OpenWebNet developing..?
draghip
Domoticz version: 2025.2
Re: OpenWebNet developing..?
Post by draghip »
Hi @spugna85,
thanks for looking into both issues!
F522 energy counters: I meant handling a counter reset correctly when it occurs, not sending a command from Domoticz to physically reset the device counters.
My preference would be to keep the total in Domoticz cumulative, preserving continuity in the consumption history without negative values or artificial spikes after a reset.
KW4691 setpoints: A global gateway setting would be sufficient for my installation: all four thermostats are KW4691, so I do not need per-thermostat configuration.
An optional dimension 7 mode, keeping the existing method as the default for compatibility with older installations, sounds good.
For completeness, my successful dimension 7 test was in heating/manual mode on zone 6, confirmed by both readback and the physical thermostat display. Cooling and automatic modes remain untested.
Thanks again for your help!
