Shelly support by Domoticz
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
FlyingDomotic
Re: Shelly support by Domoticz
Post by FlyingDomotic »
Some people here did manage connecting Shellies to Domoticz through MqttMapper plug-in.
You may find examples in this forum, looking for MqttMapper.
I may also help ;-)
Domoticz version: 2026.3
FlyingDomotic wrote: Friday 07 November 2025 10:50 Some people here did manage connecting Shellies to Domoticz through MqttMapper plug-in.
I may also help ;-)
Perhaps someone can gather all shelly MQTTMapper configs and put it in a topic or github repository.
FlyingDomotic
Some examples :
oli80330 wrote: Saturday 25 October 2025 2:33 Json for sdhelly 2.5 roller works fine.
several JSON examples for shelly (1/2.5/EM Gen1) :
1 - For a Shelly 1 (GEN1) / domoticz device on/off :
"SDB Ventil": {
"topic": "shellies/SDB Ventil/relay/0",
"type": "244", "subtype": "73",
"switchtype": "0",
"mapping": {"item": "", "default": "0", "values": { "off": "0", "on": "100", "false": "0", "true": "100" }},
"commands": {
"On": {"topic": "shellies/SDB Ventil/relay/0/command", "payload": "on"},
"Off": {"topic": "shellies/SDB Ventil/relay/0/command", "payload": "off"}
2- For a Shelly 2.5 mode relay (not roller mode) (GEN1) / domoticz on/off :
"CE Mode PAC": {
"topic": "shellies/CE Thermo Solaire/relay/0",
"switchtype": "0",
"commands": {
"On": {"topic": "shellies/CE Thermo Solaire/relay/0", "payload": "on"},
"Off": {"topic": "shellies/CE Thermo Solaire/relay/0", "payload": "off"}
3 -For a Shelly 2.5 mode roller (not relay mode) (GEN1) / domoticz blinds on/off/stop/position :
"ShellyMapper - Buro Volet": {
"topic": "shellies/Buro Volet/roller/0/pos",
"type": "244",
"subtype": "73",
"switchtype": "21",
"mapping": {"item": ""},
"commands": {
"Open": { "topic": "shellies/Buro Volet/roller/0/command", "payload": "open" },
"Close": { "topic": "shellies/Buro Volet/roller/0/command", "payload": "close" },
"Stop": { "topic": "shellies/Buro Volet/roller/0/command", "payload": "stop" },
"Set Level": { "topic": "shellies/Buro Volet/roller/0/command/pos", "payload": "<level>", "retain": false }
4 - For a Shelly EM or Shelly 2.5 (Gen1 conso) / domoticz General, kWh :
"Clim Salon": {
"topic": "shellies/Clim Salon/relay/0/power",
"type": "243", "subtype": "29", "switchtype": "0",
"options": {"EnergyMeterMode":"0"},
"mapping": {"item":"~*;~0"}
Thank you very much for your plugin, very fast for feedback in MQTT !
The CPU consumption of the RPi is very low.
A good plugin for shelly device, better than shellyteacher or AutoDiscovery, very slow in feedback.
Murasaki
Post by Murasaki »
This is a configuration for reading Shelly Plus 4i inputs (Firmware version: i4prod0)
"Input 1": {
"topic": "shellies/shellyplusi4-xxxxxxxx/status/input:0",
"type": "244",
"subtype": "73",
"switchtype": "9",
"mapping": {"item":"state", "values": {"True": "On", "False": "Off"}
Just change <input:0> to 1,2 or 3 depending on input to read
Just in case, it can help to somebody.
