For years I have been running async http requests from dzvents to get entsoe prices through their API, until Sep 7th...
Now I just get a response 403 "Forbidden" instead of a list of prices.
I have tried the following analysis:
1) run the same http command from a PC browser : no problem
2) run the same http command with a curl call (on the command line) on the domoticz machine : no problem
3) run the same command with a async shell request running curl from dzvents : no problem (so this is a workaround for now)
so it is only the async http request from domoticz that is triggering an error.
The problem first occurred after the entoe migration to a new platform. For some reason this triggered an incompatibility with the async http request from domoticz. I don't have any info on details of the entsoe migration. The feedback shows that Microsoft-Azure-Application-Gateway/v2 is involved in the creation of the 403 response.
I don't see much usefull info in the domoticz log that could help solve this. Just HTTP/1.1 response: 403 ==>> Forbidden
Anyone with similar experience? Any clue how to get the http request working again, instead of using the shell command as a workaround?
dzvents entsoe http request failing
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2026.3
Re: dzvents entsoe http request failing
What version of Domoticz are you on? Still 2024.1 as in your profile?
willemd
No, latest stable 2026.3
I think my question can also be "how is the full http get command that dzvents is sending with async http different from curl" ? That difference triggers a different reaction from the server.
willemd
I still have not solved this issue. I even generated a new security token for entsoe api but the results remains the same.
It is working in a browser, it is working with curl from command line, it is working with curl from a dzvents shell command, it is working with request get in a python program, it is NOT working from a dzvents http command.
The reponse is "403 Forbidden", which normally should only be given if the authorisation token is incorrect.
So a dzvents http call does something to the token that curl does not ?
The dzvents code is as follows (token redacted):
domoticz.openURL({
url = 'https://web-api.tp.entsoe.eu/api?securityToken=XXXXXXXXXXXXXXX&documentType=A44&in_Domain=10YNL----------L&out_Domain=10YNL----------L&periodStart=202609210000&periodEnd=202609212200' ,
method = 'GET',
callback = 'entsoe',
