Python Plugin: Volvo EV
FireWizard
Re: Python Plugin: Volvo EV
Post by FireWizard »
Hi @akamming,
Thanks for modifying your existing Volvo Recharge Plugin, authorize.py.
I can confirm, that it generates functional access and refresh tokens.
I used these successfully in my Node-RED application.
All endpoints can be fetched, as far as they are supported by the car.
I monitored also the Volvo back-end and made a condition, that, if the back-end fails, the polling
of the endpoints stops. This morning at approx 11:20 the polling stopped.
This has worked for a very long time, I think at least 2 years.
It wasn' caused by the tokens, but it indicated:
"**Inactive applications**\n\nCheck your account for applications marked as **Inactive**. If you have any, you must create a new application with a new Client ID and Client Secret before **31 January 2027**.\n\n[Read more about the Keycloak migration](https://developer.volvocars.com/news/volvoid-migration)."
If you go to the link in the message, you understand why.
I have no clue, what it means for the users, but as far as I can see, it will have only impact on those applications, that have been published in the Volvo Developer Portal. So users, that uses this application (and also other applications) can continue to do so. It means that Volvo is still working at their log-in and authentication procedures. What to expect more in the future.
For now, I see only one applications, marked as " inactive" 3 other are still there, but they are not published..
This is just for information.
Regards,
P.S. I will send you a PM
diekli
Post by diekli »
Hi, I've seen the same message on the Volvo website. Happy to help to make the Domoticz plugin to make the plugin work (again).
FireWizard
Hi @diekli ,
This will only happen after January 31st, 2027. So nobody should have any problem until then, but your application will stop after
that date. As far as I noticed it will only happen with a registered application. See the developer portal, if you have been logged-in.
The authorize.py file has been modified by akamming and is working fine.
I have modified that file on my turn in order to be able to read the email with the OTP from my email box automatically in case it needs renewal.
The whole monitoring and refreshment is handled by Node-RED
So, as far it is now, no work has to be done.
akamming
Post by akamming »
diekli wrote: Thursday 12 November 2026 14:56 Hi, I've seen the same message on the Volvo website. Happy to help to make the Domoticz plugin to make the plugin work (again).
currently plugin is already fixed again. However i am not using the plugin myself again, so if you like, feel free to take over the maintenance of the plugin.
Just create a fork and say you are official maintainer now, let me know the location and i will create a message in the plugin and the repository that you have taken over...
FlyingDomotic
Post by FlyingDomotic »
As said, end of Jan, oAuth2 with PKCE will be mandatory. This means that yo have to have a web site in order to get the code and use it to get an access code and a refresh token to provide access to VOC.
I don't use the Volvo plug-in, but a Python code that writes directly to MQTT (and MqttMapper to read it).
I received a warning from Volvo, and rewrite login procedure, still in Python. The only issue is to have somewhere a Web site to reroute message send by Volvo. Note that using a web browser is mandatory (unless you try to emulate user input with some library like Selenium).
I may share parts of code if needed.
Don't forget to tick "Keep me logged" in order to change token expiration from few hours to few months.
FYI, I'm changing my Volvo by another car provider early next year, I won't be able to help in few months.
akamming
Post by akamming »
Yeah that ‘s my conclusion as well. I’ve asked GitHub Copilot to change the code using the restraints I have. I starting building a very complex solution (basicslly a docker container with a small website to do the authentication proces with a separate website)
It didn’t work and it Will be a lot of work to make it work. (And I am not using the Plugin myself animore since i switched to home Assistant)
So that Will be the end of this Plugin unless someone takes over and still then you would need a change in domoticz plug-in framework itself: a handler that you can use for an oauth pkce, so you can handle the callback
