HomeWizard Wi-Fi P1 Extended
szelessavmuhely
Post by szelessavmuhely »
Hi everyone,
I've developed an **extended version of the HomeWizard Wi-Fi P1 plugin for Domoticz**, and I'm looking for users who would like to test it and provide feedback.
The goal is to provide more detailed electricity measurements, improved device handling, and multi-language support compared to the original plugin.
### Main improvements
- Detailed per-phase measurements (voltage, current, and calculated power)
- Imported and exported energy values for individual tariffs
- Reactive energy and power, power factor, and network frequency
- Improved handling of import/export measurements
- Consistent device structure with 47 Domoticz devices
- Multi-language support (all languages supported by Domoticz)
- Improved stability and error handling
- Detailed documentation explaining the purpose and practical use of each device
The available measurements depend on the connected electricity meter and the data provided by the HomeWizard P1 interface.
### Why so many devices?
The Extended plugin is designed to expose detailed electrical information for users who want more than basic consumption monitoring.
Not every device is necessary for everyday use. For example:
- **Total energy consumption:** Monitor electricity usage over time.
- **Per-phase voltage and current:** Identify uneven phase loading and monitor electrical conditions.
- **Per-phase power:** Estimate how electricity consumption is distributed across L1, L2, and L3.
- **Exported energy:** Monitor electricity returned to the grid, particularly useful for solar installations.
- **Reactive power and power factor:** Provide additional information for more advanced electrical analysis.
- **Active tariff:** Identify the currently active electricity tariff.
The per-phase power values are calculated from voltage, current, and power factor measurements. They should be considered estimates rather than direct per-phase power measurements.
Users can focus on the devices relevant to their installations and ignore the additional measurements.
### Screenshots
**1. Dashboard – Current power consumption and active tariff**
**2. Utility – Detailed electricity measurements**
**3. Hardware – Plugin configuration**
### Installation and documentation
The plugin, installation instructions, configuration details, and update procedures are available on GitHub:
https://github.com/szelessavalapitvany/ ... n-Extended
**The README has been significantly expanded and now includes:**
- Detailed descriptions of all 47 Domoticz devices
- Measurement units and explanations of their meaning
- Practical examples of how individual measurements can be used
- Identification of directly measured and calculated values
- Installation, configuration, update, and downgrade instructions
- Documentation in both English and Hungarian
### Latest update – October 13, 2026
Following user feedback, I've improved the documentation to make the large number of available measurements easier to understand.
The plugin has also received several corrections:
- Corrected power and energy formatting for the total energy devices (Units 1–3)
- Corrected reactive power units from kVArh to kVAr (Units 26–29)
- Preserved the existing device structure and Unit IDs
### Looking for testers
I'm particularly interested in feedback about:
- Installation and initial configuration
- Stability during continuous operation
- Correctness of measured values
- Device creation, naming, and structure
- Compatibility with different electricity meters
- Bug reports, unexpected behavior, and suggestions for improvements
If you already use a HomeWizard Wi-Fi P1 meter with Domoticz, your testing and feedback would be very welcome.
Please include your Domoticz version, electricity meter model, and relevant log messages when reporting an issue.
Thanks in advance for your feedback!
Last edited by szelessavmuhely on Tuesday 13 October 2026 5:38, edited 2 times in total.
willemd
Domoticz version: 2026.3
Re: HomeWizard Wi-Fi P1 Extended
Post by willemd »
szelessavmuhely wrote: Tuesday 31 March 2026 5:39
If you already use a HomeWizard P1 meter with Domoticz, your feedback would be especially valuable.
Thanks in advance!
I have all that already with http poller plugin.
szelessavmuhely
Yes, this plugin focuses on providing a simple, ready-to-use solution with automatic setup.
manjh
Domoticz version: 2025.2
Post by manjh »
I am using the original plugin, and found that the current usage value is a factor 10 too high, both the separate phase values, and also the Total.
Does this new plugin fix that?
Hans
manjh
Post by manjh »
I'm thinking to join your test program, but am unsure if I can install alongside with the current plugin.
Please advise.
Hans
manjh
Post by manjh »
Any thoughts?
If you want/need a tester community, it is important to be responsive!
Hans
Perhaps create an issue on his GitHub https://github.com/szelessavalapitvany/ ... ded/issues
It could be the forum.notifications are not sent or received.
manjh
Post by manjh »
waltervl wrote: Thursday 23 April 2026 22:13 Perhaps create an issue on his GitHub https://github.com/szelessavalapitvany/ ... ded/issues
Done, but no response sofar...
Hans
manjh
Post by manjh »
OK, even though it remains very silent on your side, I decided to go ahead and install.
Dit it according to the instructions (manual install), restarted Domoticz. But I cannot see a new entry in the list of hardware devices.
Please help.
Hans
szelessavmuhely
Sorry for the late reply. Notifications were enabled for this topic, but for some reason I didn't receive any notification about your post.
