Problem with accessing https://api.open-meteo.com/
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
hjzwiers
Post by hjzwiers »
I'm using a script in accessing open.meteo. I running with dockge and the latest beta. My code is :
Domoticz is reporting a 503 error, api.open.meteo is not accessible, but 10000 hits are available and Ive had some sussesvol sessions, but few
Anyone have the same problem?
   active = true,
     timer = { "every 30 minutes" },
     httpResponses = { 'openmeteo_cloud_api' }
domoticz.log(
    "Cloud trigger: timer="..tostring(item.isTimer)..
    " http="..tostring(item.isHTTPResponse),
    domoticz.LOG_STATUS)
    -- CONFIG
    local var = domoticz.variables("CloudForecast_LastUpdate")
    local lastUpdate = var and tonumber(var.value) or 0
    local now = os.time()
    local retryVar = domoticz.variables("CloudForecast_LastAttempt")
    local lastAttempt = retryVar and tonumber(retryVar.value) or 0
    domoticz.log("Time Now : "..now.. "  Time LastAttempt : " .. lastAttempt .. "  Time- LastAttempt : " .. now-lastAttempt, domoticz.LOG_STATUS)
    if (now - lastAttempt) < 1800 then
        domoticz.log("Cloud API retry delay active", domoticz.LOG_DEBUG)
        return
    -- STEP 1: THROTTLED REQUEST
    if item.isTimer then
        -- ⛔ SKIP IF DATA IS STILL FRESH (15 min cache)
        if (now - lastUpdate) < 900 then
            domoticz.log("Cloud API skipped (cached)", domoticz.LOG_DEBUG)
            return
    if retryVar then
        retryVar.set(now)
    local URL = "https://api.open-meteo.com/v1/forecast?latitude=51.46&longitude=5.45&hourly=shortwave_radiation,cloud_cover&timezone=auto&tilt=55"
    domoticz.openURL({
        url = URL,
        method = 'GET',
        timeout = 30,
        callback = 'openmeteo_cloud_api',
        domoticz.log("Cloud API request sent", domoticz.LOG_STATUS)
        return
    -- STEP 2: RESPONSE HANDLING
    if not item.isHTTPResponse then return end
    domoticz.log("HTTP status: " .. tostring(item.statusCode), domoticz.LOG_STATUS)
    if item.statusCode == 503 then
--        domoticz.variables("CloudForecast_LastAttempt").set(os.time())
        domoticz.log(
            "Open-Meteo overloaded. Keeping previous forecast.",
            domoticz.LOG_STATUS
        return
    if item.statusCode ~= 200 then
        domoticz.log(
            "Weather download failed: "..tostring(item.statusCode),
            domoticz.LOG_ERROR
        domoticz.log(tostring(item.data), domoticz.LOG_ERROR)
        return
    if item.headers then
    for k,v in pairs(item.headers) do
        domoticz.log(k.." = "..tostring(v), domoticz.LOG_ERROR)
    -- HARD VALIDATION
    local body = tostring(item.data or ""):match("^%s*(.*)")
    if body == "" or body:sub(1,1) ~= "{" then
        domoticz.log("Invalid response: " .. body, domoticz.LOG_ERROR)
        return
    -- SAFE PARSE
    local ok, data = pcall(domoticz.utils.fromJSON, item.data)
    if not ok then
        domoticz.log("JSON parse failed", domoticz.LOG_ERROR)
        return
    domoticz.log("JSON parsed successfully", domoticz.LOG_STATUS)
    domoticz.log(item.data, domoticz.LOG_STATUS)
    -- FIELD CHECK
    if not data.hourly or not data.hourly.time or not data.hourly.cloud_cover or not data.hourly.shortwave_radiation then
        domoticz.log("Cloud API missing required fields", domoticz.LOG_ERROR)
        --domoticz.log(item.data, domoticz.LOG_ERROR)
        return
    -- BUILD CLEAN FORECAST
    local out = {}
    local max = math.min(24, #data.hourly.time)
    for i = 1, max do
    local t = data.hourly.time[i]
    local c = data.hourly["cloud_cover"][i]
    local r = data.hourly["shortwave_radiation"][i]
    if t and c ~= nil then
        out[#out+1] = {
            t = t,
            c = tonumber(c) or 50,
            rad = tonumber(r) or 0
    if #out == 0 then
        domoticz.log("Cloud API empty result", domoticz.LOG_ERROR)
        return
    -- SAVE FORECAST
    if var then
        var.set(os.time())
        domoticz.log("Missing CloudForecast_LastUpdate variable", domoticz.LOG_ERROR)
    local store = domoticz.variables("CloudForecast")
    if store then
        store.set(domoticz.utils.toJSON(out))
    -- LOG
    domoticz.log(string.format(
        "Cloud API updated OK (%d entries)",
        #out
Domoticz version: 2026.3
Re: Problem with accessing https://api.open-meteo.com/
The line
is not doing anything. The next lines running the http response is always running also when it is timer response. Then you will get an error.
