Version: v2026.2
Platform: Windows 11 (Domoticz server and browser web GUI)
Plugin/Hardware: PC, x64, multiple machines
Description:
I noticed that especially web GUI (https) starts and also usage later is very slow when using Firefox v152.0.6 with previously registered service worker, meaning 2nd and subsequent starts. Chrome does not seem to suffer from this problem.
Here is example how to 100% reproduce the problem:
1. first url access in Domoticz url in Firefox is immediate, only few ms
2. 2nd and all subsequent url access takes around 6 seconds
3. when only service worker is unregistered (F12 options), then 1st run is again immediate, while 2nd and subsequent are slow again
Slowness is actually not limited to first url access, but also later in navigation - although difference is much smaller, not nearly as big as 6 second for start. Due to to described problem i strongly believe problem is in the service worker - either code itself or some sort of compatibility problems with problems related to Firefox alone. It could also be code problem, but Chrome somehow tolerates it, who knows.
Problems seems to appear only for HTTPS, not HTTP. HTTPS is using self signed certificates, while self signed CA is added to Windows certificate store, so connection is shown as trusted.
Slow web GUI in Firefox
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- gizmocuz
Re: Slow web GUI in Firefox
The service worker only caches the static files; the pages are fetched from the network first. A delay of around 6 seconds only over https with a self-signed certificate in Firefox points at Firefox not trusting that certificate inside the service worker (Firefox does not use the Windows certificate store for that unless security.enterprise_roots.enabled is on), so each request waits for a timeout. Could you check whether setting security.enterprise_roots.enabled to true in about:config helps? If not, please open an issue on GitHub (https://github.com/domoticz/domoticz/issues) with the Network tab timings (F12) of a slow load.
