WSDCGQ11LM shows as 2 device in 2026.3
njlammerts
Domoticz version: 2022.2
Post by njlammerts »
in domoticz 2025.1 I have 10+ WSDCGQ11LM sensors showing about 7 sensors `(temp, humidity, pressure, batt level, voltage etc) every item with own IDX. I use Zigbee2MQTT Plugin (v. 3.2.0-beta) on RPI 4
Scherm­afbeelding 2026-08-10 om 17.14.01.png (296.61 KiB) Viewed 603 times
In domoticz 2026.1 it is shown as 2 devices, 1 "weather station" device and 1 combined temp/pressure/humidity device. I only need temperature and batt level. When submitting them to dashboard, I get both devices on dashboard, when removing weather/pressure, the temp also disappears
I use MQTT auto discovery Client gateway with LAN interface
Scherm­afbeelding 2026-08-10 om 17.11.06.png (300.37 KiB) Viewed 603 times
how do I get (only) temp and percentage/voltage in domoticz as 2 or 3 separate sensors?
gizmocuz
Re: WSDCGQ11LM shows as 2 device in 2026.3
Post by gizmocuz »
MQTT Auto Discovery now combines the temperature, humidity and pressure of one sensor into a single Temp + Humidity + Baro device (the "Weather Station" subtype), with the battery level in that device. Removing it removes the temperature too, because it is the same device. Separate temperature, humidity and pressure devices from an older version can stay in your list but no longer get updates, you can remove those. In a dzVents script you can still read only the temperature of the combined device (device.temperature).
If you still get two updating devices for one sensor on the latest beta, please open an issue on GitHub (https://github.com/domoticz/domoticz/issues) with a screenshot of both devices and the discovery config of the sensor.
