[Theme] - Machinon v2 - schemes, Theme Hub, icon-pack installer
Ragdag
Re: [Theme] - Machinon v2 - schemes, Theme Hub, icon-pack installer
Post by Ragdag »
Sjonnie2017 wrote: Tuesday 01 September 2026 18:14 I installed your theme yesterday and it looks great. I would appreciate an option to suppress the Machinon title bar. Maybe it is already possible but not obvious in the interface. I have not taken the time to investigate (I am lazy :D ).
Keep up the good work!
Yes you can, look at the theme settings
https://domoticz.github.io/Machinon/doc ... d-branding
Ragdag
Post by Ragdag »
Machinon v2.4.0 is out
Notifications reworked
The pop-up messages got a full overhaul. They now follow your colour scheme, in every scheme and in dark mode, instead of the old fixed style. A sensor that keeps timing out no longer warns you again on every page you visit: each device warns once until the problem actually clears, and several warnings at once merge into one summary instead of a flood. The single warnings switch is now two, one for sensor timeouts and one for low battery, and a new setting lets you choose how often a device that already warned you may warn again. Error messages from Domoticz itself, which the theme was accidentally hiding, show up again too.
Every setting, checked
Every setting in the Theme Hub was tested against what its label promises, one by one, and the ones that had quietly stopped working were repaired. The most visible of those: the slider-style on/off toggles on switch cards had died on recent Domoticz betas after an internal change in Domoticz itself, and they are back. "Center popup dialogs" used to center only the edit-style dialogs and now really centers all of them, and the expand arrow on floorplan device popups works again.
While going through them, every setting also got a clearer name and a plainer explanation in the Theme Hub itself. What each setting does is unchanged; it is just easier to tell what you are switching before you switch it.
Documentation
The settings documentation was rewritten in plain language: one short explanation per setting of what you see and what changes when you flip it, instead of a technical table. It lives here: https://domoticz.github.io/Machinon/settings-reference/
Also in this release
  • The brightness sliders in the floorplan device popup now look like the card sliders, and the card slider itself is fully rounded again.
  • The name on a camera card sits on a small readable plate instead of being painted straight onto the picture.
  • Links inside a device's readings are readable again on the light colour schemes.
  • Colour schemes you build yourself now get readable status and energy colours automatically, and the Gruvbox schemes' warning colours were fixed.
Update
cd domoticz/www/styles/machinon
git pull
Then hard-refresh (Ctrl+Shift+R). Zip installs: grab the new one from the releases page.
Links
Releases and full changelog: https://github.com/domoticz/Machinon/releases
Bug, feature or icon request: https://github.com/domoticz/Machinon/issues/new/choose
Ragdag
Post by Ragdag »
Machinon v2.5.0 is out
Machinon now speaks your language
The Theme Hub is no longer English-only. Every tab, every setting name and its explanation, the colour scheme picker, the theme wizard, the icon library and all of the theme's own pop-up messages now follow the language you picked in Setup > Settings, in English, German, French, Dutch, Polish and Swedish. Anything not yet translated in your language simply shows in English instead of breaking, and corrections are welcome: each language is one file on GitHub, so a fix is a small pull request.
Fixes
  • The camera previews on the dashboard are full size again. In 2.4.0 they collapsed to a thin strip showing little more than the camera name.
  • The media remote popup (Kodi, Logitech Media Server, HEOS) opens at full size on a phone again instead of collapsing to just its title bar, and no longer opens as a squeezed sliver with "Center popup dialogs" turned on.
  • On both dashboards, the "x ago" last-seen line now lines up with the rest of the card instead of stopping short of its right edge.
  • When several sensors warn at once, the combined message lists each device on its own line instead of one long comma-separated sentence.
  • The "Apply Settings" button on the Setup pages stays red when you point at it, instead of turning into what looked like a different button.
Update
git pull
Links
Ragdag
Post by Ragdag »
rron wrote: Wednesday 19 August 2026 12:03 Very nice set up. The language dutch changes into English when selecting themes
Translation is now also done
Ragdag
Post by Ragdag »
Machinon v2.6.0 is out
Know when something needs attention
Domoticz always knew which sensors had gone quiet and which batteries were running low, but you had to go looking. Now the theme tells you. A warning icon appears at the right of the header, with a count, whenever devices are timed out or low on battery, and it stays out of the way when everything is healthy. Click it and you land on the new Problem Devices page: every affected device on one list, with the same warning icons the pop-ups use, what is wrong, and when each device last reported (always in 24-hour time). Click a row and the theme takes you to that device on its own page, showing just that device; a small bar clears the view again. The page is also reachable from a new Problem Devices tile in the Settings menu, for the happy days when the badge has nothing to show.
The pop-up warnings themselves join in: a sensor-timeout or battery warning now carries a "Show these devices" button that filters the page you are on to just the devices it names.
Search grew up
Search now matches several words in any order, so "bedroom lamp" finds a device named "Lamp Bedroom", and it shows how many devices matched right inside the box, with a button to clear it. What you typed stays put when you move between pages instead of being wiped on every navigation. The classic dashboard finally searches a device's number, hardware and type like every other page (it used to check only the name there), and the camera previews are searched too. On pages that have no search, the box now clearly shows as disabled.
