Log flooding messages v2026.3 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
BarryT
Domoticz version: 2024.3
Post by BarryT »
As the title says, our Domoticz log is being flooded approximately every 2/3/4/5 minutes with messages we have never seen before.
We upgraded Domoticz to the latest stable version last week. Since that upgrade, the following messages have started appearing:
2026-08-04 16:49:30.493 Status: 192.168.1.91 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
The client IP address may vary, but the message is always the same.
What exactly does this message mean? Is this caused by a WebSocket connection, browser session, or something else?
More importantly, how can we fix the underlying problem or disable these repeated log messages?
Thanks.
Domoticz version: 2026.3
Re: Log flooding messages v2026.3 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Is there something related to those mentioned clients connected to Domoticz? Do they run scripts outside Domoticz?
BarryT
Post by BarryT »
waltervl wrote: Tuesday 04 August 2026 20:03 Is there something related to those mentioned clients connected to Domoticz? Do they run scripts outside Domoticz?
No, there are no scripts outside Domoticz, as far as i know..
Just users who opening the Domoticz interface in their browser on laptop/pc or phones..
eddieb
Post by eddieb »
I get these messages too, latest beta ...
2026-08-05 08:02:18.983  Status: ::ffff:192.168.0.220 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
FunFair
Post by FunFair »
same here, since updating to stable.
Messages are appearing while the browser is already closed.
I was running the beta from 2 weeks ago without any of these messages.
Arjan2019
Post by Arjan2019 »
Same over here
Beta: 18195 atm
Line 37540: 2026-08-02 20:53:04.302 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37572: 2026-08-02 21:04:09.652 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37573: 2026-08-02 21:04:09.653 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37574: 2026-08-02 21:16:01.866 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37575: 2026-08-02 21:16:46.679 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37576: 2026-08-02 21:16:49.099 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37577: 2026-08-02 21:29:55.221 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37578: 2026-08-02 21:31:17.559 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37604: 2026-08-02 23:40:15.309 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37605: 2026-08-02 23:40:17.571 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37639: 2026-08-03 00:04:27.539 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37640: 2026-08-03 00:04:29.181 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37696: 2026-08-03 07:58:20.205 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37750: 2026-08-03 10:58:20.046 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37775: 2026-08-03 15:09:54.787 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37802: 2026-08-03 15:25:44.140 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37803: 2026-08-03 15:29:14.625 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37804: 2026-08-03 15:30:00.915 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37813: 2026-08-03 16:13:14.823 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37814: 2026-08-03 16:13:15.011 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37815: 2026-08-03 16:13:15.026 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 37818: 2026-08-03 17:03:00.173 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 38209: 2026-08-03 22:25:24.740 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 38727: 2026-08-03 23:00:50.035 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 38891: 2026-08-04 09:04:54.120 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 38920: 2026-08-04 15:17:51.281 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 38921: 2026-08-04 15:17:53.039 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 38949: 2026-08-04 19:12:21.526 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39104: 2026-08-05 09:42:57.741 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39105: 2026-08-05 09:43:52.849 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39115: 2026-08-05 11:28:26.851 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39147: 2026-08-05 15:47:59.138 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39333: 2026-08-05 22:17:19.070 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39334: 2026-08-05 22:17:19.776 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39335: 2026-08-05 22:18:29.825 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39336: 2026-08-05 22:18:31.862 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39340: 2026-08-05 22:34:23.237 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39423: 2026-08-06 07:50:01.075 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 39548: 2026-08-06 12:35:22.053 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 43509: 2026-08-06 16:48:49.744 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 43768: 2026-08-07 00:17:50.309 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
Line 43949: 2026-08-07 08:21:29.764 Status: ::ffff:192.168.1.94 -> pre-upgrade write queue exceeded 8388608 bytes; dropping connection
BarryT
Post by BarryT »
After updating to v2026.3 (build 18347), these messages are still appearing. Unfortunately, I can not downgrade back to the stable version.
gizmocuz
Post by gizmocuz »
Found and fixed. When a browser closed its websocket (closing a tab, a phone going to sleep), Domoticz did not answer the close and never dropped the connection. All device updates for that dead connection were then queued until 8 MB was reached, and only then was the connection dropped with this log line. That also explains why it showed up while no browser was open.
Domoticz now answers the close and drops the connection right away, so the message (and the memory it held) is gone. The fix will be in the next beta.
BarryT
Post by BarryT »
gizmocuz wrote: Saturday 31 October 2026 9:34 Found and fixed. When a browser closed its websocket (closing a tab, a phone going to sleep), Domoticz did not answer the close and never dropped the connection. All device updates for that dead connection were then queued until 8 MB was reached, and only then was the connection dropped with this log line. That also explains why it showed up while no browser was open.
Great to hear, thanks! :-)
