Rik60 wrote: Thursday 09 April 2026 15:58
Tested the plugin.
Gave the Tahomabox a new ip adres and resetted the box. Have put this new adres in the hardware settings, and switched to local ip. Restarted the plugin. The Somfy devices where working. After this resetted the token.
In the Domoticz logging i see no messages about a new token. The devices are working.
Hi RIk60,
Thanks for testing.
I'll check on the logging to give more information.
Basically if the devices are working you are having a token
Did you diabled the DNS setting in your router/system/DHCP server, to avoid it still uses this option in the background
I did set the box on another ip adres. I left the previous ip adres in the Hosts file. I have putted this new ip adres in the hardware setup. To be shure i rebooted the raspberry.
If i switch to local pin then the box can't be found. Back to local ip, communication ok and devices are working.
Rik60 wrote: Thursday 09 April 2026 16:35
Ok. Just wanted to be sure
I'll keep it open for few days and if i hear no issue it will push it to the master
Let me know if there are other things required
To be sure from my side:
- Switched to 'Local pin' in the hardware setup
- Removed the Somfy line in the hosts file in the Raspberry
- Shutdown the Raspberry
- Changed the ip adres of the Somfy box in the router
- Rebooted the Somfybox
- Switched On the Raspberry
- Wait a while so everything is powered up.
- In Domoticz log the error 'No communication with the Somfy box'
- Somfy hardware is not responding
- In the hardware setup changed from 'local pin' to 'local ip'
- Changed the ip adres to the current ip adres
- Restarted the Somfy plugin (not Domoticz restart)
- Communication with the Somfybox is Ok and can control the Somfy devices
I have started using the plugin by MadPatrick. I have two garage doors with Moto io drives, as well as roller shutters controlled by Amy 1 io remotes. The control of the garage doors and roller shutters works very well, but I have noticed something that could potentially be improved. In the Tahoma app, I can also control the light integrated into the garage door drive; however, no device for controlling this light has appeared in Domoticz. Furthermore, the Amy 1 io remotes are equipped with temperature sensors, and the readings from these are visible in the Tahoma app—but, unfortunately, I do not see them in Domoticz. It would be fantastic if these two features could also be added to Domoticz, especially the temperature sensor readings from the remotes.
Here is the initial segment of the logs. It detects 6 devices: 2 roller shutters, 2 garage doors, the Box, and the Somfy connection status. Two temperature sensors and two lights are missing. I will try to open an issue on GitHub.