If the issue is still relevant, could you please check the Domoticz log immediately after restarting Domoticz and post any errors related to the plugin?
It would also be helpful to know:
* What device/platform are you running Domoticz on?
* Which Domoticz version are you using?
There is a 99% chance that the problem is related either to JSON API compatibility or to loading the `from distutils.version import LooseVersion` module.
The plugin was modified a few days ago to improve compatibility with Domoticz 2023.2 and newer versions.
If you post the startup log here, we should be able to identify the exact problem.
manjh
Post by manjh »
I must have done something wrong, but don't see what.
Installed the plugin according to the instructions, and restarted Domoticz.
But then, on the hardware page, I can see two entries for the HomeWizard plugin, and neither shows the word "Extended".
I can see the HomeWIzard Wifi P1 meter, and the HomeWizard Electric P1 meter.
Am I missing something?
Hans
pfloryann
Post by pfloryann »
manjh wrote: Wednesday 30 September 2026 14:38 I must have done something wrong, but don't see what.
It is very likely that the plugin is installed twice. Access the `domoticz/plugins` directory via FTP and check, or use the console—run the command `cd domoticz/plugins/` followed by `dir`—and verify if the plugin folder appears twice.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
manjh
Post by manjh »
Twice... I think I misinformed you.
When I click the dropdown and look for HomeWizard, I can see two choices:
HomeWizard Wifi P1 meter
Which of the two is your plugin?
When I installed the plugin, I first removed the old installation.
This is what I see now in the plugin directory:
HomeWizard-Wifi-p1-plugin
HomeWizard-Wifi-p1-plugin-Extended
Hans
manjh
Post by manjh »
OK, got it. For some reason I expected a different name.
I've used the Electric version, but now see errors:
2026-10-01 17:04:24.592  Status: HW P1E: Entering work loop.
2026-10-01 17:04:24.592  Status: HW P1E: Started.
2026-10-01 17:04:24.816  Status: HW P1E: Initialized version 1.0.0, author 'szelessavmuhely.hu'
2026-10-01 17:04:25.191  Status: Warning: Expecting svalue with at least 5 elements separated by semicolon, 1 elements received ("0"), notification not sent (Hardware: 31 - HW P1E, ID: 001F002F, Unit: 47, Type: FA - P1 Smart Meter, SubType: 1 - Energy)
2026-10-01 17:05:24.111  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.115  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.125  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.133  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.134  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:05:24.139  Error: Invalid Number sValue: '%' for device idx: '%'
Should I worry, or will this fix over time after the first startup?
Also, will I be able to run both P1 plugins at the same time? Some of my scripts still work with the old devices, and I donot want to change anything for now.
Hans
manjh
Post by manjh »
It doesn't fix over time. When I look at the timestamp, it looks like there are three error messages at each run.
2026-10-01 17:06:24.085  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:06:24.091  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:06:24.095  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:07:24.112  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:07:24.116  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:07:24.120  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:08:24.109  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:08:24.112  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:08:24.117  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:09:24.109  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:09:24.114  Error: Invalid Number sValue: '%' for device idx: '%'
2026-10-01 17:09:24.118  Error: Invalid Number sValue: '%' for device idx: '%'
Hans
szelessavmuhely
Hello!
My colleagues and I will look into it tomorrow...
Please help by describing your setup: what device and which version of Domoticz are you using?
Best regards,
Attila
szelessavmuhely
We have fixed an issue in the plugin code related to the initialization of device 47. In theory, this issue should only have caused problems until the first successful data update.
Please update the plugin code from GitHub and restart Domoticz. Then delete the existing plugin instance from the Hardware menu and create it again using the same settings.
Please let us know whether this resolves the problem.
Thank you for your cooperation!
manjh
Post by manjh »
Sorry, I'm out. The resulting info is just too much, and without a good (detailed) description I am unable to understand the relevance.
Hans
szelessavmuhely
Thanks for your feedback, I understand your point.
The extended plugin is intended for users who want more detailed information from their HomeWizard P1 meter, but I agree that without proper documentation, the additional devices and values can be confusing.
I'll work on improving the documentation, including explanations of the individual devices and their practical relevance.
Thanks for taking the time to look at it!
szelessavmuhely
Hi everyone,
Following the feedback about the large number of devices and the lack of detailed explanations, I've updated both the plugin and its documentation.
**What's new:**
- Expanded README with detailed explanations of all 47 Domoticz devices
- Measurement units, practical use cases, and explanations of calculated values
- Corrected energy meter data formatting (Units 1–3)
- Corrected reactive power units (Units 26–29)
- Updated the first post with additional information
The documentation is available in both English and Hungarian.
**GitHub:**
Thanks for the feedback. It helped improve the documentation and make the purpose of the additional measurements clearer.
Further testing and suggestions are always welcome!