Fixes
  • Typing in search no longer makes all the device cards shift and grow on wide screens.
  • On phones, opening the search no longer makes the page content jump, and the bar that clears a filtered view sits at the bottom of the screen where it never covers anything.
  • On the Temperature and Weather pages, the favorite star works again and no longer hides inside a card's 3-dot menu; a change in recent Domoticz builds had silently broken it.
Update
git pull
Links
Ragdag
Post by Ragdag »
Machinon v2.7.0 is out
A new version of the Machinon theme is available. The main changes:
Keyboard and screen reader support
  • The on/off toggles on device cards can now be reached with Tab and switched with Space, and screen readers announce them with the device name.
  • On phones and zoomed-in screens the menu button works from the keyboard (Enter opens, Escape closes).
  • In the Theme Hub, colour schemes can be picked with the keyboard, the scheme in use is always marked, and the tabs work with the arrow keys.
Search
  • A search that finds nothing on the current page now says so, with a button to clear it, instead of leaving an empty page. This also covers a search that carried over from the previous page.
Faster and lighter
  • Pages left open, for example on a wall tablet, use noticeably less processor time.
  • On slower devices pages no longer jump from a narrow column to full width right after they open.
  • The Theme Hub only downloads the icon library when you open its Icons tab.
Easier to read and other fixes
  • Better contrast on the Log page status bar, the Theme Hub descriptions, and devices that stopped reporting (their last reading now stays readable).
  • Corrected German, French, Polish and Swedish texts in the diagnostics section, and the Icon Library page is now translated.
  • The custom page button shows the name you set right away.
  • Small security hardening of a few theme settings.
How to update
If you installed from the dist branch: run git pull inside the machinon folder, then hard-refresh your browser (Ctrl+Shift+R).
Other install methods and the full list of changes: release notes on GitHub.
Feedback and bug reports are welcome on GitHub or in this thread.
Ragdag
Post by Ragdag »
Machinon v2.7.1 is out, a small fix release:
  • Devices on disabled hardware stand out again: grey glow, a "blocked" sign next to the name, and the icon, name and controls dimmed. Domoticz only shows these devices when "Hide disabled hardware sensors" is turned off in its settings.
  • Floorplans: the "Wind arrow direction" setting now also applies to wind devices on a plan, and with "Relative times" on the device popup shows "5 minutes ago" instead of the raw date.
  • Search filters as soon as you paste or dictate text, not only after clicking away.
  • The Theme Hub now tells you when it can't use a custom logo or device photo name instead of silently showing the default.
  • Toggles switch without sliding when your device is set to reduce motion.
  • Swedish translation improvements, thanks to DewGew.
Release notes: github.com/domoticz/Machinon/releases/tag/v2.7.1
Updating: if you installed from the dist branch, run this inside the machinon folder, then hard-refresh your browser (Ctrl+Shift+R):
git pull
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
I haven't commented on your excellent work and fine theme. So here it is:
Kudos!
I have been using it for a few months now and it performs really well. No issues to be tackled, no wishes to be granted. It just works like I want it.
YouLess Energy meter
Ragdag
Post by Ragdag »
Sjonnie2017 wrote: Tuesday 13 October 2026 18:08 I haven't commented on your excellent work and fine theme. So here it is:
Kudos!
Thanks 😊
Ragdag
Post by Ragdag »
Machinon v2.8.0 is out
New: copy a device's details from its card
Open a device card's menu (the three dots) and click the Idx row at the bottom.
Four copy actions open underneath:
  • Copy idx: just the device number
  • Copy for dzVents: a ready line to paste into a script, for example:
    domoticz.devices(16) -- Possible Rain
  • Copy API URL: the JSON API address that reads this device
    http:/dz.home.lan:8081/json.htm?type=command&param=getdevices&rid=9
  • Copy device details: name, type, hardware, device ID, value and last update, plus your Domoticz and Machinon versions. Handy when you ask for help here.
    Device: Is it Raining (idx 9)
    Type: Lighting 2, AC, On/Off
    Hardware: Buienradar
    Hardware type: Buienradar (Dutch Weather Information)
    Device ID / unit: 0000001 / 1
    Value: Off
    Last update: 2026-10-14 13:31:48
    Domoticz 2026.4 (build 18475), Machinon 2.7.3
Scene and group cards get the right variant (domoticz.scenes() or domoticz.groups()). If your browser blocks copying, which can happen on a plain http:// address, the text appears in a small box, already selected, for you to copy yourself.
Fixed
  • On iPhone and iPad, pinch-to-zoom works again on every page. Tapping a small field may zoom the page in slightly again, as it did before 2.7.2; pinch out to return.
Update
If you installed from the dist branch: git pull inside the machinon folder, then hard-refresh your browser (Ctrl+F5).
Release notes and download: https://github.com/domoticz/Machinon/re ... tag/v2.8.0
More on the copy actions in the manual: https://domoticz.github.io/Machinon/doc ... g-devices/
