hello all.
I am running domoticz 2025-2 on two RPI's and everything is working pretty stable.
So it's time to make it more fancy/clearly starting with custom icons.
This mainly due to the amount of switches (currently about 210)
Most of the In and outputs are via MQTT and a boatload of ESP modules.
Domoticz Icon Generator was a big help and the first few custom icons are indeed showing on (settings,custom icons )page.
see attm.
But on the switch itself not.
I have tried to find if somebody has mentioned this before on the forum but could not find any similar problem.
custom icons not showing correctly
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
goblin
- Domoticz version: 2023.1
- green_spot.png (27.46 KiB) Viewed 791 times
- green_spot custom icons.png (14.86 KiB) Viewed 791 times
- gizmocuz
Re: custom icons not showing correctly
Is this still the case on the latest stable or beta? 2025.2 is quite old by now. If it still happens, please open an issue on GitHub (https://github.com/domoticz/domoticz/issues) with the icon zip you uploaded and a screenshot of the switch, then we can check it.
