Domoticz revision Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
HansieNL
Domoticz revision
Post by HansieNL »
Hello all,
Maybe I don't look good but I can't find the revision of the installed Domoticz version.
In the about box there's no revision version shown only the main version.
Can someone tell me how to get the revision?
Thanks in advance.
Blah blah blah
jannl
Domoticz version: 2026.1.x
Re: Domoticz revision
Post by jannl »
It is on top of the screen, below 'Domoticz' in the upper left corner. On a mobile only in landscape mode
HansieNL
Post by HansieNL »
Thanks jannl.
I see the main version number, but not a revision number.
With an older beta version (before the complete restyling) the revision was shown between parenthesis () behind the main version.
Would be great if the revision will be shown at the about box too.
Blah blah blah
Rik60
Domoticz version: 2026.3
Post by Rik60 »
Same problem here. Running 2026.3 beta, updated today
HansieNL
Post by HansieNL »
Trying http://192.168.2.2:8080/json.htm?type=c ... getversion and the answer is without the revision number too?
In the past it was shown this way "version" : "2023.1 (build 15331)" now I just get "version" : "2026.3"
Blah blah blah
Rik60
Post by Rik60 »
"DomoticzUpdateURL" : "https://www.domoticz.com/download.php?c ... ne=aarch64",
"HaveUpdate" : false,
"Revision" : 18180,
"SystemName" : "linux",
"UseUpdate" : true,
"build_time" : "2026-08-05 13:24:03",
"db_size" : 19188736,
"dzvents_version" : "3.1.11",
"hash" : "8b245beb5",
"python_version" : "3.13.5 (main, Jul 15 2026, 20:25:40) [GCC 14.2.0]",
"status" : "OK",
"title" : "GetVersion",
This is the answer
HansieNL
Post by HansieNL »
@Rik60
As far as I know is this revision version the latest revision available for download and not the installed version.
I get revision 18185, but I'm sure I don't have that one installed.
Blah blah blah
HansieNL
Post by HansieNL »
Looks like problem will be fixed:
Little info - Build version missing #6943 https://github.com/domoticz/domoticz/issues/6943
FIXED :D
Blah blah blah
Gravityz
Post by Gravityz »
thought it was a new feature.
some time a go i started naming my docker container with the build included so it was not a big deal for me.
glad is it back now
HansieNL
Post by HansieNL »
I now have created a dzvents script that sends the version as for example 2026.3.18185 to a variable. This script will run at every domoticz start.
        at_startup = true
    execute = function(domoticz)
        local rawVersion = tostring(domoticz.settings.domoticzVersion)
        local currentVersion = rawVersion:gsub("%s*%(build%s*(%d+)%)", ".%1")
        local var = domoticz.variables('domoVer')
        local storedVersion = var.value
        if currentVersion ~= storedVersion then
            domoticz.log('Nieuwe Domoticz versie: ' .. currentVersion, domoticz.LOG_INFO)
            var.set(currentVersion)
Blah blah blah
