Python Plugin: GoodWe solar inverter via SEMS API
Jeweettoch13
Domoticz version: 2026.4
Re: Python Plugin: GoodWe solar inverter via SEMS API
Post by Jeweettoch13 »
Looks like everything is on order again:
Tnx for the hard work everyone.
Only the inverter output current stays at zero for the moment. Is this maybe a mismatch in a datapoint?
JanJaap
Domoticz version: Dev
Post by JanJaap »
That is quite strange as for me all devices are being updated:
Screenshot 2026-09-29 153157.png (80.06 KiB) Viewed 607 times
input - boven and input onder are the 2 strings attached to the inverter
Details for output current:
Screenshot 2026-09-29 153349.png (43.47 KiB) Viewed 607 times
Bw: there is still a whole bunch of legacy code in the plugin, I'll work a bit on cleaning that up the coming days. You will see in the logfiles now that it default to the old endpoint and then as fallback uses the new one, which is a bit stupid
RPi 3, Domoticz dev version, Aeon ZWave stick (with a whole bunch of slaves), Zigbee using Zigbee2MQTT, Nest thermo, P1 smart meter on RPi Zero
RNEE
Domoticz version: 2026.1
Post by RNEE »
Watch this :
- My physical Goodwe Inverter says 15,94 Mwh produced (E-Total)
- My Goodwe website says 15.847,30 Kwh produced
Difference about 100 kwh
After the previous update of the plugin i had a negative value in Domoticz, this means that de Total in Domoticz previously was calculated from another variable.
To me it seems that the plugin previously calculated the right value but now uses another variable?
I deleted wrong values but now " Meter_Calender" reads in Domoticz.db :
2107	10700	15814600	2026-09-20	0
2107	16500	15831100	2026-09-21	0
2107	  9600	15840700	2026-09-22	0
2107	  0	15840700	2026-09-23	0
2107	  0	15840700	2026-09-24	0
2107	10600	15835300	2026-09-28	0
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek Homebattery 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|
Domoticz version: 2026.3
waltervl wrote: Monday 28 September 2026 19:36
waltervl wrote: Sunday 27 September 2026 13:07 It works now again but it has some strange results.
It seems it sometimes sends values with factor 1000 (Wh -KWh) too much.
The totals for the day are correct so not sure what is going on here. The red bar is because of the few days of errors and not counting.
I made a github issue for this as the plugin resets the counter due to receiving partial values from the portal. https://github.com/JanJaapKo/domoticz-G ... /issues/38
Issue solved
Jeweettoch13
JanJaap wrote: Tuesday 29 September 2026 15:34 That is quite strange as for me all devices are being updated:
Youre right at that, thats the DC output current, I'm having zero data at the AC output current.
There is probably a Goodwe.log file in your Domoticz home folder. Check the values in that log in a time it is producing more than 1A. I see 0A in Domoticz when the panels are producing less then 1 A. In the graph of the device that should be visible.
Jeweettoch13
waltervl wrote: Wednesday 30 September 2026 18:59 There is probably a Goodwe.log file in your Domoticz home folder. Check the values in that log in a time it is producing more than 1A. I see 0A in Domoticz when the panels are producing less then 1 A. In the graph of the device that should be visible.
I can only find the domoticz log in the domoticz homefolder wich is 70Gb.
Panels are producing voltage and current so thats ok.
For some reason it doesn't want to give the AC value though it is correctly reported last seen.
Where in the Goodwe script i can check if correct calls are assigned to the inverter AC output?
SEMS+ does give the current AC output value but not trough the plugin unfortunately.
JanJaap
Post by JanJaap »
The logfile in domoticz folder is the one indeed. Just empty it and restart your plugin then you have a fresh folder. With 70gb you will run out of space at some point. BTW you should enable debug logging only when you have issues otherwise turn it off
Jeweettoch13
JanJaap wrote: Thursday 01 October 2026 12:44 The logfile in domoticz folder is the one indeed. Just empty it and restart your plugin then you have a fresh folder. With 70gb you will run out of space at some point. BTW you should enable debug logging only when you have issues otherwise turn it off
This is the debug, AC and Voltage seems to give 0.
JanJaap
Post by JanJaap »
I need the logfile content to asses the actual problem. Please create an issue on github with the clear description of what's wrong plus logfile content
Jeweettoch13
Fixed AC-logging of Current and voltages.
For 3-phase models also per phase output reading.
