New Python plugin: Domoticz SolarEdge_ModbusTCP
AddieJanssen
Re: New Python plugin: Domoticz SolarEdge_ModbusTCP
Post by AddieJanssen »
imautohuttraeger wrote: Saturday 10 October 2026 1:01 EDIT: Next morning, when the battery is charged again, it is back to normal again (both status devices show "charge").
Maybe this is a standard behaviour, but I thought it might not be harmful to notify this:
Today is the first day since March (Heavy rain and dark clouds all over the day) ,where my Battery was sucked empty.
Battery1 - State of Energy:
"0"
And I recognized the following findings:
Battery1 - Status:
"Key not found in lookup table: 10"
(normally it is Idle, Charge or Discharge)
Battery1 - Internal Status:
"Fault"
According to the SolarEdge documentation that I have, there's no such status as "10".
However, I looked at a Home Assistant plugin, they list this: 10: "B_STATUS_POWER_SAVING"
They have a whole bunch more information where it is unclear where they got it from, but interesting to have a peek at in the future.
hskip
Post by hskip »
I ran the scanner again (with the 15-second setting) on ​​the SE3000, no battery.
python scanner.py 192.168.178.77 502
Connecting to server
Connected to server
Looking for SunSpec identifier at address [40000 (0x9c40)] for device [1]
The inverter is providing a SunSpec Map
Reading Block at address [40002 (0x9c42)] for device [1]
ERROR: request ask for transaction_id=2 but got id=1, Skipping.
Block id = [1]
Block length = [65]
=================================================================== DEVICE DETAILS ===================================================================
[id] [1]
[name] [common]
[label] [Common]
[description] [All SunSpec compliant devices must include this as the first model]
-------------------------------------------------------------------- MEASUREMENTS --------------------------------------------------------------------
[id] [Model identifier] [1]
[l] [Model length] [65]
[mn] [Well known value registered with SunSpec for compliance] [SolarEdge ]
[md] [Manufacturer specific value (32 chars)] [SE3000]
[opt] [Manufacturer specific value (16 chars)] []
[vr] [Manufacturer specific value (16 chars)] [0003.2537]
[sn] [Manufacturer specific value (32 chars)] [7F190BC7]
[da] [Modbus device address] [1]
Reading Block at address [40069 (0x9c85)] for device [1]
Block id = [101]
Block length = [50]
[id] [101]
[name] [inverter_single_phase]
[label] [Inverter (Single Phase)]
[description] [Include this model for single phase inverter monitoring]
[id] [Model identifier] [101]
[l] [Model length] [50]
[a] [AC Current] [0]
[apha] [Phase A Current] [0]
[aphb] [Phase B Current] [NOT_IMPLEMENTED]
[aphc] [Phase C Current] [NOT_IMPLEMENTED]
[a_sf] [] [0]
[ppvphab] [Phase Voltage AB] [230.70] = [2307 * (10**-1)] using scale factor [v_sf]
[ppvphbc] [Phase Voltage BC] [NOT_IMPLEMENTED]
[ppvphca] [Phase Voltage CA] [NOT_IMPLEMENTED]
[phvpha] [Phase Voltage AN] [NOT_IMPLEMENTED]
[phvphb] [Phase Voltage BN] [NOT_IMPLEMENTED]
[phvphc] [Phase Voltage CN] [NOT_IMPLEMENTED]
[v_sf] [] [-1]
[w] [AC Power] [0]
[w_sf] [] [0]
[hz] [Line Frequency] [50.01] = [50013 * (10**-3)] using scale factor [hz_sf]
[hz_sf] [] [-3]
[va] [AC Apparent Power] [0]
[va_sf] [] [0]
[var] [AC Reactive Power] [0]
[var_sf] [] [0]
[pf] [AC Power Factor] [100.00] = [10000 * (10**-2)] using scale factor [pf_sf]
[pf_sf] [] [-2]
[wh] [AC Energy] [41970476.00] = [41970476 * (10**0)] using scale factor [wh_sf]
[wh_sf] [] [0]
[dca] [DC Current] [0]
[dca_sf] [] [0]
[dcv] [DC Voltage] [1.20] = [12 * (10**-1)] using scale factor [dcv_sf]
[dcv_sf] [] [-1]
[dcw] [DC Power] [0]
[dcw_sf] [] [0]
[tmpcab] [Cabinet Temperature] [NOT_IMPLEMENTED]
[tmpsnk] [Heat Sink Temperature] [0]
[tmptrns] [Transformer Temperature] [NOT_IMPLEMENTED]
