Shelly support by Domoticz
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
BartSr
Domoticz version: V2024.7
Re: Shelly support by Domoticz
Post by BartSr »
For sure it will be me but what's going wrong? I scanned my shelly but cannot 'add' it.
Schermafbeelding 2026-11-26 183644.png (90.58 KiB) Viewed 155 times
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
I also can't see a mistake, provided, IP 192.168. 1.100 really exists with a supported Shelly device.
In the range for the scanner I see 192.168.2.xx , so maybe it is just a typo?
Which model is it? Is the problem also present, when you adopt an IP from the list of scanned devices?
Stop, look and listen.
BartSr
Post by BartSr »
Thanks for yr message. 192.168.1.100 is a default dz value
I tried by pressing button down-right resulting in 'problem adding node'
The shelly is known as shown at lower lines.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
gizmocuz
Post by gizmocuz »
@ BartSr, you can enable accept new hardware devices in settings
BartSr
Post by BartSr »
@Gizmocus
Would it make sense to show such a message iso generic: 'Problem adding node'?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
gizmocuz
Post by gizmocuz »
This has been improvedin the latest beta (hence my hint to use it :D)
When adding a Shelly fails because "Accept new Hardware Devices" is disabled, Domoticz now says so and explains how to enable it.
So update to beta 18658 or later and you should be good to go
