Multiple sensor weather temphumbaro
thaui
- Domoticz version: 2023.2
can somebody explain to me how to interpreting the one digit numbers in the forecast code of the sensor. The sensor is a weather sensor from OpenWeatherMap and the value reading looks like this "ForecastCode 17.1;86;3;1013.0;4". What is the number "3" and the number "4" for? Is the "3" for humidity and the "4" for clouds or vice versa?
- jvdz
- Domoticz version: 4.107
Re: Multiple sensor weather temphumbaro
Maybe this explains it for you?
https://wiki.domoticz.com/Domoticz_API/ ... o/setpoint
thaui
Thanks for the reply. This helps only partialy because i will have a value of "5"
Snowtiger
I see :
Barometer forecast does not seem to work....
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
TEMP = Temperature
HUM = Humidity
HUM_STAT = Humidity status
BAR = Barometric pressure
BAR_FOR = Barometer forecast
That's five as far as I see it.....
TEMP = Temperature
HUM = Humidity