[tmpot] [Other Temperature] [NOT_IMPLEMENTED]
[tmp_sf] [] [-2]
[st] [Enumerated value. Operating state] [STARTING]
[stvnd] [Vendor specific operating state code] [0]
[evt1] [Bitmask value. Event fields] [NOT_IMPLEMENTED]
[evt2] [Reserved for future use] [NOT_IMPLEMENTED]
[evtvnd1] [Vendor defined events] [0]
[evtvnd2] [Vendor defined events] [NOT_IMPLEMENTED]
[evtvnd3] [Vendor defined events] [NOT_IMPLEMENTED]
[evtvnd4] [Vendor defined events] [0]
Reading Block at address [40121 (0x9cb9)] for device [1]
Block id = [65535]
Block length = [0]
Block type = [The End of the block list has been reached]
End of SunSpec MAP
Looking for Battery at address [57600 (0xe100)] for device [1]
No battery found at this address
Looking for Battery at address [57856 (0xe200)] for device [1]
Disconnected from server
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
hskip wrote: Sunday 11 October 2026 22:39 [...] (with the 15-second setting) [...]
Seems I have missed something. What is the "15-second setting"? Shall we other testers run it with this option, too?
Stop, look and listen.
hskip
Post by hskip »
AddieJanssen wrote: Thursday 08 October 2026 10:24 Are these results from the scanner with the increased timeout?
Please check line 168 of the scanner. It should read:
line 168: client = ModbusTcpClient(host=args.host, port=args.port, timeout=15)
eddieb
Post by eddieb »
The github version is correct ...
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
hjzwiers
Post by hjzwiers »
Have you gotten stuck or something, you started so hopefull?
I looked into the diffences between jvdz's version and yours and why your reaction was so odd, it's this difference:
  # Set Selector switch level to 0;10;20;30 ....
                        if (unit[Column.ID] == inverters.InverterUnit.STORAGECONTROL ) \
                        or (unit[Column.ID] == inverters.InverterUnit.RCCMDMODE ) \
                        or (unit[Column.ID] == inverters.InverterUnit.STORAGE_AC_CHARGE_POLICY ):
                            sValue = unit[Column.FORMAT].format(value*10)
                            if value > 0:
                                nValue = 2
                            # EXTRATEST = True
i couldnt find these in your version 2.07
AddieJanssen
No worries - working on it and so far there are no showstoppers - just running out of time on a daily basis :) We had a heat pump installed and that consumed a lot of time. And every now and then, I need to work as well....
imautohuttraeger
AddieJanssen wrote: Sunday 25 October 2026 17:37 [...]We had a heat pump installed [...]
Very good decision. I envy you for using energy from the soil. I only a have mine working with the energy of the air. However, even this saved me about 600 € per year compared to the old gas heating. And about 400 € on top that came from the solar panels. So summing up about 1000 €.
AddieJanssen
A quick update on where we are:
I have a first 2.1.x version of the plugin working that does not depend on the solaredge_modbus library of nmakel anymore and allows us to update pymodbus to the latest version.
The updated plugin uses the scan functionality as introduced with the scanner tool that we used here over the last month.
I deployed the new plugin to my test setup just now and will let it run for a few days to see if the results make sense and if it does not crash.
Unless my test shows tons of issues, I am planning to release this version later this week.
This is a major rewrite of the plugin, so for sure not a candidate that you want to copy over your current running plugin.
But more on that later.
imautohuttraeger
Great news. I think it is about time for me to finally establish a second system for testing apart from the RasPi ;-)
Maybe an old outdated laptop could do this job.
