Dastihcz 3.20.0
Renber
Re: Dastihcz 3.20.0
Post by Renber »
Thanks.
I ran `git pull` this morning to update, but there was a conflict with my `config.js` (which is normally excluded from updates), and the `index.php` file is corrupted—it contains your changes instead of the actual code.
Have a good day.
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
madpatrick
Domoticz version: 2026.1
Re: Dastihcz 3.20.0
Post by madpatrick »
Which branch are you using ?
The index.php was net yet merged to the beta branch of Dashticz
CONFIG.JS is indeed excluded from updates, but is also not in the folder.
I need to check if i can reproduced it
Renber
Re: Dastihcz 3.20.0
Post by Renber »
I use `updatebeta.sh` or run `git pull` on the `beta` branch.
If you look at the beta branch of the GitHub code, you will see the incorrect file.
madpatrick
Re: Dastihcz 3.20.0
the PR has not yet been release by the moderator
Renber
Re: Dastihcz 3.20.0
Post by Renber »
How did this file get destroyed yesterday? I think it happened after an update (I run updates almost every day, and I was completely up to date two days ago).
madpatrick
Re: Dastihcz 3.20.0
Some PR were pushed yesterday.
The fix i did today in PR #1247
Renber
Re: Dastihcz 3.20.0
Post by Renber »
https://github.com/Dashticz/dashticz/co ... 1c7122a966
The error is here; look at the trash PHP file.
madpatrick
Re: Dastihcz 3.20.0
Fix is here
https://github.com/Dashticz/dashticz/pu ... cdff24c165
Better to raise an issue on GIT for this
Renber
Re: Dastihcz 3.20.0
Post by Renber »
Thanks, I’ve just reported it. Is there a way for me to install the beta with your latest PR before it gets approved?
madpatrick
Re: Dastihcz 3.20.0
see reply on GIT
madpatrick
Re: Dastihcz 3.20.0
Hi All
A new update has been released in the beta branch
Please be aware this is a beta version a can be buggy, so make a backup.
In this release some bug fixes and update are incorporated
[*] A theme feature has been added for a standard customization
[*] The Topbalk has been modified with the new feature icons and slide out to the top
Greenshot - Topbalk.png (43.48 KiB) Viewed 1634 times
[*] Preparations a made for a device editor to a device and resizing in the dashboard for non-programmers
This feature is not ready yet and needs still a lot of work, You can use it, but it is still buggy and far from ready
Greenshot - Device editor.png (33.71 KiB) Viewed 1634 times
[*] Preparations are made for a widget menu to add and configure the widgets
Greenshot - widgetmenu.png (39.89 KiB) Viewed 1634 times
Again, this is still a beta version and a lot has still to be done
Please share your findings on GIT and any tips or ideas are welcome
After the update you need to run "sh updatebeta.sh" to set some settigngs correct
In the future you need to use this script for updates instead of git pull
Renber
Re: Dastihcz 3.20.0
Post by Renber »
first of all, I’d like to thank you for the great work you’re doing.
A quick note: since the update (official Beta), the top bar is too tall.
As for the waste collection module, everything is in order now.
Keep up the good work. I’m available for testing from time to time if needed.
madpatrick
Re: Dastihcz 3.20.0
Do you have more info or a screenshot for me
For the topbar.
Basically the topbar should disappear after the timeout
I need some testers and would appreciate if you would help with this. Also any new feature ideas are welcome
Send me a PM otherwise
Renber
Re: Dastihcz 3.20.0
Post by Renber »
Here it is; it used to be much smaller.
After testing, it's the MiniClock that's causing the problem.
columns['bar']['blocks'] = ['logo','miniclock','sunrise'];
madpatrick
Re: Dastihcz 3.20.0
Can you try if this settings working in yout CONFIG.js (or do you have this already ?)
config["topbar_timeout"] = 5;
Renber
Re: Dastihcz 3.20.0
Post by Renber »
Yes, that setting works well, but the bar is still too high. Try it with Miniclock and you'll see.
madpatrick
Re: Dastihcz 3.20.0
In my version it looks good, but i'm ahead :o
2026-07-28 20_09_13-Greenshot.png (46.28 KiB) Viewed 1572 times
Renber
Re: Dastihcz 3.20.0
Post by Renber »
I tested it with config_default.js just to be sure, and I'm still having the issue, so there must be an error in my version. Let's put this aside until the next release, then.
Is there a way to test your version without altering my current one? Just for testing purposes. I'm not very comfortable with Git.
madpatrick
Re: Dastihcz 3.20.0
Renber wrote: Tuesday 28 July 2026 20:27 I tested it with config_default.js just to be sure, and I'm still having the issue, so there must be an error in my version. Let's put this aside until the next release, then.
See PM.
Renber
Re: Dastihcz 3.20.0
Post by Renber »
I checked out your repository. We’re on the same version now. I haven't noticed any changes with my setup, except for the miniclock, which isn't displaying anything; it takes up the right amount of space in the top bar but remains black.
