Philips Hue hardware non-standard ports
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
mikedavies1953
Post by mikedavies1953 »
2026.2
Windows
Philips Hue
Prior to 2026.2, Philips Hue hardware could be configured to use non-standard ports, allowing remote V2 Hue bridges behind port-forwarded routers. After upgrading to 2026.2 the port field disappeared and Domoticz now only attempts V2 HTTPS/443, V1 HTTPS/443 and V1 HTTP/80, causing previously functional remote bridges to fail.
The only remedy seems to be to revert to 2026.1. Are there likely to be any fixes or workarounds?
mikedavies1953
Re: Philips Hue hardware non-standard ports
I see Stable 2026.3 is now out with no sign of any acknowledgment of the use of non-standard ports. Does this mean that there will not be a solution and we have to go back to using the standard ports? Is this a security thing?