So make httpresponse working eg
if item.isHTTPResponse then
  -- Do your httpresponse code
hjzwiers
Post by hjzwiers »
I dont think that that was the problem. I could go to the website with the http address and get the needed info, and i could use curl command to get the file with a new script, it was the openURL that was failing, and still is failing
I should give it a try if I were you.....
An if you think it is openurl then try the curl from within the docker container.
hjzwiers
Post by hjzwiers »
I did try it, and it doesn't give the result. I also implemented a version with curl, which works flawlessly, so i have a running solution. But the fact that openURL is failing made me think. I worked it out with ChatGPT, ant it says after running several experiments that the version of:
I'm seeing intermittent HTTP 503 responses when using dzVents domoticz.openURL() to query the Open-Meteo API. The exact same URL, executed from the same Docker container with the command-line curl, consistently returns HTTP 200 and valid JSON.
I verified:
The URL is correct.
The request rate is low (every 30 minutes).
Manual curl requests can be repeated without issue.
The problem occurs only when using openURL().
As a workaround, I changed the script to execute curl externally, read the JSON from a temporary file, and parse it in dzVents. This has been reliable. Occasionally the first curl attempt fails, but a retry 5 seconds later succeeds, suggesting a transient network or server issue that curl handles better than openURL().
My Domoticz version is 18133 (beta) running in Docker, and the binary is linked against libcurl-gnutls (libcurl-gnutls.so.4).
I see no reason why dzvents function OpenUrl should not work properly in docker.
hjzwiers
Post by hjzwiers »
Strange, if i run the curl script, and in the same timeslot the openURL, the openURL script runs without error, as if the curl script primes someting, very strange. If i run the openURL script alone, it fails.
hjzwiers
Post by hjzwiers »
My idea that some kind of trigger must prime the openURL is true, if i check any site (for instance google) then the full previous code is succesvol:
    local URL = "https://www.google.com/"  --https://httpbin.org/get
    domoticz.openURL({
        url = URL,
        method = "GET",
        callback = "warmup"
    os.execute("sleep 5")
    local URL = "https://api.open-meteo.com/v1/forecast?latitude=51.46&longitude=5.45&hourly=shortwave_radiation,cloud_cover&forecast_hours=24&timezone=auto&tilt=55"
     domoticz.openURL({
        url = URL,
        method = 'GET',
        timeout = 30,
        headers = {
        ["Accept"] = "*/*",
        ["User-Agent"] = "curl/8.14.1",
        ["Connection"] = "close"
        return
    if item.trigger == "warmup" then
     return
it should be as simple as in the Dzvents wiki example. Callback and httpResponses should be the same value. Also they should be unique so no reuse of a callback else another script with the same httpResponse will be triggered.
https://wiki.domoticz.com/DzVents:_next ... d_handling
        timer = { 'every 5 minutes' },
        httpResponses = { 'energyRetrieved' }
        if (item.isTimer) then
            domoticz.openURL({
            url = 'http://url/to/service',
            method = 'GET',
            callback = 'energyRetrieved'
        elseif (item.isHTTPResponse) then
            if (item.ok) then -- statusCode == 2xx
                local current = item.json.consumption
                domoticz.devices('myCurrentUsage').updateEnergy(current)
I just tested this with the following script and it is working just fine on my docker system also after some minutes.
