Szelessav Light & Dark – Simple, clean Domoticz themes
szelessavmuhely
Post by szelessavmuhely »
Hello everyone,
We would like to share two Domoticz themes developed by **Szélessáv Műhely**, available in Light and Dark versions.
Our goal was to create a simple, clean and practical interface, especially for installations with a large number of devices and sensors.
The Machinon theme was also a source of inspiration during development, but we preferred a more angular, understated design with fewer decorative elements.
**Main features:**
- Light and Dark versions
- Compact dashboard with clearly separated device tiles
- Customized device icons and navigation elements
- Consistent presentation of switches, temperature sensors, weather data and utility meters
- Compatible with standard Domoticz installations
- Optional Szélessáv SmartHome branding
Both themes work independently of our SmartHome firmware and plugins. By default, they display the original Domoticz logo. When used with our firmware, an optional configuration switch enables Szélessáv branding and an additional website menu.
**Screenshots**
**Light Theme**
**Dark Theme**
**Installation**
1. Download the repository from GitHub.
2. Extract the archive.
3. Copy the `szelessav_light` and `szelessav_dark` folders into your Domoticz `www/styles/` directory.
4. Select your preferred theme in the Domoticz settings.
5. Save the settings and refresh your browser.
No additional plugins or server-side services are required.
**Compatibility**
Developed and tested with **Domoticz 2025.2**. Other versions may also work, but have not yet been fully tested.
**Download, source code and installation instructions:**
https://github.com/szelessavalapitvany/ ... sav-Themes
**Project website and additional screenshots:**
https://www.szelessavmuhely.hu/en/tools ... t_and_dark
The project is available under GPL-3.0, with separate licensing terms applying to some third-party components.
We welcome feedback, bug reports and suggestions for improvement, especially from users running other Domoticz versions.
Best regards,
Szélessáv Műhely
szelessavmuhely
Re: Szelessav Light & Dark – Simple, clean Domoticz themes
**Small update – Mobile navigation fix**
I've fixed an issue with the mobile navigation menu in both the Light and Dark themes.
The original sliding menu has been restored, including proper submenu handling on mobile devices.
The updated files are now available on GitHub:
If you've already downloaded the themes, please update to the latest version.
szelessavmuhely
Domoticz 2026.4 support
Both themes have been updated and are now compatible with Domoticz 2026.4.
The update includes dashboard and mobile layout improvements, while maintaining compatibility with Domoticz 2025.
The updated versions are available on GitHub. https://github.com/szelessavalapitvany/ ... sav-Themes
