🌙 Nightglass Theme (WIP)
gizmocuz
Re: 🌙 Nightglass Theme (WIP)
Post by gizmocuz »
Releases are always sticky for a few weeks, so you should have seen it
viewtopic.php?t=45227
galadril
Domoticz version: latest
Post by galadril »
Thanks for all the nice words.. i recently continued with some more new features.
- Doctor/Health > See setting
- Attention Center
https://github.com/user-attachments/ass ... 9d8ebf96ac
https://github.com/user-attachments/ass ... 13833f1ece
https://github.com/user-attachments/ass ... c85bbf5780
if you see bugs or anything, please use Github (see first post)
Thanks for the others to keep an eye out on this forum :D
galadril
Post by galadril »
Btw offtopic, but still like to share it here. New project coming up dzPanel:
viewtopic.php?t=45322
imautohuttraeger
Post by imautohuttraeger »
With Nightglass, you can define animated icons. E.g. a fan-icon is spinning when the device is on. Looking at such a device in the normal switches tab, the animation is visible instantly. But on the dynamic dashboard, you have to reload the page to see the animation.
Before I open an issue: Must this be solved in Domoticz generally or if it is something, that an updated Nightglass theme must solve?
Stop, look and listen.
galadril
Post by galadril »
imautohuttraeger wrote: Tuesday 10 November 2026 11:07 With Nightglass, you can define animated icons. E.g. a fan-icon is spinning when the device is on. Looking at such a device in the normal switches tab, the animation is visible instantly. But on the dynamic dashboard, you have to reload the page to see the animation.
This sounds like a theme issue ;)
Plz make a issue indeed
Gravityz
Domoticz version: 2026.3
Post by Gravityz »
i tested this but on my side it is working as expected.
switch off:fan icon is greyed out and not rotating
switch on:icon is blue and fan is rotating.
i had similar problems a while back and could not figure out what the problem was
then all of a sudden everything started working.
i am using chrome browser
domoticz 2026.3.18326
nightglass version almost the latest (the one before adding and removing the custom widget thing)
if i remember right i went into nightglass setting and started to disable options and after that enabling them again.
maybe you should try this, switch them off(especially the animate device icons) and enable the again.
after that save your settings.
imautohuttraeger
Gravityz wrote: Wednesday 11 November 2026 14:04 went into nightglass setting and started to disable options and after that enabling them again.
Switched animated icons off and saved it. Switched it on again an saved it. But the animation stell ist only visible after page reload. Using latest domoticz beta and latest nightglass.
But I now recognized, that it is not limited to the dynamic dashboard. It is also only available on reload on the switches tab.
Last edited by imautohuttraeger on Wednesday 11 November 2026 19:29, edited 1 time in total.
imautohuttraeger
galadril wrote: Tuesday 10 November 2026 22:28 This sounds like a theme issue ;)
done.