Itschi
Post by Itschi »
The most elegant way to integrate Shelly devices in Domoticz from my perspective is to make use of their integrated scripting function. Just add the respective dummy devices in Domoticz and a script in the Shelly device to call the Domoticz JSON interface. For a Plug S this looks like:
// Send Plug's Status & Power to Domoticz
let CONFIG = {
  outputId: 0,
  httpServer: 'http://1.8.1.1:8080', //Domoticz Server IP
  httpState: '/json.htm?type=command&param=switchlight&idx=6536&switchcmd=', // Domoticz Dummy Switch
  httpPower: '/json.htm?type=command&param=udevice&idx=6535&nvalue=0&svalue='  // Domoticz Dummy Power Device
function notifyState(OnOff) {
  Shelly.call(
    'HTTP.GET',
    {url:CONFIG.httpServer+CONFIG.httpState+OnOff}
function notifyPower(Power, Energy) {
  Shelly.call(
    'HTTP.GET',
    {url:CONFIG.httpServer+CONFIG.httpPower+Power+';'+Energy}
let outputStringId = "switch:" + JSON.stringify(CONFIG.outputId);
print(outputStringId);
Shelly.addStatusHandler(function (statusNtf) {
  if (statusNtf.component !== outputStringId) return;
  let sysStatus = Shelly.getComponentStatus('Switch:0')
  if (sysStatus.output === true) notifyState('On');
  else notifyState('Off');
  notifyPower(sysStatus.apower, sysStatus.aenergy.total)
  print(sysStatus.apower)
  print(sysStatus.aenergy.total)
Finally you add in the Domoticz switch the on and off actions where 1.8.1.17 is the Shelly IP in this example:
"http://1.8.1.17/relay/0?turn=on"
"http://1.8.1.17/relay/0?turn=off"
That's it. Now you can control and monitor the plug from any endpoint (Domoticz, Shelly-App and even from the device switch).
andrehj
Domoticz version: 2026.4
Post by andrehj »
Thanks @Itschi,
That looks very promising. I'm very new to Shelly's, and have a Shelly Pro 3 (with 3 output relays, no energy metering and I don't use the three inputs).
Removing the energy- and power-part is simple, but I'm struggling to expand your script to three outputs.
What would your script look like with 3 outputs (0, 1 and 2)?
alanf
Post by alanf »
Thanks for the code example @Itschi,
I bought a couple of Shelly door/window BLU sensors, mostly because they look far less clunky than most alternatives and I have a few earlier generation Shelly switches that have proved reliable over a few years (using the https://github.com/enesbcs/Shelly_MQTT plugin). I'm using a Shelly1 Gen4 switch as a gateway I can place near the doors, well within bluetooth range. One of the first tasks was to start by updating the firmware on the switches and the sensors. Some of the earlier firmware on devices "out of the box" don't have the menu options or messages described in the Shelly website documentation.
Simplest way I found to operate was to manually create a new dummy switch on Domoticz of type "door contact" and use two "Action" entries (opened and closed) on the paired Shelly switch to control the Domoticz switch. If anyone wants to try that:
First create the dummy Domoticz door contact switch (note the idx). Then pair the Shelly BLU device as a component from the Shelly1gen4 admin page; as per the Shelly guide (https://kb.shelly.cloud/knowledge-base/ ... art-blueto). The new component was renamed "Front Door sensor" to make it easier to find, the window[0] as the supported sensor could be renamed but as the only sensor of that type on the component I didn't bother.
From there it's a few menu choices to create two new "Action"s (aka webhooks?) using that "Front Door sensor - window[0]". One called "Front Door Opened" has a trigger of "State change", an additional condition of "New state is open" and a URL to execute of
http://<Domoticz IPaddress>:<port>/json.htm?type=command&param=switchlight&idx=<door contact idx>&switchcmd=On
(Your <Domoticz IPaddress>:<port> address is likely to be something like 192.168.1.10:8080, the <door contact idx> the idx of the switch I created is 136).
The reverse "Front Door Closed" action uses "New state is closed" and "switchcmd=Off".
Seems to work well for a basic on/off type sensor; a Domoticz switch with the appropriate door icons that reflects the open/closed state of the door and can be included in scripts and so on. I can see some case for using MQTT, but against that would be adding extra complexity and another failure point. I was thinking of the simplest way I can use the built in "Battery[0]" and "llluminance[0]" sensors. Your script example might be the easiest way to trigger conditions such as "low battery" and "low light".
angelo67
Post by angelo67 »
Itschi wrote: Monday 17 November 2025 17:06 The most elegant way to integrate Shelly devices in Domoticz from my perspective is to make use of their integrated scripting function. Just add the respective dummy devices in Domoticz and a script in the Shelly device to call the Domoticz JSON interface. For a Plug S this looks like:
let CONFIG = {
  outputId: 0,
  Shelly.call(
    'HTTP.GET',
  Shelly.call(
    'HTTP.GET',
Returning to this post by "Itschi,"
in the script to be written on the shellyplug, you need to change the IP of the domoticz server and in the two rows below you need to enter the "IDX" of the switch previously created as a virtual switch on a dummy hardware.
