000",
CounterDelivToday: "0.000 kWh",
CounterToday: "0.000 kWh",
CustomImage: 0,
Data: "0;0;0;0;0;0",
Favorite: 0,
HardwareID: 5,
HardwareName: "Smartmeter",
HaveTimeout: false,
LastUpdate: "2015-02-10 00:15:45",
Name: "Smartmeter - Electro",
Notifications: "false",
PlanID: "0",
Protected: false,
SignalLevel: 12,
SubType: "Energy",
SwitchTypeVal: 0,
Timers: "false",
Type: "P1 Smart Meter",
TypeImg: "counter",
Unit: 1,
Usage: "0 Watt",
UsageDeliv: "0 Watt",
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "17"
status: "OK",
title: "Devices"
and
ActTime: 1423523841,
DashboardType: 0,
Latitude: "51.994260",
Longitude: "4.469550",
MobileType: 0,
TempScale: 1,
TempSign: "C",
WindScale: 1,
WindSign: "m/s",
result: [
BatteryLevel: 255,
Counter: "0.000",
CounterToday: "0.000 m3",
CustomImage: 0,
Data: "0",
Favorite: 0,
HardwareID: 5,
HaveTimeout: false,
LastUpdate: "2015-02-10 00:14:15",
Name: "Smartmeter - Gas",
PlanID: "0",
Protected: false,
SignalLevel: 12,
SubType: "Gas",
SwitchTypeVal: 1,
Timers: "false",
TypeImg: "counter",
Unit: 2,
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "18"
status: "OK",
title: "Devices"
Any help on how to troubleshoot this?
I could create my python script to call the json and create virtual devices.... but would be great if it worked out of the box :)
antwan
Domoticz version: Latest
Re: P1 meter results are not showing
Post by antwan »
Did you try to change the baudrate in hardware setup?
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
geoffrey
Post by geoffrey »
Yes I did... It should be the default 9600 but I also tried the larger value.
pwhooftman
Post by pwhooftman »
geoffrey wrote:Yes I did... It should be the default 9600 but I also tried the larger value.
Are you sure? Mine only works when i set baudrate 115200 in Dmomoticz
Domoticz v 1.16xx
1X RFXtrx433 USB 433.92MHz Transceiver Firmware version: 71
1X Synology Nas DS918+ DSM 7 (12Gb RAM mod)
geoffrey
Post by geoffrey »
unfortunately yes...
switching to 15200 gives me:
Tue Feb 10 23:10:30 2015 Error: Smartmeter hardware (5) nothing received for more then 1 Minute!....
Tue Feb 10 23:10:31 2015 Error: Restarting: Smartmeter
while switching to 9600 gives:
Tue Feb 10 23:12:09 2015 (Smartmeter) P1 Smart Meter (Electra)
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
Can you try to connect to the serial port with PuTTY?
It will show you the raw data of the P1 port. You should see the complete datagrams. If it is OK there, your hardware is fine.
If it shows gibberish or nothing than the problem is in your hardware setup.
You maybe have not correctly connected the RTS line to 5V.
I assume you followed click
geoffrey
Post by geoffrey »
Yeah the terminal shows the right results... As does the python script....
bbqkees
Post by bbqkees »
What system are you using it on? A Pi with the latest stable?
geoffrey
Post by geoffrey »
Yeah correct.... RPi with DomoticzV2.2025
bbqkees
Post by bbqkees »
And how did you make the cable?
If you use the correct hardware it should work out of the box in domoticz.
bbqkees
Post by bbqkees »
Maybe a stupid question: did you click on 'Allow hardware for 5 minutes" before adding the hardware?
CrashHouse
Domoticz version: V3.4834
Post by CrashHouse »
Found the solution? I'm experiencing exactly the same.
Although I had to set te permissions for ttyUSB0 first, but now 'sudo cu -l /dev/ttyUSB0 -s 9600 --parity=none' gives me the right information, just does't show in Domoticz.
Output:
Connected.
/XMX5XMXABCD100003654
0-0:96.1.1(4B383257303039373435393037343131)
1-0:1.8.1(08871.778*kWh)
1-0:1.8.2(07177.896*kWh)
1-0:2.8.1(02150.857*kWh)
1-0:2.8.2(05204.918*kWh)
0-0:96.14.0(0001)
1-0:1.7.0(0002.75*kW)
0-0:96.13.1()
0-0:96.13.0()
0-1:96.1.0(3238303131303038323333313532373132)
0-1:24.1.0(03)
0-1:24.3.0(160703100000)(08)(60)(1)(0-1:24.2.0)(m3)
(07056.183)
CrashHouse
Start at the beginning...
Well I made a cable as described at viewtopic.php?f=14&t=4970&hilit=p1+cable. After some fiddling I got the cable working in puTTY. After that I tried to install the cable on my Pi3. But after:
I got this message:
Line in use
Only after I changed permissions
sudo chmod 666 /dev/ttyUSB0
I got the output as mentioned earlier.
But after a reboot all is adjusted to the prior settings.
So I thought I would set the permissions persistent as described in http://ask.xmodulo.com/change-usb-devic ... linux.html so after a reboot Domoticz could see and connect the USB0 serial adapter.
Domoticz does see my P1 as hardware and I can add devices (Gas and Power) but values are stuck at 0.
If I run
on my Pi3 I get reading which is adjusting constantly.
So what am I doing wrong?
CrashHouse
Little update...
Just installed Domoticz on my spare Windows laptop and...
Cable works just fine in Domoticz. Perfect readings...
So why not on the Pi3?
