Dashticz - Module - Garbage collector Topic is solved
nfuse
Re: Dashticz - Module - Garbage collector
Post by nfuse »
a few weeks ago mine stopped working to (hvc) i created a fix for the garbage collector and mine is working again. i did a pull request i you want to test download it here. https://github.com/Dashticz/dashticz/pull/1230
docker with sonos http api / mosquitto / zigbee2mqtt assistant / portainer / dashticz / nodeJS on windows with Zigbee2Mqtt, and some flask builds of my own
jake
Post by jake »
nfuse wrote:a few weeks ago mine stopped working to (hvc) i created a fix for the garbage collector and mine is working again. i did a pull request i you want to test download it here. https://github.com/Dashticz/dashticz/pull/1230
Thanks for the fix. I am on hvc as well and now the pickup dates are working again
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
Unfortunately info for Waardlanden (Alblasserwaard) still isn't working with this fix. Info stopped coming in a few weeks ago. I only replaced index.php and reloaded Dashticz in the browser. Will try to restart my rasperry pi; maybe then it 'll work
Renber
Post by Renber »
for about two years now, the trash module (Recyleapp) hasn't been working for me out of the box; I have to modify the `index.php` file to get it to work. I found that changing the line `function curlWebJson($url, $headers=0)` to `function curlWebJson($url, $headers=[])` solves the issue.
Is this a bug?
Is there an explanation for this?
Thanks.
Linux Debian 12 Server: Domoticz beta + Dashticz beta + Node-Red + Homebridge
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
posted a fix PR for this issue
https://github.com/Dashticz/dashticz/pull/1246