Is there anything else to change?
I tried, but the shellyplug status isn't changed on the domoticz page.
Angelo67
JanAV
Post by JanAV »
i have a shell mini gen 3 working with shelly script, put this script in the shelly and make a dummy power sensor
let DOMOTICZ_IP = "192.168.2.2";
let DOMOTICZ_PORT = "8080";
let IDX = 38;
function sendEnergy() {
  let pm = Shelly.getComponentStatus("pm1:0");
  if (!pm || !pm.aenergy) {
    print("Energy data not ready");
    return;
  let power = pm.apower;                       // Watts
  let energy_kwh = pm.aenergy.total / 1000;    // Wh → kWh
  let url = "http://" + DOMOTICZ_IP + ":" + DOMOTICZ_PORT +
            "/json.htm?type=command&param=udevice" +
            "&idx=" + IDX +
            "&nvalue=0&svalue=" + power + ";" + energy_kwh;
  print("Sending:", power, "W,", energy_kwh, "kWh");
  Shelly.call("HTTP.GET", { url: url }, function (res, err_code, err_msg) {
    if (err_code !== 0) {
      print("HTTP error:", err_msg);
    } else {
      print("OK");
// every 30 seconds
Timer.set(30000, true, sendEnergy);
imautohuttraeger
Domoticz version: lat.beta
Post by imautohuttraeger »
I wonder if there is any kind of collection of Shelly scripts for available. I am still using Gen. 1 and 2 devices and don't need it for these. But for Gen. 3 devices it is necessary
Stop, look and listen.
jorknu
Post by jorknu »
Not sure this is helpful, but here are my 2 cents:
Recently added a Shelly EM mini gen4 (this one via zigbee) and Shelly EM3 pro gen3 (via manually creating AD topics) via MQTT AD
Google AI provided me with the following json template:
  "name": "Shelly Fase A Actief Vermogen",
  "unique_id": "shelly_<id>_a_act_power",
  "state_topic": "shelly<id>/status/em:0",
  "value_template": "{{ value_json.a_act_power }}",
  "device_class": "power",
  "state_class": "measurement",
  "unit_of_measurement": "W",
  "device": {
    "identifiers": ["shelly_<id>"],
    "name": "Shelly Pro 3EM",
    "model": "Pro 3EM",
    "manufacturer": "Shelly"
And link to publish it to (don't forget to use the retain flag!):
homeassistant/sensor/shelly<id>/a_act_power/config
(Obviously MQTT must be enabled in the shelly)
This can be filled in for every sensor that you want and then be deployed to your broker from any PC able to reach your broker.
For our GUI users: MQTT explorer can be used
For our linux techies: mosquitto_pub (from mosquitto-clients package) can load this struct from
I am thinking of creating a shell script (linux only) to deploy sensors this way (in case I ever get more shellies and for the reproduceability of my current setup. If its useful, I will post a link here once I have something that is 'workable'
imautohuttraeger
jorknu wrote: Wednesday 02 September 2026 21:57 I will post a link here once I have something that is 'workable'
That would be highly appreciated by me!
lemassykoi
Domoticz version: 2025.1
Post by lemassykoi »
imautohuttraeger wrote: Wednesday 05 November 2025 13:30 Super! Will test it maybe next week and give feedback if it works.
did you test it?
imautohuttraeger
lemassykoi wrote: Thursday 03 September 2026 19:04
did you test it?
Unfortunately not. I was quite busy after that post and I have to admit that I forgot it.
JanAV
Post by JanAV »
i made a hardware plugin for measuring power
save this file as plugin.py in a folder named shell under plugins, restart domoticz and the plugin should be visible in hardware
