Problem in notifications tab for device
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Dave21w
Domoticz version: Stable
Post by Dave21w »
After setting a notification to be sent via prowl when i return to the notifications it is then missing but the notification is still working, refreshing the page multiple times sometimes get them to reappear. I have tried this on 3 different browsers and 2 different machines, the other machine had never been used to access Domoticz before so not a cache issue.
I should probably add I'm using a pi5 with latest O/S and updates and Domoticz 2026.3 beta build 18266.
gizmocuz
Re: Problem in notifications tab for device
Post by gizmocuz »
Does this still happen on the latest beta? A lot has changed since build 18266, and I could not find a cause in the current code: the notifications are read from the same list that is used to send them, and that list is reloaded after every save.
If it still happens, please open an issue on GitHub (https://github.com/domoticz/domoticz/issues) with the build number, the device type, a screenshot of the empty Notifications tab, and any errors from the browser console (press F12, Console tab) while the tab is opened. Then we can follow it up there.
