new installation Added "hardware" does not work
Rik60
- Domoticz version: 2026.3
Re: new installation Added "hardware" does not work
I am not sure that Domoticz is supporting the old Envoy type R. Maybe someone else knows this.
SmartEra35
Thanks for the update. Putting the token in the variable saves a credential; it does not by itself show whether Domoticz can reach this particular Envoy or whether the hardware setup uses it correctly. Could you open Domoticz's log just after a connection attempt and share the exact error text, with any token, serial number, public address and login removed? Also, which Domoticz version and Envoy firmware version are shown? Please don't paste the token itself.
Another reported Enphase connection issue in the Domoticz project shows that log messages can distinguish a token problem from an error fetching device information. I can't tell from that report whether it applies to your older Envoy R, so I would use the log to narrow down the next step rather than changing settings at random.