# SHELLY
# Description: Shelly Gen2 / Gen3 power meter. Reads power, voltage, current,
#              energy and temperature over the local HTTP RPC API.
#              Supports Switch.GetStatus (1PM, Plus 1PM, 1PM Mini Gen3, ...)
#              and PM1.GetStatus (Plus PM Mini, PM Mini Gen3, ...).
# History:
# 1.0.0   Initial version
# 1.0.1   Use urllib for the request (Domoticz HTTP protocol returned an empty body)
# 1.1.0   Added "Shelly type" option: Switch, PM1 or Auto-detect
<plugin key="Shelly_PM" name="Shelly power meter (Gen2 / Gen3)" author="" version="1.1.0" externallink="https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/Switch">
  <description>
    <h2>Shelly power meter (Gen2 / Gen3)</h2><br/>
    Reads the live values of a Shelly with power measurement through the local API:
    <i>/rpc/Switch.GetStatus?id=0</i> (1PM, Plus 1PM, 1PM Mini Gen3, ...) or
    <i>/rpc/PM1.GetStatus?id=0</i> (Plus PM Mini, PM Mini Gen3, ...).<br/><br/>
    Creates the devices: Power + energy (kWh), Voltage, Current and Temperature
    (temperature only if the Shelly reports it, PM1 models do not).<br/>
    Authentication on the Shelly is not supported, so leave it switched off.
  </description>
  <params>
    <param field="Address" label="IP Address" width="200px" required="true" default="192.168.2.0"/>
    <param field="Port" label="Port" width="40px" required="true" default="80"/>
    <param field="Mode1" label="Switch / channel id" width="40px" required="true" default="0"/>
    <param field="Mode2" label="Shelly type" width="200px">
      <options>
        <option label="Auto-detect" value="auto" default="true"/>
        <option label="Switch (1PM, Plus 1PM, ...)" value="switch"/>
        <option label="PM1 (Plus PM Mini, PM Mini Gen3, ...)" value="pm1"/>
      </options>
    </param>
    <param field="Mode3" label="Poll interval" width="100px">
      <options>
        <option label="10 seconds" value="10"/>
        <option label="20 seconds" value="20"/>
        <option label="30 seconds" value="30" default="true"/>
        <option label="60 seconds" value="60"/>
      </options>
    </param>
    <param field="Mode4" label="Show values as positive" width="100px">
      <options>
        <option label="Yes" value="1" default="true"/>
        <option label="No" value="0"/>
      </options>
    </param>
    <param field="Mode6" label="Debug" width="100px">
      <options>
        <option label="Off" value="0" default="true"/>
        <option label="On" value="1"/>
      </options>
    </param>
  </params>
</plugin>
import Domoticz
import json
import urllib.request
# Device units
UNIT_POWER = 1        # power (W) + energy counter (Wh)
UNIT_VOLTAGE = 2      # V
UNIT_CURRENT = 3      # A
UNIT_TEMP = 4         # degrees C
REQUEST_TIMEOUT = 5   # seconds
# RPC methods per Shelly type
METHODS = {
  "switch": "Switch.GetStatus",
  "pm1": "PM1.GetStatus",
class BasePlugin:
  switchId = 0
  shellyType = "auto"        # auto / switch / pm1
  detected = None            # RPC method that worked (auto-detect)
  absolute = True            # show negative values as positive
  pollTicks = 3              # heartbeat is 10 s, so 3 ticks = 30 s
  ticks = 0
  errorReported = False
  def onStart(self):
    if Parameters["Mode6"] == "1":
      Domoticz.Debugging(1)
    self.absolute = (Parameters["Mode4"] == "1")
    self.shellyType = Parameters["Mode2"] if Parameters["Mode2"] in ("auto", "switch", "pm1") else "auto"
    self.detected = None
    try:
      self.switchId = int(Parameters["Mode1"])
    except ValueError:
      Domoticz.Error("Switch id '" + Parameters["Mode1"] + "' is not an integer, using 0")
      self.switchId = 0
    try:
      interval = int(Parameters["Mode3"])
    except ValueError:
      interval = 30
    self.pollTicks = max(1, interval // 10)
    Domoticz.Heartbeat(10)
    self.ticks = self.pollTicks          # poll at the first heartbeat
    self.createDevices()
  def onStop(self):
    Domoticz.Debug("onStop called")
  def onConnect(self, Connection, Status, Description):
    pass
  def onMessage(self, Connection, Data):
    pass
  def onCommand(self, Unit, Command, Level, Hue):
    Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": " + str(Command))
  def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
    pass
  def onDisconnect(self, Connection):
    pass
  def onHeartbeat(self):
    self.ticks += 1
    if self.ticks < self.pollTicks:
      return
    self.ticks = 0
    self.poll()
