I recently acquired a Indevolt SolidFlex 2000 eco + SFA3600 stack. Works like a charm with the app. To enable automation, e.g. putting the battery in stand-by when charging my car, I decided to create a plugin against the Indevolt OpenData API. The idea is to use a Zigbee CT Energy meter to detect when the car is charging (e.g. anything above 2A) to activate the automation.
The plugin creates the necessary devices automatically including the switches to set the working mode, charging state and enable/disable the Backup Power Socket. Please have a look and feel free to use it for your own scenario's.
Here is the link to the github repository: https://github.com/marceldbo/Domoticz-Indevolt-plugin
Comments and suggestions are welcome.
Enjoy,
Marcel
Indevolt Battery plugin
bartnl
Re: Indevolt Battery plugin
thanks for the plugin idea. I used it for reference for a script that does the same for my Indevolt SolidFlex 3000 AC with SFA3600 batteries. I'm using my P1 meter data to detect if my dumb on/off car battery charger is on and set the Indevolt to standby and thanks to you it's already working
- Xenomes
- Domoticz version: 2026.4
Thanks for the plugin! I've already been using it for a couple of weeks, I found it on GitHub. Keep up the good work.
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
