before i put in a request on github.
is it possible to make the widgets smaller so we can fit more widgets on 1 screen?
I (and others) have lot's of sensors like standard on/off switches or temperature sensors which do not need a lot of room.
making them square would mean you can fit 2 next 2 each other as compared to the current minimum width
should be rreal easy to implement because at the moment you can resize them but they have a minimal size. lowering the minimal size by a factor of 2 would fix it.(and yes you could end up with unreadable widgets because they need more room but that is already the case with sensors which have a long name.
i would exclude dimmers and selector switches for the obvious reasons
somehow the option to upload files is disabled so i can not show what i mean
Dynamic Dashboards and easier theming
Moderator: remb0
- imautohuttraeger
- Domoticz version: latest
Re: Dynamic Dashboards and easier theming
I remember there is / was a GitHub feature request already, but I can't find it
Edit: Found it: It was you
, but for Nightglass theme.
https://github.com/galadril/Domoticz-Ni ... issues/287
Stop, look and listen.
Gravityz
- Domoticz version: 2026.3
Yes indeed and nightglass developer told me this is a domoticz thing.
So some domoticz improvement are inherited by nightglass
apparently this is one of the basic features (widget size)
hopefully they will implement this
imautohuttraeger wrote: Wednesday 04 November 2026 20:24 I remember there is / was a GitHub feature request already, but I can't find it
Edit: Found it: It was you, but for Nightglass theme.