####################### Plugin specific functions #######################
  def createDevices(self):
    if UNIT_POWER not in Devices:
      Domoticz.Device(Name="Power", Unit=UNIT_POWER, Type=243, Subtype=29, Switchtype=4, Used=1).Create()
    if UNIT_VOLTAGE not in Devices:
      Domoticz.Device(Name="Voltage", Unit=UNIT_VOLTAGE, Type=243, Subtype=8, Used=1).Create()
    if UNIT_CURRENT not in Devices:
      Domoticz.Device(Name="Current", Unit=UNIT_CURRENT, Type=243, Subtype=23, Used=1).Create()
    if UNIT_TEMP not in Devices:
      Domoticz.Device(Name="Temperature", Unit=UNIT_TEMP, Type=80, Subtype=5, Used=1).Create()
  def methodsToTry(self):
    if self.shellyType in METHODS:
      return [METHODS[self.shellyType]]
    # auto-detect: reuse the method that worked, otherwise try both
    if self.detected:
      return [self.detected]
    return [METHODS["switch"], METHODS["pm1"]]
  def fetch(self, url):
    Domoticz.Debug("GET " + url)
    with urllib.request.urlopen(url, timeout=REQUEST_TIMEOUT) as response:
      raw = response.read().decode("utf-8", "ignore")
    Domoticz.Debug("Shelly reply: " + raw)
    start = raw.find("{")
    if start < 0:
      raise ValueError("no JSON in reply: '" + raw[:80] + "'")
    return json.loads(raw[start:])
  def poll(self):
    errors = []
    for method in self.methodsToTry():
      url = "http://%s:%s/rpc/%s?id=%d" % (Parameters["Address"], Parameters["Port"], method, self.switchId)
      try:
        status = self.fetch(url)
      except Exception as e:
        errors.append(url + ": " + str(e))
        continue
      if self.shellyType == "auto" and self.detected != method:
        self.detected = method
        Domoticz.Log("Shelly type detected, using " + method)
      self.errorReported = False
      self.updateFromStatus(status)
      return
    # Every method failed; forget the detected one so auto-detect retries both
    if self.shellyType == "auto":
    self.fail("Could not read the Shelly: " + " | ".join(errors))
  def fail(self, message):
    # Report and mark the devices only once per outage
    if self.errorReported:
      return
    self.errorReported = True
    Domoticz.Error(message)
    for unit in Devices:
      Devices[unit].Update(nValue=Devices[unit].nValue, sValue=Devices[unit].sValue, TimedOut=1)
  def updateFromStatus(self, st):
    power = self.number(st.get("apower"))
    voltage = self.number(st.get("voltage"))
    current = self.number(st.get("current"))
    if self.absolute:
      power = abs(power)
      current = abs(current)
    # Energy counter in Wh. When absolute values are wanted, the returned
    # energy (negative direction) is added to the forward energy.
    energy = 0.0
    aenergy = st.get("aenergy")
    if isinstance(aenergy, dict) and aenergy.get("total") is not None:
      energy = self.number(aenergy.get("total"))
    if self.absolute:
      ret = st.get("ret_aenergy")
      if isinstance(ret, dict) and ret.get("total") is not None:
        energy += self.number(ret.get("total"))
    self.updateDevice(UNIT_POWER, "%.1f;%.2f" % (power, energy))
    self.updateDevice(UNIT_VOLTAGE, "%.1f" % voltage)
    self.updateDevice(UNIT_CURRENT, "%.3f" % current)
    # Only Switch models report a temperature; PM1 does not
    temperature = st.get("temperature")
    if isinstance(temperature, dict) and temperature.get("tC") is not None:
      self.updateDevice(UNIT_TEMP, "%.1f" % self.number(temperature.get("tC")))
  def number(self, value):
    try:
      return float(value)
    except (TypeError, ValueError):
      return 0.0
  def updateDevice(self, unit, sValue):
    if unit in Devices:
      Devices[unit].Update(nValue=0, sValue=sValue, TimedOut=0)
####################### Global functions for plugin #######################
global _plugin
_plugin = BasePlugin()
def onStart():
  global _plugin
  _plugin.onStart()
def onStop():
  global _plugin
  _plugin.onStop()
def onConnect(Connection, Status, Description):
  global _plugin
  _plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
  global _plugin
  _plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
  global _plugin
  _plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
  global _plugin
  _plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
  global _plugin
  _plugin.onDisconnect(Connection)
def onHeartbeat():
  global _plugin
  _plugin.onHeartbeat()
gizmocuz
Post by gizmocuz »
Domoticz (latest beta versions) is fully compatible with all shelly's that support MQTT-AD
