is 433Mhz fsk supported on RFLink
Loekie63
- Domoticz version: 2024.7
I am trying to get a Led that is integrated into a ir heater to operate with Domoticz via RFlink. Now I found that the original transmitter uses 433MHz fsk (Frequency Shift Keying) to send commands. Is this supported by RFLink?
Thx for your support.
- gizmocuz
Re: is 433Mhz fsk supported on RFLink
Best to directly ask the designer/author of RFLink this question as it is hardware related
Loekie63
And who would be the best man to ask this question then? I hope you know.
thx for your support.
- Domoticz version: 2026.3
Check the contact page of rflink https://rflink.nl/donate.php
Loekie63
Not much response there.
- gizmocuz
Maybe it is supported with a RFXCom transceiver like the RFXTrx433XL ?
b_weijenberg
- Target OS: -
The RFX-433EMC can use FSK but....
In most cases FSK is using packet mode and needs a special implementation of this protocol in the firmware.
It can also use encryption and in this case it is not possible to use it.
RFX-433, RFX-433EMC, RFX-868
- andreo
- Domoticz version: 2024.3
The RF link operates at 433 MHz using OOK modulation.
https://en.wikipedia.org/wiki/On%E2%80%93off_keying
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
