hello all.
I am running domoticz 2025-2 on two RPI's and everything is working pretty stable.
So it's time to make it more fancy/clearly starting with custom icons.
This mainly due to the amount of switches (currently about 210)
Most of the In and outputs are via MQTT and a boatload of ESP modules.
Domoticz Icon Generator was a big help and the first few custom icons are indeed showing on (settings,custom icons )page.
see attm.
But on the switch itself not.
I have tried to find if somebody has mentioned this before on the forum but could not find any similar problem.
custom icons not showing correctly
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
goblin
- Domoticz version: 2023.1
- green_spot.png (27.46 KiB) Viewed 596 times
- green_spot custom icons.png (14.86 KiB) Viewed 596 times
