new installation Added "hardware" does not work
schipper
Re: new installation Added "hardware" does not work
@ Rik60
Thanks, I tried but then there is the box "Select System (Search with system name or Site ID) *"
1. Whatever I tried, nothing happens
2. What do you mean with "create" an api key ? How or what should that look or be ?
As I said before I'm just an old man (79) willing to learn but do not know anything about "api" other then in a zoo.
Why not make it easy ? Just say what I have to do.
Every time I see new unknown things and do not know what to do with it.
Does Domoticz has to be so difficult and only handy for the nitwits ? I don't think that it must be that difficult for the average user ?
schipper
@ RNEE Wednesday 18 November 2026 13:21
I searched for info about API (as you suggested).
Well sorry man but I am not a programmer and do not understand anything said in those documentation files. It says a lot but not "what to do".
Again I think that Domoticz is not ment to be only for nitwits and programmers.
If it's ment for the standard user who do not know anything about API's a.s.o. then it should be more easy to use or better documented so that a user knows what to do and most of all HOW to do it.
No offence of course but I am just an ordinary old user trying to get insight in the power consumption in my house and what my solar panels do (and don't)
Domoticz seemed to be a possibility for that aim. But so far I am desperate.
RNEE
- Domoticz version: 2026.4
Domoticz is not the problem, there are a lot of good tools available to integrate hardware.
Problem are the manufacturers of hardware, they don't develop connectors with opensource like Domoticz in mind.
Mostly only make connectors for there own apps.
Hobbyists have to build connectors to get data into Domoticz. Some connectors have to be build by reverse engineering websites etc.
When choosing Domoticz as your Home Automation system, you indeed need some basic understanding of how things work, that can not be changed.
About the api-key :
when data of hardware are on a website on the internet this website only supplies data to Domoticz when it is requested bij using a username / password and a secret api-key. The api-key is used in every request to the website.
About the api-key :
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|DTGbot|
Rik60
- Domoticz version: 2026.3
Do you have web access to your system? You should see something like:schipper wrote: Wednesday 18 November 2026 15:33 @ RNEE Wednesday 18 November 2026 13:21
download/file.php?mode=view&id=35509
If you don't have, ask the company that has installed the solar panels system
- Schermafbeelding 2026-11-18 154943.png (64.04 KiB) Viewed 287 times
schipper
@ Rik60
Now that's about what I would like to see and then in Domoticz of course.
So I tried to reproduce your command line that was partly blocked. That didn't work. What I finally got was the normal info I get from Enphase about how much was produced. No more. But I admit that my command line missed something you had in yours (what I can not see).
To get the production info from Enphase I can use username and password on their https://enlighten.enphaseenergy.com/systems/<and more>
I also asked Enphase support about that authentication screen in order to "create" an " acces token" because whatever I try to fill in, nothing goes. But it probably will take several days before getting an answer (as usual). I hope they also tell me HOW to "create" because I have no clue about what an "access token" is and what it looks like.
Then please continue in the other topic That you use windows is a bit different as all the instructions for Nefit Easy with Domoticz are written for Linux. The other topic gives you instructions what to use.schipper wrote: Wednesday 18 November 2026 1:08 I hope you don't mind but this Nefit Easy question was my topic (together with the solarpanels issue).
So I'll go on with it here. I fear that otherwise things will cross or will not be clear but confusing .
It does not mind that my topic is answered in my question, is it ?
So Waltervl about your answer:
I really don't know what you mean by
1. installing a Nefit Easy SERVER (what "server"? on what platform ? )
2. on a Domoticz SERVER (what is a Domoticz "server" and where do I find it ?
3. the line that you mentioned starting with "curl", what is it and what should I do with it ? I still remind you I'm using a Windows 10 laptop so I would not know what to do with that line and where to place it.
Sorry but I'm just an ols man and simple "user" and nothing more.I don't know what it means but I can learn. That's why I ask my questions here.
schipper
@ waltervl
Which other topic exactly do you mean ?
Can I solve the Nefit problem for Windows 10 following that topic ?
I would be happy
I would be happy
RNEE
Rik60
I have created a step by step document to get an access token, hopefully this will help youschipper wrote: Wednesday 18 November 2026 17:22 @ Rik60
- Enphase token.pdf
- (179.18 KiB) Downloaded 13 times
schipper
Thanks for your document.
But that does not answer my question.
I had found that already, but the question is:
1. What do you mean by "some name" ? Just anything ? or what ?
2. What do you mean by "location ID" What is it and what does it look like. Do you mean some random name ? geogaphical or a streetname or what ?
Rik60
Ok.
Open your Enphase web portal at: https://enlighten.enphaseenergy.com/
At the bottom you can find Your_Name (Schipper i think), next to it is the location id. So something like: Schipper (Location-id ???????)
I hope it is a bit clear now.
- Schermafbeelding 2026-11-18 154943.png (65.05 KiB) Viewed 137 times
schipper
OK thanks a little bit clear. But ....
My Enlighten does not look like yours but OK with some trial and error I found my location ID
So I filled that in the box in the entrez.enphaseenergy.com and that worked.
My location ID was found and I could select that.
BUT.....
Then the next box "get gateway" well whatever I do I can not get any digit in there It does not accept anything.
And so that's the next stop. I can't get farther....
It's a difficult process when every step forward als means 2 steps back
BUT.....
Rik60
Just another question, if you put your location-id, and don't press the enter key, wait 1 second, can you select then something like what is showed in the attached picure (Your_Name - Location-id)?
- Schermafbeelding 2026-11-19 191854.png (20.26 KiB) Viewed 99 times
schipper
The screen shown in your picture is what I mean. In the topbox I give the ID number and then I get an answer (name and ID number) I select that and then the lower box comes highlighted
But I cannot get any digit or whatever in there and there is no dropbox visible. So as I sai one step forward 2 steps back.
I'm starting to get mad.
Rik60
I think i am out of options. It is working for me, don't know why it isn't for you. Maybe someone else has an idea.