        timer = { 'every minute' },
        httpResponses = { 'meteotest' }
    logging = {
		    level = domoticz.LOG_INFO,
		    marker = 'meteo',
            domoticz.openURL({
            url = 'https://api.open-meteo.com/v1/forecast?latitude=51.46&longitude=5.45&hourly=shortwave_radiation,cloud_cover&forecast_hours=24&timezone=auto&tilt=55',
            method = 'GET',
            callback = 'meteotest'
            domoticz.log('openurl called')
                domoticz.log('Could get data from website ',domoticz.LOG_INFO)
                domoticz.log(item.data,domoticz.LOG_INFO)
                domoticz.log('Could not get (good) data from website ',domoticz.LOG_STATUS)
Logging:
2026-07-22 18:56:00.148  dzVents: meteo: openurl called
2026-07-22 18:56:00.496  dzVents: meteo: Could get data from website
2026-07-22 18:56:00.496  dzVents: meteo: {"latitude":51.466,"longitude":5.4519997,"generationtime_ms":0.06568431854248047,"utc_offset_seconds":7200,"timezone":"Europe/Amsterdam","timezone_abbreviation":"GMT+2","elevation":39.0,"hourly_units":{"time":"iso8601","shortwave_radiation":"W/m²","cloud_cover":"%"},"hourly":{"time":["2026-07-22T18:00","2026-07-22T19:00","2026-07-22T20:00","2026-07-22T21:00","2026-07-22T22:00","2026-07-22T23:00","2026-07-23T00:00","2026-07-23T01:00","2026-07-23T02:00","2026-07-23T03:00","2026-07-23T04:00","2026-07-23T05:00","2026-07-23T06:00","2026-07-23T07:00","2026-07-23T08:00","2026-07-23T09:00","2026-07-23T10:00","2026-07-23T11:00","2026-07-23T12:00","2026-07-23T13:00","2026-07-23T14:00","2026-07-23T15:00","2026-07-23T16:00","2026-07-23T17:00"],"shortwave_radiation":[148.0,228.0,68.0,21.0,5.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,5.0,59.0,103.0,143.0,109.0,174.0,596.0,727.0,734.0,639.0,550.0],"cloud_cover":[99,100,100,100,100,100,100,100,100,99,100,100,100,100,100,92,100,100,93,99,96,100,100,100]}}
2026-07-22 18:57:00.198  dzVents: meteo: openurl called
2026-07-22 18:57:00.507  dzVents: meteo: Could get data from website
2026-07-22 18:57:00.508  dzVents: meteo: {"latitude":51.466,"longitude":5.4519997,"generationtime_ms":0.08022785186767578,"utc_offset_seconds":7200,"timezone":"Europe/Amsterdam","timezone_abbreviation":"GMT+2","elevation":39.0,"hourly_units":{"time":"iso8601","shortwave_radiation":"W/m²","cloud_cover":"%"},"hourly":{"time":["2026-07-22T18:00","2026-07-22T19:00","2026-07-22T20:00","2026-07-22T21:00","2026-07-22T22:00","2026-07-22T23:00","2026-07-23T00:00","2026-07-23T01:00","2026-07-23T02:00","2026-07-23T03:00","2026-07-23T04:00","2026-07-23T05:00","2026-07-23T06:00","2026-07-23T07:00","2026-07-23T08:00","2026-07-23T09:00","2026-07-23T10:00","2026-07-23T11:00","2026-07-23T12:00","2026-07-23T13:00","2026-07-23T14:00","2026-07-23T15:00","2026-07-23T16:00","2026-07-23T17:00"],"shortwave_radiation":[148.0,228.0,68.0,21.0,5.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,5.0,59.0,103.0,143.0,109.0,174.0,596.0,727.0,734.0,639.0,550.0],"cloud_cover":[99,100,100,100,100,100,100,100,100,99,100,100,100,100,100,92,100,100,93,99,96,100,100,100]}}
2026-07-22 18:58:00.245  dzVents: meteo: openurl called
2026-07-22 18:58:00.551  dzVents: meteo: Could get data from website
