New project, a small wall display to control Domoticz using CYD (Cheap ESP32 touchscreen)
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
Thorgal789
Re: New project, a small wall display to control Domoticz using CYD (Cheap ESP32 touchscreen)
Post by Thorgal789 »
Ha yes, have checked values for my device and mine is smaller ^^.
Thorgal789
Hello, so for information the project have moved a lot with @FlyingDomotic , he have added so much features and we need some testers before pushing the code on "stable" branch.
For exemple :
- It's now possible to send and receive the config using the onboard Web server, the file will be on JSON format.
- There is no limit for widget page number.
- It's possible to make shortcut from a Widget page to another.
- It's possible to protect some page with code.
- The custom font sytem is easier to use, there is ATM 3 fonts at start, Standard (by defaut), French (for French user), and Custom.
- Lot of bugs corrected.
For information as the procedure is not clear yet.
- On first start, your configuration will be upgraded to the new system, that use JSON.
- It's possible to configure Widget page using the setting menu but easier to use the Json, just donwload it, edit it, and send it again.
For exemple
  "pages": [
      "name": "Page 1",
      "number": 1,
      "idx": [
        122,
        75,
        16,
        36,
        28,
        -2,
        63,
        90,
        145
      "name": "Page 2",
      "number": 2,
      "idx": [
        12,
        75,
        16,
        36,
        28,
        -1,
        63,
        0,
        0
On this sample, -1 send to widget page n°1 and -2 send to widget page n°2.
So we can consider the "Homepage" (page n°1) have a link to a second page and this one have a shortcut to return to "Homepage".
All negative number will be used as link to widget page.
The code is still on "test" branch.
Thorgal789
Ok so no one want to make a try ^^.
Someone is using the text widget on a small device ? on a 2.4'', Do you think it would be useful to remove the name and icon on the widget to only display the description ?
There is too few space, but perhaps someone can use it ?
FlyingDomotic
Post by FlyingDomotic »
You now have ESP32-S3 with a 7" color display for 51€ at Amazon. It allows 4 rows of 4 widgets.
I own some of these devices, one displaying 18 pages without trouble.
Thorgal789
Yeah but on my side I m using those device on same place than switch and plug, on a 68mm in wall box.
So I prefer use smal one for integration, but It's simply a matter of taste.
Menno
Domoticz version: 2026.1
Post by Menno »
Since the last upgrade it no longer connects.
(I had not used the display for a while, so I'm noticing this only now)
In my log I see:
Status: [web:8080] Rejected WebSocket upgrade: Origin 'file://' is not allowed for a trusted-network session
Is there anything in the Domoticz settings to fix this?
Or should this be fixed in the device's code?
FlyingDomotic
Are you using "main" or "test" branch ?
Thorgal789
Hello, will be corrected in 1 hour, on the "test" branch.
Good reason to tests all @FlyingDomotic improvements ^^.
Dave21w
Domoticz version: Stable
Post by Dave21w »
I've only just started with this, my ESP32 -S3 7 inch touch arrived this morning. I compiled the latest release (not the test branch) and despite it letting me set it up I obviously got the connection issue so I downloaded the test version and compiled that. Went through the set up and this must connect as I see no errors in the Domoticz log (running the latest beta) but I get nothing on the screen of my touch panel. Am i doing something wrong, should i get the Dashboard contents ?
FlyingDomotic
By default, IDX 1 to 12 are displayed on home page. you may want going to setup (slide screen to right and then "settings" to set your IDX.
You may also check sliding screen to left (going to group page) and then still left (to get device lists)
Thorgal789
You see nothing ? no message about connexion to domoticz , or calibration screen ?
You have edited the platformio.ini file to match your device ?
On first try, enable the "serial monitor" (it's an icon close the one to compile and upload), you will see error message.
And remember
On domoticz, add the device ip to the "trusted network" (else it will be blocked).
Dave21w
Post by Dave21w »
Thanks for the reply's, I have a test system at work so was setting it up on that but then yesterday afternoon got busy so had to do some "actual" work. Anyway when i had the latest stable installed i got the calibration screen and setup etc but since installing the test version from yesterday I have only seen the setup screen once, it seems the touch is not responding as if i power cycle it or press reset it comes up connecting to Domoticz in the middle but pressing the reset button underneath the message i get no response from it. Will investigate further very soon, I have picked the correct panel in the initial build so should be OK.
FlyingDomotic
Unless you erase flash, settings are saved in memory, avoiding restarting initialization process. That's why upgrading is "transparent" and should bring you directly on home page (after showing quickly the network and web connection pages).
Dave21w
Post by Dave21w »
Sorted thank you, when I used the stable I did everything correctly but obviously there was the connection issue which is fixed in the test version however when i compiled the test version i forgot to pick the correct panel type :roll:
FlyingDomotic
Take also care of other compilation options:
	-DUSER_SETUP_LOADED=1 # To enable config throught platformio for TFT_eSPI
	#-DFORCE_CONFIG # Enable or disable the forced network configuration.
	-DFORCECALIBRATE=false # Reset the calibration at every restart, used to reset it after a config change.
	#-DOLD_DOMOTICZ # If you are using older Domoticz version < 2023.2
	-DPAGES=2 # Count of widget pages, including HomePage, need to be at least 1
	-DFASTCLIC # Enable 1 clic action for some widget
	#-DNO_INFO_PAGE # Disable the Info panel
	#-DNO_GROUP_PAGE # Disable the Group/scene panel
	-DFONT_TO_USE=1 # 1=Standard 2=Custom 3=French
	-DHIDE_PASSWORD # Hide password input (else show it)
	#-DAUTO_BRIGHTNESS
	-DDIM_OFF_ICONS # Change Off/Closed devices icons to grey
	-DLIGHTWS # Only possible for version > 16088, decrease WS requests.
	-DPUSHOTA # To enable PUSH OTA (Don't enable both OTA)
	#-DPULLOTA # To enable PULL OTA (Don't enable both OTA)
	#-DCORE_DEBUG_LEVEL=5 # To enable debug on serial for librairies and core
	#-DLV_USE_SNAPSHOT=1 # Enable to take screen snapshots (will fail on non PSRAM devices)
   	#-DDEBUG_LVGL # Used to internaly debug LGVL
Dave21w
Post by Dave21w »
Thank you, i will check on those later
wim57
Post by wim57 »
This morning I upgraded Domoticz to 2026.3. Now the CYD cannot connect to Domoticz any longer,
Domoticz log shows an error: Rejected WebSocket upgrade: Origin 'file://' is not allowed for a trusted-network session
If I remove the trusted network IP the error changes in:
Rejected WebSocket upgrade: Origin 'file://' is not allowed for a cookie-less session
It seems the websocket handling in Domoticz has become a bit more picky.
Edit: I see this is already addressed in the test branch. Problem solved.
FlyingDomotic
Strange...
I'm using layrdy test version of CYD (26.9.19-1) with Domoticz 2026.3, and it works perfectly...
Did you compile with -DOLD_DOMOTICZ? You can check it on tools page.
Thorgal789
About last @FlyingDomotic features he have added.
Here you have a sample with resized widget.
And here the "interaction", the CYD is able to communicate from and to domoticz using 2 text widgets.