2026-07-22 18:58:00.551  dzVents: meteo: {"latitude":51.466,"longitude":5.4519997,"generationtime_ms":0.08940696716308594,"utc_offset_seconds":7200,"timezone":"Europe/Amsterdam","timezone_abbreviation":"GMT+2","elevation":39.0,"hourly_units":{"time":"iso8601","shortwave_radiation":"W/m²","cloud_cover":"%"},"hourly":{"time":["2026-07-22T18:00","2026-07-22T19:00","2026-07-22T20:00","2026-07-22T21:00","2026-07-22T22:00","2026-07-22T23:00","2026-07-23T00:00","2026-07-23T01:00","2026-07-23T02:00","2026-07-23T03:00","2026-07-23T04:00","2026-07-23T05:00","2026-07-23T06:00","2026-07-23T07:00","2026-07-23T08:00","2026-07-23T09:00","2026-07-23T10:00","2026-07-23T11:00","2026-07-23T12:00","2026-07-23T13:00","2026-07-23T14:00","2026-07-23T15:00","2026-07-23T16:00","2026-07-23T17:00"],"shortwave_radiation":[148.0,228.0,68.0,21.0,5.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,5.0,59.0,103.0,143.0,109.0,174.0,596.0,727.0,734.0,639.0,550.0],"cloud_cover":[99,100,100,100,100,100,100,100,100,99,100,100,100,100,100,92,100,100,93,99,96,100,100,100]}}
2026-07-22 18:59:00.288  dzVents: meteo: openurl called
2026-07-22 18:59:00.563  dzVents: meteo: Could get data from website
2026-07-22 18:59:00.564  dzVents: meteo: {"latitude":51.466,"longitude":5.4519997,"generationtime_ms":0.058770179748535156,"utc_offset_seconds":7200,"timezone":"Europe/Amsterdam","timezone_abbreviation":"GMT+2","elevation":39.0,"hourly_units":{"time":"iso8601","shortwave_radiation":"W/m²","cloud_cover":"%"},"hourly":{"time":["2026-07-22T18:00","2026-07-22T19:00","2026-07-22T20:00","2026-07-22T21:00","2026-07-22T22:00","2026-07-22T23:00","2026-07-23T00:00","2026-07-23T01:00","2026-07-23T02:00","2026-07-23T03:00","2026-07-23T04:00","2026-07-23T05:00","2026-07-23T06:00","2026-07-23T07:00","2026-07-23T08:00","2026-07-23T09:00","2026-07-23T10:00","2026-07-23T11:00","2026-07-23T12:00","2026-07-23T13:00","2026-07-23T14:00","2026-07-23T15:00","2026-07-23T16:00","2026-07-23T17:00"],"shortwave_radiation":[148.0,228.0,68.0,21.0,5.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,5.0,59.0,103.0,143.0,109.0,174.0,596.0,727.0,734.0,639.0,550.0],"cloud_cover":[99,100,100,100,100,100,100,100,100,99,100,100,100,100,100,92,100,100,93,99,96,100,100,100]}}
But now I get the error, but after that no issues, so it seems an issue on the server that has some issues sometimes:
2026-07-22 19:00:01.307  Error: Error opening url: https://api.open-meteo.com/v1/forecast?latitude=51.46&longitude=5.45&hourly=shortwave_radiation,cloud_cover&forecast_hours=24&timezone=auto&tilt=55
2026-07-22 19:00:01.795  Error: dzVents: meteo: HTTP/1.1 response: 503 ==>> Service Unavailable
2026-07-22 19:00:01.796  Status: dzVents: meteo: Could not get (good) data from website
2026-07-22 19:00:01.796  dzVents: meteo: {"error":true,"reason":"The service is overloaded"}
hjzwiers
Post by hjzwiers »
i found a return that shouldnt be there .... and i added a os.execute("sleep 5") to get the https request out of the busy area around the vol minute.
Is there any other way to delay that period, for instance 30 seconds after the minute, and then every half hour?
Thanks for the help!
Do not use a sleep as it stalls Domoticz for 5 seconds!
I think you can use afterSec(5) so
domoticz.openURL(---).afterSec(5)
hjzwiers
Post by hjzwiers »
Perfect, it working!
